    MMM-FRITZ-Box-Callmonitor-py3 unknown_error
    15 Posts 4 Posters 5.7k Views 4 Watching
      rkorell Module Developer @wuermchen
      @wuermchen
      Hi.
      I guess it SHOULD work - at least it works for me at current github status (approx. 2-3 old - not sure what you have archived).
      At my own initial setup I got the same error message and after some researches it was caused by refused authentication on the fritzbox side.
      So I would start at this point initially - not at module side.
      My first attempt was login without password (as possible for console) - this doesn’t work.
      I’ve created a separate user on AVM side with full access to phonebook and so on and this worked from scratch.
      I see that you have an explicite user/pw as well - so I would double check if this user exists on AVM side and do have the right access privileges.
      For being sure I would recommend to delete all parameters from configuration you do not really need and experiment with the base parameters.
      E.g. you have set the Port number - at default - I would delete this one.
      I’m not sure if you are aware but you can find the documentation of the module in your module folder as well - you do not need the - closed - github entry.
      “README.md” is the file.
      Good luck!
      Ralf
      • KristjanESPERANTOK
        @sdetweil said in MMM-FRITZ-Box-Callmonitor-py3 unknown_error:
        i do not know how the module works but i suspect this
        https://forum.magicmirror.builders/post/123380
        Where do you see the connection? The maintainer of MMM-FRITZ-Box-Callmonitor-py3 is drtorchwood.
          sdetweil @KristjanESPERANTO
          @KristjanESPERANTO bad post, didn’t check source, he had one too
          • W
            wuermchen
            • I tried a new config with default values, without success
            • Reinstalling and turning off the other modules, without success
            		module: 'MMM-FRITZ-Box-Callmonitor-py3',
            		position: 'top_right',
            		header: "Recent calls",
            			password: "pass",
            			username: "user",
            			fritzIP: "192.168.188.1",
            			showContactsStatus: true,
            			vCard: false
            npm start has errors
            > magicmirror@2.30.0 start
            > npm run start:x11
            > magicmirror@2.30.0 start:x11
            [2025-01-31 18:47:25.363] [LOG]   Starting MagicMirror: v2.30.0
            [2025-01-31 18:47:25.394] [LOG]   Loading config ...
            [2025-01-31 18:47:25.398] [LOG]   config template file not exists, no envsubst
            [2025-01-31 18:47:26.001] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
            [2025-01-31 18:47:26.140] [INFO]  Your configuration file doesn't contain syntax errors :)
            [2025-01-31 18:47:26.142] [INFO]  Checking modules structure configuration ...
            [2025-01-31 18:47:26.269] [INFO]  Your modules structure configuration doesn't contain errors :)
            [2025-01-31 18:47:26.272] [LOG]   Loading module helpers ...
            [2025-01-31 18:47:26.275] [LOG]   No helper found for module: alert.
            [2025-01-31 18:47:26.283] [LOG]   Initializing new module helper ...
            [2025-01-31 18:47:26.284] [LOG]   Module helper loaded: updatenotification
            [2025-01-31 18:47:26.285] [LOG]   No helper found for module: clock.
            [2025-01-31 18:47:26.286] [LOG]   No helper found for module: compliments.
            [2025-01-31 18:47:26.461] [LOG]   Initializing new module helper ...
            [2025-01-31 18:47:26.462] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
            [2025-01-31 18:47:26.463] [LOG]   All module helpers loaded.
            [2025-01-31 18:47:26.473] [LOG]   Starting server on port 8080 ...
            [2025-01-31 18:47:27.320] [LOG]   Server started ...
            [2025-01-31 18:47:27.322] [LOG]   Connecting socket for: updatenotification
            [2025-01-31 18:47:27.324] [LOG]   Starting module helper: updatenotification
            [2025-01-31 18:47:27.325] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
            [2025-01-31 18:47:27.327] [LOG]   Starting module: MMM-FRITZ-Box-Callmonitor-py3
            [2025-01-31 18:47:27.329] [LOG]   Sockets connected & modules started ...
            [2025-01-31 18:47:28.262] [LOG]   Launching application.
            [2025-01-31 18:47:29.866] [INFO]  System information:
            ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false
            ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
            ### VERSIONS: electron: 34.0.2; used node: 20.18.1; installed node: 20.18.1; npm: 10.9.2; pm2: 5.4.3
            ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
            [96922:0131/184730.026384:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.026830:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.027196:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.027321:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.027499:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.027625:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.027798:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.027902:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.028061:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.028171:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.028341:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.028445:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.028602:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.028704:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.030069:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.030275:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.030478:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.030618:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.030807:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.030950:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.031137:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.031248:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.031471:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.031751:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.031946:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.032053:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.032219:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
            [96922:0131/184730.032326:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
            [2025-01-31 18:47:31.626] [LOG]   Received config for MMM-FRITZ-Box-Callmonitor-py3
            [2025-01-31 18:47:31.631] [LOG]   MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls.
            [2025-01-31 18:47:31.680] [INFO]  updatenotification: Updater Class Loaded!
            [2025-01-31 18:47:31.682] [INFO]  updatenotification: Checking PM2 using...
            [2025-01-31 18:47:31.684] [INFO]  updatenotification: [PM2] You are not using pm2
            [2025-01-31 18:47:31.689] [INFO]  Checking git for module: MMM-FRITZ-Box-Callmonitor-py3
            [2025-01-31 18:47:31.730] [INFO]  Checking git for module: MagicMirror
            [2025-01-31 18:48:11.502] [INFO]  updatenotification: Updater Class Loaded!
            [2025-01-31 18:48:11.503] [INFO]  updatenotification: Checking PM2 using...
            [2025-01-31 18:48:11.503] [INFO]  updatenotification: [PM2] You are not using pm2
              @wuermchen
              The log info from MMM-FRITZ-Box-Callmonitor seems to be O.K. …
              Regards,
              Ralf
              • W
                wuermchen
                I reinstalled Fritzcallmonitor. The error still exists.
                During installation there were changes compared to the template:
                python-dev = Doch die folgenden Pakete ersetzen es: python-dev-is-python3
                sudo pip install fritzconnection  error: externally-managed-environment   sudo pipx install fritzconnection
                Does anyone have any idea what I’m doing wrong?
                  sdetweil @wuermchen
                  @wuermchen does the pip setup require a virtual environment?
                  which you have to enable again before launching MagicMirror
                  • W
                    wuermchen
                    I installed pipx before and then “sudo pipx install fritzconnection” so I don’t need a virtual environment
                      sdetweil @wuermchen
                      @wuermchen yes, but it failed
                      • W
                        wuermchen
                        When I try to reinstall fritzconnection I get the following message:
                        'fritzconnection' already seems to be installed. Not modifying existing
                        installation in '/root/.local/pipx/venvs/fritzconnection'. Pass '--force' to
                        force installation.
                        • W
                          wuermchen
                          New attempt: I did not install fritzconnection via pipx, but with pip. I had to turn off the “externally managed” message beforehand.
                          The phone book is now being read.
                          The call is not yet displayed. The list is only displayed after a restart.
                          • W
                            wuermchen
                            Finally! After restarting it works.
                              @wuermchen Great, congratulations.
                              Ralf
