    MMM-FRITZ-Box-Callmonitor-py3 unknown_error
    15 Posts 4 Posters 3.0k Views 4 Watching
    • W Offline
      wuermchen
      I have reinstalled my Raspberry. Unfortunately MMM-FRITZ-Box-Callmonitor-py3 no longer works. The module says unknown error. It does not load the phone book. The settings were taken from the old system (it worked there)
      Can anyone help me?
      My data:
      RaspberryPi4 bookworm
      Packages are updated
      module: ‘MMM-FRITZ-Box-Callmonitor-py3’,
      position: ‘top_right’,
      header: “Letzter Anruf”,
      fritzIP: “192.168.188.1”,
      fritzPort: ‘1012’,
      username: “name”,
      password: “pass”,
      showContactsStatus: true,
      vCard: false,
      debug: true,
      maximumCallDistance: 60
      S R 2 Replies Last reply Reply Quote 0
      • W Offline
        wuermchen
        New attempt: I did not install fritzconnection via pipx, but with pip. I had to turn off the “externally managed” message beforehand.
        The phone book is now being read.
        The call is not yet displayed. The list is only displayed after a restart.
          sdetweil @wuermchen
          @wuermchen
          sorry bad post
            rkorell @wuermchen
            @wuermchen
            Hi.
            I guess it SHOULD work - at least it works for me at current github status (approx. 2-3 old - not sure what you have archived).
            At my own initial setup I got the same error message and after some researches it was caused by refused authentication on the fritzbox side.
            So I would start at this point initially - not at module side.
            My first attempt was login without password (as possible for console) - this doesn’t work.
            I’ve created a separate user on AVM side with full access to phonebook and so on and this worked from scratch.
            I see that you have an explicite user/pw as well - so I would double check if this user exists on AVM side and do have the right access privileges.
            For being sure I would recommend to delete all parameters from configuration you do not really need and experiment with the base parameters.
            E.g. you have set the Port number - at default - I would delete this one.
            I’m not sure if you are aware but you can find the documentation of the module in your module folder as well - you do not need the - closed - github entry.
            “README.md” is the file.
            Good luck!
            Ralf
            • KristjanESPERANTOK Offline
              @sdetweil said in MMM-FRITZ-Box-Callmonitor-py3 unknown_error:
              i do not know how the module works but i suspect this
              https://forum.magicmirror.builders/post/123380
              Where do you see the connection? The maintainer of MMM-FRITZ-Box-Callmonitor-py3 is drtorchwood.
                sdetweil @KristjanESPERANTO
                @KristjanESPERANTO bad post, didn’t check source, he had one too
                • W Offline
                  wuermchen
                  • I tried a new config with default values, without success
                  • Reinstalling and turning off the other modules, without success
                  		module: 'MMM-FRITZ-Box-Callmonitor-py3',
                  		position: 'top_right',
                  		header: "Recent calls",
                  			password: "pass",
                  			username: "user",
                  			fritzIP: "192.168.188.1",
                  			vCard: false
                  npm start has errors
                  > magicmirror@2.30.0 start
                  > npm run start:x11
                  > magicmirror@2.30.0 start:x11
                  [2025-01-31 18:47:25.363] [LOG]   Starting MagicMirror: v2.30.0
                  [2025-01-31 18:47:25.394] [LOG]   Loading config ...
                  [2025-01-31 18:47:25.398] [LOG]   config template file not exists, no envsubst
                  [2025-01-31 18:47:26.001] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js ...
                  [2025-01-31 18:47:26.140] [INFO]  Your configuration file doesn't contain syntax errors :)
                  [2025-01-31 18:47:26.142] [INFO]  Checking modules structure configuration ...
                  [2025-01-31 18:47:26.269] [INFO]  Your modules structure configuration doesn't contain errors :)
                  [2025-01-31 18:47:26.272] [LOG]   Loading module helpers ...
                  [2025-01-31 18:47:26.275] [LOG]   No helper found for module: alert.
                  [2025-01-31 18:47:26.283] [LOG]   Initializing new module helper ...
                  [2025-01-31 18:47:26.284] [LOG]   Module helper loaded: updatenotification
                  [2025-01-31 18:47:26.285] [LOG]   No helper found for module: clock.
                  [2025-01-31 18:47:26.286] [LOG]   No helper found for module: compliments.
                  [2025-01-31 18:47:26.461] [LOG]   Initializing new module helper ...
                  [2025-01-31 18:47:26.462] [LOG]   Module helper loaded: MMM-FRITZ-Box-Callmonitor-py3
                  [2025-01-31 18:47:26.463] [LOG]   All module helpers loaded.
                  [2025-01-31 18:47:26.473] [LOG]   Starting server on port 8080 ...
                  [2025-01-31 18:47:27.320] [LOG]   Server started ...
                  [2025-01-31 18:47:27.322] [LOG]   Connecting socket for: updatenotification
                  [2025-01-31 18:47:27.324] [LOG]   Starting module helper: updatenotification
                  [2025-01-31 18:47:27.325] [LOG]   Connecting socket for: MMM-FRITZ-Box-Callmonitor-py3
                  [2025-01-31 18:47:27.327] [LOG]   Starting module: MMM-FRITZ-Box-Callmonitor-py3
                  [2025-01-31 18:47:27.329] [LOG]   Sockets connected & modules started ...
                  [2025-01-31 18:47:28.262] [LOG]   Launching application.
                  [2025-01-31 18:47:29.866] [INFO]  System information:
                  ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; virtual: false
                  ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
                  ### VERSIONS: electron: 34.0.2; used node: 20.18.1; installed node: 20.18.1; npm: 10.9.2; pm2: 5.4.3
                  ### OTHER:    timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                  [96922:0131/184730.026384:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.026830:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.027196:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.027321:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.027499:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.027625:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.027798:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.027902:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.028061:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.028171:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.028341:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.028445:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.028602:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.028704:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.030069:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.030275:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.030478:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.030618:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.030807:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.030950:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.031137:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.031248:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.031471:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.031751:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.031946:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.032053:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.032219:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                  [96922:0131/184730.032326:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                  [2025-01-31 18:47:31.626] [LOG]   Received config for MMM-FRITZ-Box-Callmonitor-py3
                  [2025-01-31 18:47:31.631] [LOG]   MMM-FRITZ-Box-Callmonitor-py3 is waiting for incoming calls.
                  [2025-01-31 18:47:31.680] [INFO]  updatenotification: Updater Class Loaded!
                  [2025-01-31 18:47:31.682] [INFO]  updatenotification: Checking PM2 using...
                  [2025-01-31 18:47:31.684] [INFO]  updatenotification: [PM2] You are not using pm2
                  [2025-01-31 18:47:31.689] [INFO]  Checking git for module: MMM-FRITZ-Box-Callmonitor-py3
                  [2025-01-31 18:47:31.730] [INFO]  Checking git for module: MagicMirror
                  [2025-01-31 18:48:11.502] [INFO]  updatenotification: Updater Class Loaded!
                  [2025-01-31 18:48:11.503] [INFO]  updatenotification: Checking PM2 using...
                  [2025-01-31 18:48:11.503] [INFO]  updatenotification: [PM2] You are not using pm2
                    rkorell @wuermchen
                    @wuermchen
                    The log info from MMM-FRITZ-Box-Callmonitor seems to be O.K. …
                    Regards,
                    Ralf
                    • W Offline
                      wuermchen
                      I reinstalled Fritzcallmonitor. The error still exists.
                      During installation there were changes compared to the template:
                      python-dev = Doch die folgenden Pakete ersetzen es: python-dev-is-python3
                      sudo pip install fritzconnection  error: externally-managed-environment   sudo pipx install fritzconnection
                      Does anyone have any idea what I’m doing wrong?
                        sdetweil @wuermchen
                        @wuermchen does the pip setup require a virtual environment?
                        which you have to enable again before launching MagicMirror
                        • W Offline
                          wuermchen
                          I installed pipx before and then “sudo pipx install fritzconnection” so I don’t need a virtual environment
