    Camera intigration in your Mirror
    23 Posts 6 Posters 19.8k Views 11 Watching
    • yawnsY Offline
      yawns Moderator @lolobyte
      @lolobyte
      So are you happy with your NoIR camera behind the mirror glass?
      I am still unsure if I should buy one or if I skip this. On the other hand I am tempted to do so and integrate it into my mirror design right at the beginning.
      • lolobyteL Offline
        lolobyte
        @yawns
        Yes, sure. It solve many of my task build on my mirror.
        security cam with IR_LED’s for night-view possibilities, Motion detection, enabling/disabling mirror, facial recognition -> profile switcher.
        Maybe other options lather with other ideas from the community.
        • schlachtkreuzer6S Offline
          schlachtkreuzer6 @lolobyte
          @lolobyte I´m also interested to see the difference between the camera mounted in the frame or mounted behind the glass :) Is it possilbe to share some pics of the camera feed? :)
          lolobyteL 1 Reply Last reply Reply Quote 0
          • lolobyteL Offline
            lolobyte @schlachtkreuzer6
            @schlachtkreuzer6
            yes i do this how is said, lather when i’m back home.
              andrei20wks @lolobyte
              @lolobyte what about the v2 camera? the one with IR. does that work behind the mirror? have you tested it so far?
              • lolobyteL Offline
                lolobyte
                @schlachtkreuzer6 , @yawns , @andrei20wks , @reaper81
                hey Guys, here the desired pictures.
                Sorry, i forgot to remove the ip.
                Here are the pics again.
                With normal LED spots
                No Light and IR-Spot
                With IR-Light
                SvenSommerS 1 Reply Last reply Reply Quote 1
                • yawnsY Offline
                  yawns Moderator
                  Cool, thank you
                  • lolobyteL Offline
                    lolobyte
                    and here some pictures from the Mirror it self.
                    schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
                      @lolobyte WOW! that is great thank you very much! That helps me immensely :D
                      which camera version are you using? the Pi Noir v2? and which transmision has the mirror?
                      • SvenSommerS Offline
                        SvenSommer @lolobyte
                        @lolobyte
                        I’m amazed by the quality of your picture with IR-Light.
                        What kind of IR lamp are you using?
                        I’m also using a raspi noir camera and integraded like 30 IR-Leds within the mirror to get a brighter picture.
                        But always have problems with the face recognition. I assume it’s because the pictures used for comparing a black and white and for contrast reasons much darker.
                        Looking for some building inspiration?
                        Check out my large, thin and metal framed mirror on robstechlog.com.
                        Modules released:
                        MMM-GoogleAnalytics
                        MMM-GrafanaChart
                        MMM-GrafanaGauges
