    Camera intigration in your Mirror
    23 Posts 6 Posters 20.4k Views 11 Watching
      andrei20wks @lolobyte
      @lolobyte what about the v2 camera? the one with IR. does that work behind the mirror? have you tested it so far?
      • lolobyteL Offline
        lolobyte
        @schlachtkreuzer6 , @yawns , @andrei20wks , @reaper81
        hey Guys, here the desired pictures.
        Sorry, i forgot to remove the ip.
        Here are the pics again.
        With normal LED spots
        No Light and IR-Spot
        With IR-Light
        SvenSommerS 1 Reply Last reply Reply Quote 1
        • yawnsY Offline
          yawns Moderator
          Cool, thank you
          • lolobyteL Offline
            lolobyte
            and here some pictures from the Mirror it self.
            schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
            • schlachtkreuzer6S Offline
              schlachtkreuzer6 @lolobyte
              @lolobyte WOW! that is great thank you very much! That helps me immensely :D
              which camera version are you using? the Pi Noir v2? and which transmision has the mirror?
              lolobyteL 1 Reply Last reply Reply Quote 0
              • SvenSommerS Offline
                SvenSommer @lolobyte
                @lolobyte
                I’m amazed by the quality of your picture with IR-Light.
                What kind of IR lamp are you using?
                I’m also using a raspi noir camera and integraded like 30 IR-Leds within the mirror to get a brighter picture.
                But always have problems with the face recognition. I assume it’s because the pictures used for comparing a black and white and for contrast reasons much darker.
                Looking for some building inspiration?
                Check out my large, thin and metal framed mirror on robstechlog.com.
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                • lolobyteL Offline
                  lolobyte @schlachtkreuzer6
                  @schlachtkreuzer6
                  https://www.conrad.de/de/raspberry-pi-kamera-gehaeusemodul-raspberry-pi-622959.html
                  Full HD Video Auflösung mit 1080p
                  Omnivision 5647 CMOS Bildsensor
                  Maximale Framerate: 30 fps
                  Integrierter IR-Filter
                  5 Megapixel
                  schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
                    @lolobyte ah okay thats V1 so :) Thank you :)
                    • lolobyteL Offline
                      lolobyte @SvenSommer
                      @SvenSommer
                      http://www.ebay.de/sch/sis.html?_nkw=Neu+Night+Vision+Infrared+LED+Board+Für+Rapsberry+Camera+Module+60+Array+3+Light&_id=181557695080&&_trksid=p2057872.m2749.l265
                        reaper81
                        @lolobyte Thanks also from my side. Is the IR-LED-board wired with the camera board? I see no wires for IR-powersupply to the Raspi in your picture. How do you enable/disable your mirror?
                        Are the camera and the IR-LEDs visible from the other side, through the mirros. And last but not least: What’s the function of the red-white and the blue-white cable?
                        • lolobyteL Offline
                          lolobyte
                          Hello.
                          My fist step was mounting the IR together with the cam behind the mirror.
                          Was a disaster. From that point as the IR is starting, no really good picture was available.
                          After that i mounted the cam without IR and the IR extra outside from the Mirror.
                          The cam is not visible. The IR has his own power supply.
                          The mirror is enabled and disabled by the cam.
                          The blue/white cable is soldered on a switch (Taster) to be capable to make soft reset to the raspi mirror or to shutdown the raspi mirror. You can set the option in a python script.
                          I planed to install one other switch for a hard reset. I have recognized this switch will also enable the mirror after a shutdown an i didn’t must pull the Raspberry power supply.
                          The red/white one is also a switch (Taster) to enable the "Tagesschau in 100 sek.) with the MMM-Button and the MMM-Podcast modules.
                            reaper81
                            Where do you hide the IR-LEDs? In the Frame? Is there a special Module to use the Camera to disable the mirror or do you just disable all modules, if no face is recognized?
                            • lolobyteL Offline
                              lolobyte @reaper81
                              @reaper81
                              No, the IR-Spot is completely at another place. This spot is mounted under the room cover above the mirror.
                              I use the cam SW to recognize any motion in the front of the mirror named MOTION-MMAL
                              Take a look for example at
                              https://embeddedday.com/projects/raspberry-pi/a-step-further/install-motion-mmal/
                              In the config file you can define how the SW has to work and which commands are executed by the SW.
                              Se also here in this Forum
                              https://forum.magicmirror.builders/topic/988/motion-detection-with-raspicam-non-module-version/
                                reaper81
                                Ok, sounds interesting. Can the Face-Recognitiontool and the MMAL-Motion share the camera? If I try to use the Camera with “raspistill” while the Face-Recog-Module is enable, I get an Error.
