    birthdaylist - discontinued ?
    63 Posts 2 Posters 16.6k Views 2 Watching
      rkorell Module Developer
      Re: birthdaylist
      Dear Sam (@sdetweil ),
      I found your module some time ago but currently I can not.
      Do you took the module “birthdaylist” offline?
      If NOT ( I would appreciate this because your module is really (!) nice):
      I found a kind of strange “behaviour” - the module disappears over night (cannot identify at which time).
      This is true for the connected monitor (HDMI to Raspberry Pi) as well as a connected headless VNC remote session.
      With a “refresh” of the screen - e.g. triggered via a page reload in WebBrowser the module re-appears.
      I’ve searched the forum regarding a similar topic/issue but was not successful with this.
      Found some “refresh” related parameters in “birthdaylist” module config - do they relate to an issue like this? (from my understanding NOT - you mentioned in documentation “only on fresh mirror startup” which is not the case here).
      If you have discontinued the module please ignore this.
      Thanks, anyway!
      Regards,
      Ralf
        sdetweil @rkorell
        @rkorell I just pushed some fixes for the update cycle
        give it a try…
        git pull
        to update
          sdetweil @rkorell
          @rkorell still present in same place
          https://github.com/sdetweil/birthdaylist
          i have not seen a report like this. will examine in the next couple days.
            @sdetweil thanks.
            Not found - for whatever reason, sorry.
            Warmest regards,
            Ralf
              sdetweil @rkorell
              @rkorell hm, its public and i copy/pasted the url
              i clicked the link i provided and got this
                sdetweil @rkorell
                @rkorell i checked the code. and it stops displaying if it is marked hidden by some other module/core
                do you use pages, module scheduler or any other thing like that
                  For sure my error!
                  Search routine wrong or something like this.
                  I’ve searched the modules list (both of them) and your sdetweil github page.
                  none of them showing the module.
                    sdetweil @rkorell
                    @rkorell not on modules list
                    you should have been able to look at my public repositories
                    did you get it with the link?
                    also if you have it,
                    git remote -v
                    will show you the link where it came from
                      not “really”. - pages definitely not used
                      I use MMM-Pir with cron - but this switches off the HDMI communication as far as I understand.
                      MMM-MagicMover moves but doesn’t hide.
                      All other of the modules are showing, not hiding anything.
                      clock
                      MMM-Profilepicture
                      MMM-Moonphase
                      MMM-Globe
                      weather
                      MMM-MyGarbage
                      MMM-CalendarExt3Agenda
                      MMM-Todoist
                      birthdaylist    :-)
                      MMM-Systemstats
                      MMM-Strava
                      MMM-FRITZ-Box-Callmonitor-py3
                      MMM-Fuel
                      MMM-NowPlayingOnSpotify
                      MMM-SystemInfo
                      MMM-EventHorizon
                      newsfeed
                      MMM-Pir
                      two times calendar
                      and finally
                      weather
                      all three for broadcasting to MMM-CalendarExt3Agenda , NOT visible.
                      Regards,
                      Ralf
                        @rkorell i signed out of github and went back to
                        my home page, clicked repositories
                        put in part of the name
                          @sdetweil said in
                          You’re FAR better than me in searching :-)
                          I gave up at the front page .
                          as I wrote: MY fault…
                          Ralf
                            sdetweil @rkorell
                            @rkorell ok, just wanted to make sure nothing else was going on. github will only allow a user to pin 6 repos on their home page. i have at least 20 things i would pin
                            i also don’t see anything in your list that would be sending hide requests
                            i am driving all day today, so i may try to find a debug strategy
                            my idea is to install MMM-logging, which takes the messages from the browser side and adds them to the messages from the server/node helper side
                            and then i will give a debug message about which source called hide
                            but im not sure that will tell us
                              Dear Sam @sdetweil ,
                              no hurry.
                              It is definitely not urgent!
                              Have a safe trip!
                              I’ve added MMM-logging but cannot see a difference …
                              Warmest regards,
                              Ralf
                                sdetweil @rkorell
                                @rkorell have not added messages yet
                                  :-) yes for sure.
                                  But I had assumed that the already given output (from other modules as well) will change …
                                    sdetweil @rkorell
                                    @rkorell i added some debug for suspending, resuming, and getdom() if suspended
                                    git pull to update
                                    add debug:true
                                    to the config options
                                    you will see the output from mmm-logging
                                    who calls before we suspend ?
                                      @sdetweil said i added some debug for suspending, resuming, and getdom() if suspended
                                      git pull to update
                                      add debug:true
                                      Dear Sam,
                                      thanks a lot.
                                      pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
                                      hint: Pulling without specifying how to reconcile divergent branches is
                                      hint: discouraged. You can squelch this message by running one of the following
                                      hint: commands sometime before your next pull:
                                      hint:
                                      hint:   git config pull.rebase false  # merge (the default strategy)
                                      hint:   git config pull.rebase true   # rebase
                                      hint:   git config pull.ff only       # fast-forward only
                                      hint:
                                      hint: You can replace "git config" with "git config --global" to set a default
                                      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                                      hint: or --ff-only on the command line to override the configured default per
                                      hint: invocation.
                                      remote: Enumerating objects: 5, done.
                                      remote: Counting objects: 100% (5/5), done.
                                      remote: Compressing objects: 100% (1/1), done.
                                      remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
                                      Unpacking objects: 100% (3/3), 419 bytes | 32.00 KiB/s, done.
                                      From https://github.com/sdetweil/birthdaylist
                                         0fcfb8c..0c16aeb  master     -> origin/master
                                      Updating 0fcfb8c..0c16aeb
                                      Fast-forward
                                       birthdaylist.js | 11 +++++++++--
                                       1 file changed, 9 insertions(+), 2 deletions(-)
                                      git pull has worked, debug is enabled.
                                      Surprisingly enough today in the morning birthdaylist is NOT disappeared.
                                      This exactly is the kind of error I like most: Unpredictable and not reproducable :-(
                                      Thanks anyway for your really great support (I’m pretty sure you do have more than enough other things to do …)
                                      Checking the console output the “debug” switch works - a lot more of information is showing up.
                                      Several module notifications are received from your module and broadcasted in log.
                                      One single “conspicuousness”: undefined is in init! in line 48 of birthdaylist.js :
                                      (Log.log(this.name + " is in init!");)
                                      The “suspended” status (and therefore “hidden” (??) ) is reached several times - I guess caused by MMM-Pir ? - at least it corresponds definitely with turning off the screen by MMM-Pir.
                                      Warmest regards,
                                      Ralf
                                        rkorell Module Developer @rkorell
                                        The suspending call seems indeed to come from MMM-Pir.
                                        But there is always a resuming…
                                        birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                                        birthdaylist.js:337 birthdaylist suspending
                                        birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather
                                        birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather
                                        birthdaylist.js:108 birthdaylist received a module notification: CALL_DISCONNECTED from sender: MMM-FRITZ-Box-Callmonitor-py3
                                        birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                                        birthdaylist.js:345 birthdaylist resuming
                                        2birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                                        I assume that we have to wait until birthdaylist disappears and then check the written logs afterwards if there is something different (I guess: NOT :-(. )
                                        Regards,
                                        Ralf
                                          sdetweil @rkorell
                                          @rkorell right we have to wait, thanks for the great info
                                          ill look at the init time message
                                            sdetweil @rkorell
                                            @rkorell notifications are broadcast. so every module gets every broadcast.
                                            thats why you have to check if the broadcast is for you , but logging them all can give an idea what is going on.
                                            if clock seconds was enabled you would see a notification for that too
                                              @sdetweil clock seconds are enabled, as far as I know …
                                              at least I haven’t found a parameter to enable/disable seconds
                                              and second hand is shown …
                                              • 1 / 4
