    birthdaylist - discontinued ?
    63 Posts 2 Posters 20.0k Views 2 Watching
      sdetweil @rkorell
      @rkorell i checked the code. and it stops displaying if it is marked hidden by some other module/core
      do you use pages, module scheduler or any other thing like that
        @sdetweil said
        i clicked the link i provided and got this
        For sure my error!
        Search routine wrong or something like this.
        I’ve searched the modules list (both of them) and your sdetweil github page.
        none of them showing the module.
          sdetweil @rkorell
          @rkorell not on modules list
          you should have been able to look at my public repositories
          did you get it with the link?
          also if you have it,
          git remote -v
          will show you the link where it came from
            not “really”. - pages definitely not used
            I use MMM-Pir with cron - but this switches off the HDMI communication as far as I understand.
            MMM-MagicMover moves but doesn’t hide.
            All other of the modules are showing, not hiding anything.
            clock
            MMM-Profilepicture
            MMM-Moonphase
            MMM-Globe
            weather
            MMM-MyGarbage
            MMM-CalendarExt3Agenda
            MMM-Todoist
            birthdaylist    :-)
            MMM-Systemstats
            MMM-Strava
            MMM-FRITZ-Box-Callmonitor-py3
            MMM-Fuel
            MMM-NowPlayingOnSpotify
            MMM-SystemInfo
            MMM-EventHorizon
            newsfeed
            MMM-Pir
            two times calendar
            and finally
            weather
            all three for broadcasting to MMM-CalendarExt3Agenda , NOT visible.
            Regards,
            Ralf
              @rkorell i signed out of github and went back to
              my home page, clicked repositories
              put in part of the name
                @sdetweil said in
                You’re FAR better than me in searching :-)
                I gave up at the front page .
                as I wrote: MY fault…
                Ralf
                  sdetweil @rkorell
                  @rkorell ok, just wanted to make sure nothing else was going on. github will only allow a user to pin 6 repos on their home page. i have at least 20 things i would pin
                  i also don’t see anything in your list that would be sending hide requests
                  i am driving all day today, so i may try to find a debug strategy
                  my idea is to install MMM-logging, which takes the messages from the browser side and adds them to the messages from the server/node helper side
                  and then i will give a debug message about which source called hide
                  but im not sure that will tell us
                    Dear Sam @sdetweil ,
                    no hurry.
                    It is definitely not urgent!
                    Have a safe trip!
                    I’ve added MMM-logging but cannot see a difference …
                    Warmest regards,
                    Ralf
                      sdetweil @rkorell
                      @rkorell have not added messages yet
                        :-) yes for sure.
                        But I had assumed that the already given output (from other modules as well) will change …
                          sdetweil @rkorell
                          @rkorell i added some debug for suspending, resuming, and getdom() if suspended
                          git pull to update
                          add debug:true
                          to the config options
                          you will see the output from mmm-logging
                          who calls before we suspend ?
                            @sdetweil said i added some debug for suspending, resuming, and getdom() if suspended
                            git pull to update
                            add debug:true
                            Dear Sam,
                            thanks a lot.
                            pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
                            hint: Pulling without specifying how to reconcile divergent branches is
                            hint: discouraged. You can squelch this message by running one of the following
                            hint: commands sometime before your next pull:
                            hint:
                            hint:   git config pull.rebase false  # merge (the default strategy)
                            hint:   git config pull.rebase true   # rebase
                            hint:   git config pull.ff only       # fast-forward only
                            hint:
                            hint: You can replace "git config" with "git config --global" to set a default
                            hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                            hint: or --ff-only on the command line to override the configured default per
                            hint: invocation.
                            remote: Enumerating objects: 5, done.
                            remote: Counting objects: 100% (5/5), done.
                            remote: Compressing objects: 100% (1/1), done.
                            remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
                            Unpacking objects: 100% (3/3), 419 bytes | 32.00 KiB/s, done.
                            From https://github.com/sdetweil/birthdaylist
                               0fcfb8c..0c16aeb  master     -> origin/master
                            Updating 0fcfb8c..0c16aeb
                            Fast-forward
                             birthdaylist.js | 11 +++++++++--
                             1 file changed, 9 insertions(+), 2 deletions(-)
                            git pull has worked, debug is enabled.
                            Surprisingly enough today in the morning birthdaylist is NOT disappeared.
                            This exactly is the kind of error I like most: Unpredictable and not reproducable :-(
                            Thanks anyway for your really great support (I’m pretty sure you do have more than enough other things to do …)
                            Checking the console output the “debug” switch works - a lot more of information is showing up.
                            Several module notifications are received from your module and broadcasted in log.
                            One single “conspicuousness”: undefined is in init! in line 48 of birthdaylist.js :
                            (Log.log(this.name + " is in init!");)
                            The “suspended” status (and therefore “hidden” (??) ) is reached several times - I guess caused by MMM-Pir ? - at least it corresponds definitely with turning off the screen by MMM-Pir.
                            Warmest regards,
                            Ralf
                              rkorell Module Developer @rkorell
                              The suspending call seems indeed to come from MMM-Pir.
                              But there is always a resuming…
                              birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                              birthdaylist.js:337 birthdaylist suspending
                              birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather
                              birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather
                              birthdaylist.js:108 birthdaylist received a module notification: CALL_DISCONNECTED from sender: MMM-FRITZ-Box-Callmonitor-py3
                              birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                              birthdaylist.js:345 birthdaylist resuming
                              2birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                              I assume that we have to wait until birthdaylist disappears and then check the written logs afterwards if there is something different (I guess: NOT :-(. )
                              Regards,
                              Ralf
                                sdetweil @rkorell
                                @rkorell right we have to wait, thanks for the great info
                                ill look at the init time message
                                  sdetweil @rkorell
                                  @rkorell notifications are broadcast. so every module gets every broadcast.
                                  thats why you have to check if the broadcast is for you , but logging them all can give an idea what is going on.
                                  if clock seconds was enabled you would see a notification for that too
                                    @sdetweil clock seconds are enabled, as far as I know …
                                    at least I haven’t found a parameter to enable/disable seconds
                                    and second hand is shown …
                                      sdetweil @rkorell
                                      @rkorell you are using the analog clock, not digital
                                      this for digital
                                      displaySeconds	Display seconds.
                                      Possible values: true or false
                                      Default value: true
                                      and I didn’t see this change
                                      sendNotifications	Enable notifications for elapsed time. Used to be always done send prio to v2.23
                                      Possible values: true, or false
                                      Default value: false
                                        @sdetweil Yeah…
                                        You’re right.
                                        I’ve set this - my type of clock is set to “both” because I like sunset and day of week information.
                                        This causes an error in your module…
                                        birthdaylist.js:398 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'startsWith')
                                            at Class.getBD_DAY_from_Date (birthdaylist.js:398:9)
                                            at Class.getDom (birthdaylist.js:462:154)
                                            at main.js:132:35
                                            at new Promise (<anonymous>)
                                            at updateDom (main.js:112:10)
                                            at Object.updateDom (main.js:669:4)
                                            at Class.updateDom (module.js:341:6)
                                            at Class.socketNotificationReceived (birthdaylist.js:328:9)
                                            at module.js:240:9
                                            at Socket.<anonymous> (socketclient.js:32:4)
                                        Not sure if this corresponds with the displaySeconds parameter but seen this error first time…
                                        Regards,
                                        Ralf
                                        R S 2 Replies Last reply Reply Quote 0
                                          No, obviously NOT…
                                          I’ve now added “sendNotifications: true” to config.
                                          Mirror reloads and your module starts without this error message.
                                            sdetweil @rkorell
                                            @rkorell can i see your birthdaylist config
                                            and the date portion of one birthday from the list, which order the date info is in
                                            and this error is trying to check if tye month part starts w a 0
                                            and i figure out which date separator you used
                                            /, or :, or just not ,
                                            and then i split the date with the separator i discovered, they all HAVE to be the same separator and order
                                            • 1 / 4
