    Help with calendar
    27 Posts 2 Posters 9.5k Views 2 Watching
      sdetweil @gerbenz
      @gerbenz is this the latest MM release 2 .30
      did you put on the fix?
      see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
      • G
        gerbenz @sdetweil
        done,but not working. stays empty
          sdetweil @gerbenz
          @gerbenz can you show me output of
          git branch
          • G
            gerbenz @sdetweil
            • _fix_clipping
              master
              sdetweil @gerbenz
              @gerbenz ok, can you show the output of starting MagicMirror
              if you are using pm2 then
              pm2 logs --lines=xxx
              xxx is the number of most recent lines , default 15
              you may need more
              careful the cal broadcast message contains the full url so coukd expose personal info
              is it broadcasting events ?
              • G
                gerbenz @sdetweil
                only see events when i place orriginal callendar too,
                then the addon works good.
                wierd.
                  sdetweil @gerbenz
                  @gerbenz no idea
                  can you show the calendar configuration
                  (xxx out the urls but don’ change anything else)
                  you ARE just commenting out the calendar position line, right??
                  mine looks like this
                          classes: "page1",
                          //position: "top_left",
                          order: "*",
                          index: 1,
                          label: "instance 1",
                            broadcastPastEvents: true,
                            fetchInterval: 120000,
                            urgency: 0,
                            dateFormat: "Do.MMM, HH:mm",
                            fullDayEventDateFormat: "Do.MMM",
                            getRelative: 0,
                            hidePrivate: true,
                  • G
                    gerbenz @sdetweil
                    		module: "MMM-CalendarExt3",
                    		header: "Afspraken",
                    		position: "middle_center",
                                mode: "week",
                                weeksInView: 1,
                                weekIndex: 0,
                                instanceId: "basicCalendar",
                                locale: 'nl-NL',
                                maxEventLines: 5,
                                firstDayOfWeek: 0,
                    			startDayIndex: 0,
                                displayEndTime: true,
                    	        calendarSet: null,
                                refreshInterval: 60000,
                    		    fontsize: '30px',
                    		    eventHeight: '30px',
                    		    useWeather: false,
                    		    skipPassedEventToday: true,
                    					name: "werk stefnie",
                    					color: "red",
                    					url: "https://xxxx"
                                        url: "webcal://p181-caldav.icloud.com/published/xxxx",
                                        url: "webcal://p175-caldav.icloud.com/published/xxxx",
                      sdetweil @gerbenz
                      @gerbenz no, the default calendar, where the events come from
                      • G
                        gerbenz @sdetweil
                        			coloredText: true,
                                    broadcastPastEvents: false, // <= IMPORTANT to see past events
                        			fetchInterval: 1000 * 60 * 1,
                        					symbol: "werk stefnie",
                        					url: "xxxxx"
                                            symbol: "Stefanie",
                                            url: "webcal://p181-caldav.icloud.com/published/xxxxx",
                                            symbol: "Gezin",
                                            symbol: "Amber",
                                            symbol: "Luna",
                                            url: "webcal://p181-caldav.icloud.com/published/xxxxxx",
                                            symbol: "Gerben",
                                            url: "webcal://p175-caldav.icloud.com/published/xxxxx",
                          sdetweil @gerbenz
                          @gerbenz fetch every 60 seconds?
                          might be a spammer
                          how about try 5 mins
                          and comment out the position
                          Ext3 tries not to flash the screen w updates, you are probably running into that with so frequent updates and so many cals all at different times
                          you can look at the pm2’log and see timestamps when events are sent from each cal
                          • G
                            gerbenz @sdetweil
                            updating the screen works good.
                            all calendars are working.
                            butt when i hide the standard calendar then te addon calandar lost the events and is empty
                              sdetweil @gerbenz
                              @gerbenz but thats not how it works! the calendar module just keeps sending even when no position is specified.
                              i have both setup on my system and it works perfectly
                              maybe 10releases ago modules w no
                              position would not be run
                              you should be able to see the broadcasts go out in the logs
                                @gerbenz show me the default calendar config whenExt3 is not working.
                                • G
                                  gerbenz @sdetweil
                                  I changed nothing, only possition to unknown dor the standard calendar.
                                  And then the addon calendar is show no events
                                    sdetweil @gerbenz
                                    @gerbenz no, NOT unknown, thats invalid, module will not be loaded (there will be an error in the log about this)
                                    just add
                                    to the front of the line w position on it to comment it out
                                    see mine that i posted earlier
                                    https://forum.magicmirror.builders/post/123049
                                    • G
                                      gerbenz @sdetweil
                                      Okay i give it a try tomorrow.
                                      Thanks so far for youre help.
                                      I lett it know if it works.
                                      And do i need delete the adresses from the standard calendar or not?
                                        sdetweil @gerbenz
                                        @gerbenz address?
                                        look at my example
                                        • G
                                          gerbenz @sdetweil
                                          I mean urls,
                                          I have in both the same urls for the calendar
                                            sdetweil @gerbenz
                                            @gerbenz i do not understand
