    Camera intigration in your Mirror
    23 Posts 6 Posters 21.1k Views 11 Watching
      reaper81
      Hey everyone, I use the facerecognition module from paviro to switch between different userprofiles. The softwarepart is ready. Now I would like to build a large bathroom-mirror, preferably wihtout any visible frame.
      1. How do you integrate/hide your camera in the frame (if you use one)?
      2. Work the camera behind the mirror glas?
      • Y Offline
        yawns Moderator
        Hi, I did not test but some users report the NoIR camera works behind the mirror
        • L Offline
          lolobyte
          Yes pi noir works behind the glass.
          I’ts a bit darker but you can recognize the persons or other objects in the front of the mirror.
          My Mirror is on a wooden plate and i drilled a hole for the cam.
          Y A 2 Replies Last reply Reply Quote 0
            reaper81
            @lolobyte There are pictures of your frame (front and back)?
            • L Offline
              lolobyte @reaper81
              @reaper81
              I must search for some pictures at my phone or i send you new pictures lather in the evening!
              • Y Offline
                yawns Moderator @lolobyte
                @lolobyte
                So are you happy with your NoIR camera behind the mirror glass?
                I am still unsure if I should buy one or if I skip this. On the other hand I am tempted to do so and integrate it into my mirror design right at the beginning.
                • L Offline
                  lolobyte
                  @yawns
                  Yes, sure. It solve many of my task build on my mirror.
                  security cam with IR_LED’s for night-view possibilities, Motion detection, enabling/disabling mirror, facial recognition -> profile switcher.
                  Maybe other options lather with other ideas from the community.
                    schlachtkreuzer6 @lolobyte
                    @lolobyte I´m also interested to see the difference between the camera mounted in the frame or mounted behind the glass :) Is it possilbe to share some pics of the camera feed? :)
                    • L Offline
                      lolobyte @schlachtkreuzer6
                      @schlachtkreuzer6
                      yes i do this how is said, lather when i’m back home.
                        andrei20wks @lolobyte
                        @lolobyte what about the v2 camera? the one with IR. does that work behind the mirror? have you tested it so far?
                        • L Offline
                          lolobyte
                          @schlachtkreuzer6 , @yawns , @andrei20wks , @reaper81
                          hey Guys, here the desired pictures.
                          Sorry, i forgot to remove the ip.
                          Here are the pics again.
                          With normal LED spots
                          No Light and IR-Spot
                          With IR-Light
                          SvenSommerS 1 Reply Last reply Reply Quote 1
                          • Y Offline
                            yawns Moderator
                            Cool, thank you
                            • L Offline
                              lolobyte
                              and here some pictures from the Mirror it self.
                                @lolobyte WOW! that is great thank you very much! That helps me immensely :D
                                which camera version are you using? the Pi Noir v2? and which transmision has the mirror?
                                • SvenSommerS Offline
                                  SvenSommer @lolobyte
                                  @lolobyte
                                  I’m amazed by the quality of your picture with IR-Light.
                                  What kind of IR lamp are you using?
                                  I’m also using a raspi noir camera and integraded like 30 IR-Leds within the mirror to get a brighter picture.
                                  But always have problems with the face recognition. I assume it’s because the pictures used for comparing a black and white and for contrast reasons much darker.
                                  Looking for some building inspiration?
                                  Check out my large, thin and metal framed mirror on robstechlog.com.
                                  Modules released:
                                  MMM-GoogleAnalytics
                                  MMM-GrafanaChart
                                  MMM-GrafanaGauges
                                  • L Offline
                                    @schlachtkreuzer6
                                    https://www.conrad.de/de/raspberry-pi-kamera-gehaeusemodul-raspberry-pi-622959.html
                                    Full HD Video Auflösung mit 1080p
                                    Omnivision 5647 CMOS Bildsensor
                                    Maximale Framerate: 30 fps
                                    Integrierter IR-Filter
                                    5 Megapixel
                                      @lolobyte ah okay thats V1 so :) Thank you :)
                                      • L Offline
                                        lolobyte @SvenSommer
                                        @SvenSommer
                                        http://www.ebay.de/sch/sis.html?_nkw=Neu+Night+Vision+Infrared+LED+Board+Für+Rapsberry+Camera+Module+60+Array+3+Light&_id=181557695080&&_trksid=p2057872.m2749.l265
                                          reaper81
                                          @lolobyte Thanks also from my side. Is the IR-LED-board wired with the camera board? I see no wires for IR-powersupply to the Raspi in your picture. How do you enable/disable your mirror?
                                          Are the camera and the IR-LEDs visible from the other side, through the mirros. And last but not least: What’s the function of the red-white and the blue-white cable?
                                          • L Offline
                                            lolobyte
                                            Hello.
                                            My fist step was mounting the IR together with the cam behind the mirror.
                                            Was a disaster. From that point as the IR is starting, no really good picture was available.
                                            After that i mounted the cam without IR and the IR extra outside from the Mirror.
                                            The cam is not visible. The IR has his own power supply.
                                            The mirror is enabled and disabled by the cam.
                                            The blue/white cable is soldered on a switch (Taster) to be capable to make soft reset to the raspi mirror or to shutdown the raspi mirror. You can set the option in a python script.
                                            I planed to install one other switch for a hard reset. I have recognized this switch will also enable the mirror after a shutdown an i didn’t must pull the Raspberry power supply.
                                            The red/white one is also a switch (Taster) to enable the "Tagesschau in 100 sek.) with the MMM-Button and the MMM-Podcast modules.
