MMM-FRITZ-Box-Callmonitor-py3 unknown_error
I have reinstalled my Raspberry. Unfortunately MMM-FRITZ-Box-Callmonitor-py3 no longer works. The module says unknown error. It does not load the phone book. The settings were taken from the old system (it worked there)
Can anyone help me?
My data:
RaspberryPi4 bookworm
Packages are updated
module: ‘MMM-FRITZ-Box-Callmonitor-py3’,
position: ‘top_right’,
header: “Letzter Anruf”,
fritzIP: “192.168.188.1”,
fritzPort: ‘1012’,
username: “name”,
password: “pass”,
showContactsStatus: true,
vCard: false,
debug: true,
maximumCallDistance: 60
New attempt: I did not install fritzconnection via pipx, but with pip. I had to turn off the “externally managed” message beforehand.
The phone book is now being read.
The call is not yet displayed. The list is only displayed after a restart. -
sorry bad post
@wuermchen
Hi.
I guess it SHOULD work - at least it works for me at current github status (approx. 2-3 old - not sure what you have archived).
At my own initial setup I got the same error message and after some researches it was caused by refused authentication on the fritzbox side.So I would start at this point initially - not at module side.
My first attempt was login without password (as possible for console) - this doesn’t work.
I’ve created a separate user on AVM side with full access to phonebook and so on and this worked from scratch.
I see that you have an explicite user/pw as well - so I would double check if this user exists on AVM side and do have the right access privileges.For being sure I would recommend to delete all parameters from configuration you do not really need and experiment with the base parameters.
E.g. you have set the Port number - at default - I would delete this one.I’m not sure if you are aware but you can find the documentation of the module in your module folder as well - you do not need the - closed - github entry.
“README.md” is the file.Good luck!
Ralf -
@sdetweil said in MMM-FRITZ-Box-Callmonitor-py3 unknown_error:
i do not know how the module works but i suspect this
https://forum.magicmirror.builders/post/123380Where do you see the connection? The maintainer of MMM-FRITZ-Box-Callmonitor-py3 is drtorchwood.
@KristjanESPERANTO bad post, didn’t check source, he had one too
- I tried a new config with default values, without success
- Reinstalling and turning off the other modules, without success
{ module: 'MMM-FRITZ-Box-Callmonitor-py3', position: 'top_right', header: "Recent calls", config: { password: "pass", username: "user", fritzIP: "192.168.188.1", showContactsStatus: true, vCard: false } },npm start has errors
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.30.0 start > npm run start:x11 > magicmirror@2.30.0 start:x11 > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [2025-01-31 18:47:25.363] [LOG] Starting MagicMirror: v2.30.0 [2025-01-31 18:47:25.394] [LOG] Loading config ... [2025-01-31 18:47:25.398] [LOG] config template file not exists, no envsubst [2025-01-31 18:47:26.001] [INFO] Checking config file /home/pi/MagicMirror/config/config.js ... [2025-01-31 18:47:26.140] [INFO] Your configuration file doesn't contain syntax errors :) [2025-01-31 18:47:26.142] [INFO] Checking modules structure configuration ... [2025-01-31 18:47:26.269] [INFO] Your modules structure configuration doesn't contain errors :) [2025-01-31 18:47:26.272] [LOG] Loading module helpers ... [2025-01-31 18:47:26.275] [LOG] No helper found for module: alert. [2025-01-31 18:47:26.283] [LOG] Initializing new module helper ... [2025-01-31 18:47:26.284] [LOG] Module helper loaded: updatenotification [2025-01-31 18:47:26.285] [LOG] No helper found for module: clock. [2025-01-31 18:47:26.286] [LOG] No helper found for module: compliments. [2025-01-31 18:47:26.461] [LOG] Initializing new module helper ... [2025-01-31 18:47:26.462] [LOG] Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3 [2025-01-31 18:47:26.463] [LOG] All module helpers loaded. [2025-01-31 18:47:26.473] [LOG] Starting server on port 8080 ... [2025-01-31 18:47:27.320] [LOG] Server started ... [2025-01-31 18:47:27.322] [LOG] Connecting socket for: updatenotification [2025-01-31 18:47:27.324] [LOG] Starting module helper: updatenotification [2025-01-31 18:47:27.325] [LOG] Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3 [2025-01-31 18:47:27.327] [LOG] Starting module: MMM-FRITZ-Box-Callmonitor-py3 [2025-01-31 18:47:27.329] [LOG] Sockets connected & modules started ... [2025-01-31 18:47:28.262] [LOG] Launching application. [2025-01-31 18:47:29.866] [INFO] System information: ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8 ### VERSIONS: electron: 34.0.2; used node: 20.18.1; installed node: 20.18.1; npm: 10.9.2; pm2: 5.4.3 ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined [96922:0131/184730.026384:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.026830:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.027196:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.027321:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.027499:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.027625:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.027798:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.027902:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.028061:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.028171:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.028341:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.028445:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.028602:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.028704:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.030069:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.030275:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.030478:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.030618:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.030807:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.030950:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.031137:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.031248:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.031471:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.031751:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.031946:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.032053:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.032219:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [96922:0131/184730.032326:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2) [2025-01-31 18:47:31.626] [LOG] Received config for MMM-FRITZ-Box-Callmonitor-py3 [2025-01-31 18:47:31.631] [LOG] MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls. [2025-01-31 18:47:31.680] [INFO] updatenotification: Updater Class Loaded! [2025-01-31 18:47:31.682] [INFO] updatenotification: Checking PM2 using... [2025-01-31 18:47:31.684] [INFO] updatenotification: [PM2] You are not using pm2 [2025-01-31 18:47:31.689] [INFO] Checking git for module: MMM-FRITZ-Box-Callmonitor-py3 [2025-01-31 18:47:31.730] [INFO] Checking git for module: MagicMirror :ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2) [2025-01-31 18:48:11.502] [INFO] updatenotification: Updater Class Loaded! [2025-01-31 18:48:11.503] [INFO] updatenotification: Checking PM2 using... [2025-01-31 18:48:11.503] [INFO] updatenotification: [PM2] You are not using pm2 -
@wuermchen
The log info from MMM-FRITZ-Box-Callmonitor seems to be O.K. …
Regards,
Ralf -
I reinstalled Fritzcallmonitor. The error still exists.
During installation there were changes compared to the template:python-dev = Doch die folgenden Pakete ersetzen es: python-dev-is-python3 sudo pip install fritzconnection error: externally-managed-environment sudo pipx install fritzconnectionDoes anyone have any idea what I’m doing wrong?
@wuermchen does the pip setup require a virtual environment?
which you have to enable again before launching MagicMirror -
I installed pipx before and then “sudo pipx install fritzconnection” so I don’t need a virtual environment
@wuermchen yes, but it failed
When I try to reinstall fritzconnection I get the following message:
'fritzconnection' already seems to be installed. Not modifying existing installation in '/root/.local/pipx/venvs/fritzconnection'. Pass '--force' to force installation. -
Finally! After restarting it works.
S sdetweil has marked this topic as solved on
@wuermchen Great, congratulations.
Ralf
