    Help with calendar
    27 Posts 2 Posters 8.8k Views 2 Watching
    • G Offline
      gerbenz @sdetweil
      done,but not working. stays empty
        sdetweil @gerbenz
        @gerbenz can you show me output of
        git branch
        • G Offline
          gerbenz @sdetweil
          • _fix_clipping
            master
            sdetweil @gerbenz
            @gerbenz ok, can you show the output of starting MagicMirror
            if you are using pm2 then
            pm2 logs --lines=xxx
            xxx is the number of most recent lines , default 15
            you may need more
            careful the cal broadcast message contains the full url so coukd expose personal info
            is it broadcasting events ?
            • G Offline
              gerbenz @sdetweil
              only see events when i place orriginal callendar too,
              then the addon works good.
              wierd.
                sdetweil @gerbenz
                @gerbenz no idea
                can you show the calendar configuration
                (xxx out the urls but don’ change anything else)
                you ARE just commenting out the calendar position line, right??
                mine looks like this
                        classes: "page1",
                        //position: "top_left",
                        order: "*",
                        index: 1,
                        label: "instance 1",
                          broadcastPastEvents: true,
                          fetchInterval: 120000,
                          urgency: 0,
                          dateFormat: "Do.MMM, HH:mm",
                          fullDayEventDateFormat: "Do.MMM",
                          getRelative: 0,
                          hidePrivate: true,
                • G Offline
                  gerbenz @sdetweil
                  		module: "MMM-CalendarExt3",
                  		header: "Afspraken",
                  		position: "middle_center",
                              mode: "week",
                              weeksInView: 1,
                              weekIndex: 0,
                              instanceId: "basicCalendar",
                              locale: 'nl-NL',
                              maxEventLines: 5,
                              firstDayOfWeek: 0,
                  			startDayIndex: 0,
                              displayEndTime: true,
                  	        calendarSet: null,
                              refreshInterval: 60000,
                  		    fontsize: '30px',
                  		    eventHeight: '30px',
                  		    useWeather: false,
                  		    skipPassedEventToday: true,
                  					name: "werk stefnie",
                  					color: "red",
                  					url: "https://xxxx"
                                      url: "webcal://p181-caldav.icloud.com/published/xxxx",
                                      url: "webcal://p175-caldav.icloud.com/published/xxxx",
                    sdetweil @gerbenz
                    @gerbenz no, the default calendar, where the events come from
                    • G Offline
                      gerbenz @sdetweil
                      			coloredText: true,
                                  broadcastPastEvents: false, // <= IMPORTANT to see past events
                      			fetchInterval: 1000 * 60 * 1,
                      					symbol: "werk stefnie",
                      					url: "xxxxx"
                                          symbol: "Stefanie",
                                          url: "webcal://p181-caldav.icloud.com/published/xxxxx",
                                          symbol: "Gezin",
                                          symbol: "Amber",
                                          symbol: "Luna",
                                          url: "webcal://p181-caldav.icloud.com/published/xxxxxx",
                                          symbol: "Gerben",
                                          url: "webcal://p175-caldav.icloud.com/published/xxxxx",
                        sdetweil @gerbenz
                        @gerbenz fetch every 60 seconds?
                        might be a spammer
                        how about try 5 mins
                        and comment out the position
                        Ext3 tries not to flash the screen w updates, you are probably running into that with so frequent updates and so many cals all at different times
                        you can look at the pm2’log and see timestamps when events are sent from each cal
                        • G Offline
                          gerbenz @sdetweil
                          updating the screen works good.
                          all calendars are working.
                          butt when i hide the standard calendar then te addon calandar lost the events and is empty
                            sdetweil @gerbenz
                            @gerbenz but thats not how it works! the calendar module just keeps sending even when no position is specified.
                            i have both setup on my system and it works perfectly
                            maybe 10releases ago modules w no
                            position would not be run
                            you should be able to see the broadcasts go out in the logs
                              @gerbenz show me the default calendar config whenExt3 is not working.
                              • G Offline
                                gerbenz @sdetweil
                                I changed nothing, only possition to unknown dor the standard calendar.
                                And then the addon calendar is show no events
                                  sdetweil @gerbenz
                                  @gerbenz no, NOT unknown, thats invalid, module will not be loaded (there will be an error in the log about this)
                                  just add
                                  to the front of the line w position on it to comment it out
                                  see mine that i posted earlier
                                  https://forum.magicmirror.builders/post/123049
                                  • G Offline
                                    gerbenz @sdetweil
                                    Okay i give it a try tomorrow.
                                    Thanks so far for youre help.
                                    I lett it know if it works.
                                    And do i need delete the adresses from the standard calendar or not?
                                      sdetweil @gerbenz
                                      @gerbenz address?
                                      look at my example
                                      • G Offline
                                        gerbenz @sdetweil
                                        I mean urls,
                                        I have in both the same urls for the calendar
                                          sdetweil @gerbenz
                                          @gerbenz i do not understand
                                          • G Offline
                                            gerbenz @sdetweil
                                            // for the position line was the solution.
                                            Thank u so much.
                                            Now only need the calendar what bigger and every schedule my wife kids and me different colors and bigger text.
                                            Only need to fins out how this works
