    Which solution for touching screen?
    Scheduled Pinned Locked Moved Forum
    13 Posts 3 Posters 9.5k Views 3 Watching
      com1cedric
      Hello everyone,
      Could someone advise me which hardware to use to make a touch Magic Mirror? Not too small, idealy 21 to 23 inches.
      E.g infrared frame overlay, or an idea of a monitor brand which provides touch screens compatible with a Raspberry 4 and the Magic Mirror solution?
      I bought a iiyama ProLite T2252MSC-B2 touch screen, but as I tried it, the touch function was finally not compatible with Raspberry and it was only working in the landscape mode… I did not realise it before buying it…
      Thank you for your advise and sharing you experience about this topic.
      Looking forward to reading you,
      Kind regards,
      Cedric
      R 1 Reply Last reply
        rkorell Module Developer @com1cedric
        @com1cedric
        I had tried a Hannspree Touch monitor which worked out of the box with Raspian OS - without any driver installation.
        So it should work with MagicMirror as well.
        Video is connected via HDMI and touch is realized via USB.
        I do not use it for my MagigMirror - it‘s to small for my use-case.
        If you really want to realize a MIRROR keep in mind that every capacitative touch functionality will NOT work behind a reflecting surface.
        For this use case you have to consider IR-Frames around your mirror.
        If you just want to use the monitor - fine …
        Regards,
        Ralf
        C 2 Replies Last reply
          com1cedric @rkorell
          @rkorell said in Which solution for touching screen?:
          Hello @rkorell , and thank you for your advise!
          My mirror should be just a monitor without any reflecting surface, using MMM-Pages and MMM-page-indicator.
          @sdetweil and @edward-shen : do you think your modules MMM-Pages and MMM-page-indicator should work with a kind of “Hannspree Touch monitor” or IR-Frame, without using a mouse? Can you please advise me?
          Thank you in advance and best regards.
          Cédric
            sdetweil @com1cedric
            @com1cedric touch monitor/ir-frame is a mouse from the apps perspective, touch invokes click, movement is mouse movements
            pageindicator circles are buttons/links , you can change the image thru css
            see https://forum.magicmirror.builders/post/118877
            so, if the display sends touch events, the browser will react
            i do not know the hardware
            C 1 Reply Last reply
              com1cedric @sdetweil
              @sdetweil hello Sam, great, thanks a lot!
                @com1cedric where are you located?
                Bckground: If in feasible distance I could send you my Hannspree Display for testing purposes …
                Warm regards,
                Ralf
                  com1cedric @rkorell
                  @rkorell thank you very much for your proposal, but I just ordered it (I am in Switzerland).
                  I will then test it and send it back if it does not work.
                  I will inform you in any case whether if was successful or not.
                  Kind regards,
                  Cédric
                    @com1cedric O.K. to me :-)
                    Good luck!
                    Ralf
                    • C com1cedric referenced this topic on
                      com1cedric @rkorell
                      @rkorell
                      hello @rkorell, wenn you tested your Hannspree Touch monitor, did you have to change any parameter on the raspberry, so that the “touching points” work?
                      On mine, it is working fine in landscape mode, but in the portrait mode, the points are “mirrored”, so that it is impossible to use it without parametring that. Thank you in advance, Cédric
                        @com1cedric didn’t you just.post solving this
                        https://forum.magicmirror.builders/post/124971
                        R C 2 Replies Last reply
                          @sdetweil , @com1cedric , yes, that’s what I would have suggested as well - use
                          Option "TransformationMatrix" "0 -1 1 1 0 0 0 0 1"
                          or similar in /usr/share/X11/xorg.conf.d/40-libinput.conf …
                          Regards,
                          Ralf
                            @sdetweil yes, this one can be closed. But I do not see the button to close it
                              @com1cedric this was started as a conversation, not an issue…
