birthdaylist - discontinued ?
Re: birthdaylist
Dear Sam (@sdetweil ),
I found your module some time ago but currently I can not.
Do you took the module “birthdaylist” offline?If NOT ( I would appreciate this because your module is really (!) nice):
I found a kind of strange “behaviour” - the module disappears over night (cannot identify at which time).
This is true for the connected monitor (HDMI to Raspberry Pi) as well as a connected headless VNC remote session.
With a “refresh” of the screen - e.g. triggered via a page reload in WebBrowser the module re-appears.I’ve searched the forum regarding a similar topic/issue but was not successful with this.
Found some “refresh” related parameters in “birthdaylist” module config - do they relate to an issue like this? (from my understanding NOT - you mentioned in documentation “only on fresh mirror startup” which is not the case here).If you have discontinued the module please ignore this.
Thanks, anyway!
Regards,
Ralf -
@rkorell I just pushed some fixes for the update cycle
give it a try…
git pull
to update -
@rkorell still present in same place
https://github.com/sdetweil/birthdaylist
i have not seen a report like this. will examine in the next couple days.
@sdetweil thanks.
Not found - for whatever reason, sorry.Warmest regards,
Ralf -
@rkorell hm, its public and i copy/pasted the url
i clicked the link i provided and got this
@rkorell i checked the code. and it stops displaying if it is marked hidden by some other module/core
do you use pages, module scheduler or any other thing like that
For sure my error!
Search routine wrong or something like this.
I’ve searched the modules list (both of them) and your sdetweil github page.none of them showing the module.
@rkorell not on modules list
you should have been able to look at my public repositoriesdid you get it with the link?
also if you have it,
git remote -vwill show you the link where it came from
not “really”. - pages definitely not used
I use MMM-Pir with cron - but this switches off the HDMI communication as far as I understand.
MMM-MagicMover moves but doesn’t hide.All other of the modules are showing, not hiding anything.
clock MMM-Profilepicture MMM-Moonphase MMM-Globe weather MMM-MyGarbage MMM-CalendarExt3Agenda MMM-Todoist birthdaylist :-) MMM-Systemstats MMM-Strava MMM-FRITZ-Box-Callmonitor-py3 MMM-Fuel MMM-NowPlayingOnSpotify MMM-SystemInfo MMM-EventHorizon newsfeed MMM-Pir two times calendar and finally weather all three for broadcasting to MMM-CalendarExt3Agenda , NOT visible.Regards,
Ralf -
@rkorell i signed out of github and went back to
my home page, clicked repositories
put in part of the name
@rkorell ok, just wanted to make sure nothing else was going on. github will only allow a user to pin 6 repos on their home page. i have at least 20 things i would pin
i also don’t see anything in your list that would be sending hide requests
i am driving all day today, so i may try to find a debug strategy
my idea is to install MMM-logging, which takes the messages from the browser side and adds them to the messages from the server/node helper side
and then i will give a debug message about which source called hide
but im not sure that will tell us
Dear Sam @sdetweil ,
no hurry.
It is definitely not urgent!Have a safe trip!
I’ve added MMM-logging but cannot see a difference …Warmest regards,
Ralf -
@rkorell have not added messages yet
:-) yes for sure.
But I had assumed that the already given output (from other modules as well) will change … -
@rkorell i added some debug for suspending, resuming, and getdom() if suspended
git pull to update
add debug:true
to the config optionsyou will see the output from mmm-logging
who calls before we suspend ?
@sdetweil said i added some debug for suspending, resuming, and getdom() if suspended
git pull to update
add debug:true
Dear Sam,
thanks a lot.pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull hint: Pulling without specifying how to reconcile divergent branches is hint: discouraged. You can squelch this message by running one of the following hint: commands sometime before your next pull: hint: hint: git config pull.rebase false # merge (the default strategy) hint: git config pull.rebase true # rebase hint: git config pull.ff only # fast-forward only hint: hint: You can replace "git config" with "git config --global" to set a default hint: preference for all repositories. You can also pass --rebase, --no-rebase, hint: or --ff-only on the command line to override the configured default per hint: invocation. remote: Enumerating objects: 5, done. remote: Counting objects: 100% (5/5), done. remote: Compressing objects: 100% (1/1), done. remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0) Unpacking objects: 100% (3/3), 419 bytes | 32.00 KiB/s, done. From https://github.com/sdetweil/birthdaylist 0fcfb8c..0c16aeb master -> origin/master Updating 0fcfb8c..0c16aeb Fast-forward birthdaylist.js | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)git pull has worked, debug is enabled.
Surprisingly enough today in the morning birthdaylist is NOT disappeared.
This exactly is the kind of error I like most: Unpredictable and not reproducable :-(Thanks anyway for your really great support (I’m pretty sure you do have more than enough other things to do …)
Checking the console output the “debug” switch works - a lot more of information is showing up.
Several module notifications are received from your module and broadcasted in log.
One single “conspicuousness”: undefined is in init! in line 48 of birthdaylist.js :(Log.log(this.name + " is in init!");)The “suspended” status (and therefore “hidden” (??) ) is reached several times - I guess caused by MMM-Pir ? - at least it corresponds definitely with turning off the screen by MMM-Pir.
Warmest regards,
Ralf -
The suspending call seems indeed to come from MMM-Pir.
But there is always a resuming…birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir birthdaylist.js:337 birthdaylist suspending birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather birthdaylist.js:108 birthdaylist received a module notification: CALL_DISCONNECTED from sender: MMM-FRITZ-Box-Callmonitor-py3 birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir birthdaylist.js:345 birthdaylist resuming birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather birthdaylist.js:337 birthdaylist suspending 2birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir birthdaylist.js:345 birthdaylist resumingI assume that we have to wait until birthdaylist disappears and then check the written logs afterwards if there is something different (I guess: NOT :-(. )
Regards,
Ralf -
@rkorell right we have to wait, thanks for the great info
ill look at the init time message
@rkorell notifications are broadcast. so every module gets every broadcast.
thats why you have to check if the broadcast is for you , but logging them all can give an idea what is going on.
if clock seconds was enabled you would see a notification for that too
@sdetweil clock seconds are enabled, as far as I know …
at least I haven’t found a parameter to enable/disable seconds
and second hand is shown …
