    Question about backup script
    30 Posts 3 Posters 6.5k Views 3 Watching
    • N Offline
      nowayto
      I have a question about backup script.
      In these days I’m trying to learn how to configure MM with some modules, after all these tries, I will do a fresh installation with no errors on configuration.
      When I’ll arrive at that point, I’ll wanna backup MM entirely, so I see your script:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)” with any parms
      I don’t want a github private backup, I want just a local backup so does this script will backup every configuration on: $HOME/MM_backup ?
      I assume I’ll just have to copy that folder away and keep it secure?
      When I’ll need a restore I can start with an empty SD card, OS installation, MM installation script and then which of that 2 options?
      1- copy the MM_backup folder in $HOME, install modules I need and run your restore script
      (bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)” with any parms)
      2- copy the MM_backup folder in $HOME and just run the restore script
      Thanks in advance
        sdetweil @nowayto
        @nowayto restore, option 2 . restore will reinstall all the modules and copy any created files saved with them
        (What’s the point of having a restore tool if it doesn’t?)
        And restore will copy the GitHub repo down for you (part 1 of your option 2)
        now, on the github
        its the same as ‘copy the MM_backup folder someplace’
        backup also creates versions
        backup today and next week, and restore either one
        or one from last year
        github is free
        make a private repo
        N 1 Reply Last reply Reply Quote 2
        • N Offline
          nowayto @sdetweil
          Perfect.
          Your right but since I’m not a programmer so sometimes I have some stupid doubts.
          I started with a simple idea and now in my mind I wanna make more than one MM, with differents setup but for now I need to learn the basics configuration, so I’m testing testing and testing more :)
          Reinstall from 0 and test again :)
          For example I hope it will be not to difficult to config css, I like the personalization it will offer but I’m scared about difficulties. But I’ll try for sure!
          Thank you again
          S 2 Replies Last reply Reply Quote 1
            sdetweil @nowayto
            @nowayto also see my MMM-Config, it provides module install and all config
            N 1 Reply Last reply Reply Quote 1
              sdetweil @nowayto
              @nowayto css, learn the developers window.
              see the second link in my signature below
                rkorell @sdetweil
                @sdetweil Dear Sam,
                seen backup/restore days ago and as the question arises here - I struggle with the commend line :-(
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -h
                works - I get some hints - same as on your github repo.
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p
                doesn’t work?
                "illegal option '- ’ " is the error message.
                Where can I place the -p option?
                (inside the brackets I get an errormessage from curl …)
                This is also true if I add repo- and username and the token.
                There is my second question: how to pass the parameters?
                I’ve tried
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p MagicMirror rkorell ghp_thisismyverylongandcryptictokenforgithub
                But with no luck.
                MagicMirror is a fresh created repo, rkorell is my username on GitHub - token is fresh created private token according your guidance in module description.
                Can you please help?
                Thanks a LOT -as always,
                Ralf
                  rkorell @rkorell
                  @sdetweil ,
                  last trial (after digging in your script I understand that -p is not that correct…)
                  So I’ve figured out that reponame and username have their own prefix.
                  A prefix for the token is not present, so I assume user:token could be feasible.
                  So I came to
                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh) -p -r MagicMirror -u rkorell:ghpthisismyverylongandcryptictokenforgithub"
                  But this doesn’t work either…
                  So I’m desparately looking for the right place to put in the right parameters in the right manner.
                  Sorry for being this dumb…
                  Regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell hm… I did
                    and got
                    -h takes optional parameters
                    	 -s MagicMirror_dir
                    		default /Users/sam/MagicMirror
                    	 -b backup_dir
                    		default /Users/sam/MM_backup
                    	 -m backup message
                    		 any message (in quotes) that you would like to attach to this change for later info
                    		default none
                    	 -p auto push to github (will need repo name, username,  user password or token
                    		default false
                    	 -r github repository name (reponame)
                    		typically https://github.com/username/reponame.git
                    		default output of git remote -v (if set)
                    		 -r overrides the git remote setting
                    	 -u github username
                    		default none
                    S R 3 Replies Last reply Reply Quote 0
                      @rkorell there was a typo in the help contents…
                      I NEVER ask for password/token… git will prompt if needed…
                      thus I cannot capture it in my script… a security confidence thing…
                        @rkorell -p by itself gives an error, will fix
                        in both scripts
                        -s is the MagicMirror folder
                        -b is the backup folder
                        -u is the github userid
                        -r is the repo name, short xxxx or long https:…/repo
                        if you use the long url, i will get the userid from there
                        in backup
                        -p is push if not specified script will NOT push to github
                        in restore
                        -f requests fetch the github repo. if not specified, the local -b folder will be used to restore from. if not found the script will abort
