Camera intigration in your Mirror
23 Posts 6 Posters 17.7k Views 11 Watching
    reaper81
    Hey everyone, I use the facerecognition module from paviro to switch between different userprofiles. The softwarepart is ready. Now I would like to build a large bathroom-mirror, preferably wihtout any visible frame.
    1. How do you integrate/hide your camera in the frame (if you use one)?
    2. Work the camera behind the mirror glas?
    • Y Offline
      yawns Moderator
      Hi, I did not test but some users report the NoIR camera works behind the mirror
      • L Offline
        lolobyte
        Yes pi noir works behind the glass.
        I’ts a bit darker but you can recognize the persons or other objects in the front of the mirror.
        My Mirror is on a wooden plate and i drilled a hole for the cam.
        Y A 2 Replies Last reply Jan 24, 2017, 12:49 PM Reply Quote 0
          reaper81
          @lolobyte There are pictures of your frame (front and back)?
          L 1 Reply Last reply Jan 24, 2017, 12:01 PM Reply Quote 0
          • L Offline
            lolobyte @reaper81
            @reaper81
            I must search for some pictures at my phone or i send you new pictures lather in the evening!
            S 1 Reply Last reply Jan 24, 2017, 2:23 PM Reply Quote 0
            • Y Offline
              yawns Moderator @lolobyte
              @lolobyte
              So are you happy with your NoIR camera behind the mirror glass?
              I am still unsure if I should buy one or if I skip this. On the other hand I am tempted to do so and integrate it into my mirror design right at the beginning.
              • L Offline
                lolobyte
                @yawns
                Yes, sure. It solve many of my task build on my mirror.
                security cam with IR_LED’s for night-view possibilities, Motion detection, enabling/disabling mirror, facial recognition -> profile switcher.
                Maybe other options lather with other ideas from the community.
                  schlachtkreuzer6 @lolobyte
                  @lolobyte I´m also interested to see the difference between the camera mounted in the frame or mounted behind the glass :) Is it possilbe to share some pics of the camera feed? :)
                  L 1 Reply Last reply Jan 24, 2017, 2:35 PM Reply Quote 0
                  • L Offline
                    lolobyte @schlachtkreuzer6
                    @schlachtkreuzer6
                    yes i do this how is said, lather when i’m back home.
                      andrei20wks @lolobyte
                      @lolobyte what about the v2 camera? the one with IR. does that work behind the mirror? have you tested it so far?
                      1 / 3
