    birthdaylist - discontinued ?
    63 Posts 2 Posters 18.6k Views 2 Watching
      sdetweil @rkorell
      @rkorell still present in same place
      https://github.com/sdetweil/birthdaylist
      i have not seen a report like this. will examine in the next couple days.
        @sdetweil thanks.
        Not found - for whatever reason, sorry.
        Warmest regards,
        Ralf
          sdetweil @rkorell
          @rkorell hm, its public and i copy/pasted the url
          i clicked the link i provided and got this
            sdetweil @rkorell
            @rkorell i checked the code. and it stops displaying if it is marked hidden by some other module/core
            do you use pages, module scheduler or any other thing like that
              For sure my error!
              Search routine wrong or something like this.
              I’ve searched the modules list (both of them) and your sdetweil github page.
              none of them showing the module.
                sdetweil @rkorell
                @rkorell not on modules list
                you should have been able to look at my public repositories
                did you get it with the link?
                also if you have it,
                git remote -v
                will show you the link where it came from
                  not “really”. - pages definitely not used
                  I use MMM-Pir with cron - but this switches off the HDMI communication as far as I understand.
                  MMM-MagicMover moves but doesn’t hide.
                  All other of the modules are showing, not hiding anything.
                  clock
                  MMM-Profilepicture
                  MMM-Moonphase
                  MMM-Globe
                  weather
                  MMM-MyGarbage
                  MMM-CalendarExt3Agenda
                  MMM-Todoist
                  birthdaylist    :-)
                  MMM-Systemstats
                  MMM-Strava
                  MMM-FRITZ-Box-Callmonitor-py3
                  MMM-Fuel
                  MMM-NowPlayingOnSpotify
                  MMM-SystemInfo
                  MMM-EventHorizon
                  newsfeed
                  MMM-Pir
                  two times calendar
                  and finally
                  weather
                  all three for broadcasting to MMM-CalendarExt3Agenda , NOT visible.
                  Regards,
                  Ralf
                    @rkorell i signed out of github and went back to
                    my home page, clicked repositories
                    put in part of the name
                      @sdetweil said in
                      You’re FAR better than me in searching :-)
                      I gave up at the front page .
                      as I wrote: MY fault…
                      Ralf
                        sdetweil @rkorell
                        @rkorell ok, just wanted to make sure nothing else was going on. github will only allow a user to pin 6 repos on their home page. i have at least 20 things i would pin
                        i also don’t see anything in your list that would be sending hide requests
                        i am driving all day today, so i may try to find a debug strategy
                        my idea is to install MMM-logging, which takes the messages from the browser side and adds them to the messages from the server/node helper side
                        and then i will give a debug message about which source called hide
                        but im not sure that will tell us
                          Dear Sam @sdetweil ,
                          no hurry.
                          It is definitely not urgent!
                          Have a safe trip!
                          I’ve added MMM-logging but cannot see a difference …
                          Warmest regards,
                          Ralf
                            sdetweil @rkorell
                            @rkorell have not added messages yet
                              :-) yes for sure.
                              But I had assumed that the already given output (from other modules as well) will change …
                                sdetweil @rkorell
                                @rkorell i added some debug for suspending, resuming, and getdom() if suspended
                                git pull to update
                                add debug:true
                                to the config options
                                you will see the output from mmm-logging
                                who calls before we suspend ?
                                  @sdetweil said i added some debug for suspending, resuming, and getdom() if suspended
                                  git pull to update
                                  add debug:true
                                  Dear Sam,
                                  thanks a lot.
                                  pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
                                  hint: Pulling without specifying how to reconcile divergent branches is
                                  hint: discouraged. You can squelch this message by running one of the following
                                  hint: commands sometime before your next pull:
                                  hint:
                                  hint:   git config pull.rebase false  # merge (the default strategy)
                                  hint:   git config pull.rebase true   # rebase
                                  hint:   git config pull.ff only       # fast-forward only
                                  hint:
                                  hint: You can replace "git config" with "git config --global" to set a default
                                  hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                                  hint: or --ff-only on the command line to override the configured default per
                                  hint: invocation.
                                  remote: Enumerating objects: 5, done.
                                  remote: Counting objects: 100% (5/5), done.
                                  remote: Compressing objects: 100% (1/1), done.
                                  remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
                                  Unpacking objects: 100% (3/3), 419 bytes | 32.00 KiB/s, done.
                                  From https://github.com/sdetweil/birthdaylist
                                     0fcfb8c..0c16aeb  master     -> origin/master
                                  Updating 0fcfb8c..0c16aeb
                                  Fast-forward
                                   birthdaylist.js | 11 +++++++++--
                                   1 file changed, 9 insertions(+), 2 deletions(-)
                                  git pull has worked, debug is enabled.
                                  Surprisingly enough today in the morning birthdaylist is NOT disappeared.
                                  This exactly is the kind of error I like most: Unpredictable and not reproducable :-(
                                  Thanks anyway for your really great support (I’m pretty sure you do have more than enough other things to do …)
                                  Checking the console output the “debug” switch works - a lot more of information is showing up.
                                  Several module notifications are received from your module and broadcasted in log.
                                  One single “conspicuousness”: undefined is in init! in line 48 of birthdaylist.js :
                                  (Log.log(this.name + " is in init!");)
                                  The “suspended” status (and therefore “hidden” (??) ) is reached several times - I guess caused by MMM-Pir ? - at least it corresponds definitely with turning off the screen by MMM-Pir.
                                  Warmest regards,
                                  Ralf
                                    rkorell Module Developer @rkorell
                                    The suspending call seems indeed to come from MMM-Pir.
                                    But there is always a resuming…
                                    birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                                    birthdaylist.js:337 birthdaylist suspending
                                    birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather
                                    birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather
                                    birthdaylist.js:108 birthdaylist received a module notification: CALL_DISCONNECTED from sender: MMM-FRITZ-Box-Callmonitor-py3
                                    birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                                    birthdaylist.js:345 birthdaylist resuming
                                    2birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
                                    I assume that we have to wait until birthdaylist disappears and then check the written logs afterwards if there is something different (I guess: NOT :-(. )
                                    Regards,
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell right we have to wait, thanks for the great info
                                      ill look at the init time message
                                        sdetweil @rkorell
                                        @rkorell notifications are broadcast. so every module gets every broadcast.
                                        thats why you have to check if the broadcast is for you , but logging them all can give an idea what is going on.
                                        if clock seconds was enabled you would see a notification for that too
                                          @sdetweil clock seconds are enabled, as far as I know …
                                          at least I haven’t found a parameter to enable/disable seconds
                                          and second hand is shown …
                                            sdetweil @rkorell
                                            @rkorell you are using the analog clock, not digital
                                            this for digital
                                            displaySeconds	Display seconds.
                                            Possible values: true or false
                                            Default value: true
                                            and I didn’t see this change
                                            sendNotifications	Enable notifications for elapsed time. Used to be always done send prio to v2.23
                                            Possible values: true, or false
                                            Default value: false
                                            • 1 / 4
