    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 156.4k Views 25 Watching
    • T
      Them Russians @bungee09
      @bungee09 I did not do that install in the Magic Mirror folder. I ran the “curl” command from the github site for the MagicMirror, set up config.js, and then immediately got the PIR module.
      Do you think i could run the npm install on the MagicMirror folder now, and try again with the rebuild, or would i have to clear my SD card and reinstall everything and start from scratch?
      yawnsY B 2 Replies Last reply
      • yawnsY
        yawns Moderator @Them Russians
        @Them-Russians said in MMM-PIR-Sensor - White Screen:
        Yes, running npm install now will work and it is required.
          bungee09 @Them Russians
          @Them-Russians
          npm install in the main MM directory. Then npm install in the PIR sensor directory to install dependencies. If it fails then npm rebuild as above using the correct electron version number and abi.
          T 1 Reply Last reply
          • T
            @bungee09 The main MagicMirror directory, or the module directory within MagicMirror?
            B 1 Reply Last reply
              @Them-Russians In the main directory
               cd ~/MagicMirror/
               npm install && npm start
              • T
                @bungee09 @yawns When i ran the “npm install” in the MM directory, i got this error:
                npm warn grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed
                I googled the error and it looks like it shouldnt be an issue, but when i tried doing an install in the PIR directory (it failed), so did the rebuild with the updated electron version number (mine was 1.5.6).
                I got the same error when trying to run the rebuild
                Failed at the epoll@0.1.20 install script ‘node-gyp rebuild’
                Make sure you have the latest version of node.js and npm installed.
                Sorry for all the posts on here, but do you have any thoughts? I update node.js and npm to the most recent versions, so i dont think that what is broken for me :(
                When i try to run the mirror, here is the error i get before the white screen:
                magicmirror@2.1.0 start /home/pi/MagicMirror
                electron js/electron.js “dev”
                Starting MagicMirror: v2.1.0
                Loading config …
                Loading module helpers …
                WARNING! Could not load config file. Starting with default configuration. Error found: Error: Could not locate the bindings file. Tried:
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node
                → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node
                App threw an error during load
                at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:88:9)
                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:116)
                at Module._compile (module.js:556:32)
                at Object.Module._extensions…js (module.js:565:10)
                at Module.load (module.js:473:32)
                at tryModuleLoad (module.js:432:12)
                at Function.Module._load (module.js:424:3)
                at Module.require (module.js:483:17)
                at require (internal/module.js:20:19)
                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/onoff.js:4:11)
                Whoops! There was an uncaught exception…
                { Error: Could not locate the bindings file. Tried:
                tries:
                [ ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node’,
                ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node’ ] }
                Launching application.
                bheplerB 1 Reply Last reply
                • bheplerB
                  bhepler Module Developer @Them Russians
                  @Them-Russians
                  Don’t worry about this one. The log file format is [process] [debug level] [error message]. In this case, “warn” is the level of severity of the message. If it said “err” then it would require your attention.
                  I suspect your nodejs version is out of date. Try running this command: nodejs -v and then npm -v. It should spit out the version of node and NPM you’re using. Personally, I’m on v7.4.0 and v4.0.5 respectively. If you’re running a few versions behind, you may wish to run these commands from your home folder:
                  curl -sL https://deb.nodesource.com/setup_7x | sudo -E bash -
                  sudo apt-get install -y nodejs
                  sudo npm install -g npm
                  And yes, you may have to run that last command twice. For some reason, NPM sometimes requires a double-tap to update itself. Thank you, StackExchange.
                  Run nodejs -v again and verify that your node version is up to snuff.
                  • T
                    Them Russians @bhepler
                    @bhepler
                    Hey there, thank you for the suggestion. updated both nodejs and npm to 7.4.0 and 4.0.5.
                    I think removed the MMM-PIR-Sensor folder, grabbed it again from github, and then tried to run npm install on it, and the install failed again.
                    An unhandled error occurred inside electron-rebuild
                    Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                    Error: Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                    at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                    at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                    at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                    at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                    at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                    at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                    at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                    at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                    at Module._compile (module.js:571:32)
                    at Object.Module._extensions…js (module.js:580:10)
                    at Module.load (module.js:488:32)
                    at tryModuleLoad (module.js:447:12)
                    at Function.Module._load (module.js:439:3)
                    at Module.runMain (module.js:605:10)
                    at run (bootstrap_node.js:420:7)
                    at startup (bootstrap_node.js:139:9)
                    I tried running the rebuild with my electron version number (1.5.7) but still no luck. Any thoughts on what else I could try? I am drawing a blank here, unfortunately.
                    O B J 3 Replies Last reply
                    • O
                      ostfilinchen @Them Russians
                      @Them-Russians i also thought i have a higher electron-version. but i tried
                      npm rebuild --runtime=electron --target=1.4.3 --disturl=https://atom.io/download/atom-shell --abi=50
                      and it worked for me.
                        @Them-Russians I think you definitely need to rebuild electron. I can’t see what else is causing the issue. Try with different electron version numbers. Otherwise I’m all out of ideas. Sorry!
                          Jopyth Moderator @Them Russians
                          @Them-Russians Try changing line 24 in package.json as shown here and reinstall with npm install in the module folder. Does that help?
                          Also: Please continue discussion about install issues here. There is already info on how it can be solved. For other problems with the PIR-Sensor Module please open a new thread in the modeul troubleshooting section.
                            djbosman @Bangee
                            @Bangee
                            Thanx a Million, Bro’ !!
                            The step-by-step did it for me!
                            I couldn’t understand that everybody’s was working so cool and mine dis diddly-squat?!?
                            So removing the module and reinstalling was the answer. No idea what went wrong first time round; Just grateful it is now working as expected.
                            Thanx for your great post!!
                            • BangeeB
                              Bangee Module Developer
                              I’m glad to hear that! :-D
                                Coda @Medo
                                @Medo Solved it for me, thanks!
                                  MobbareKurtZ
                                  • 5 / 5
