    Question about backup script
    30 Posts 3 Posters 10.3k Views 3 Watching
      sdetweil @nowayto
      @nowayto restore, option 2 . restore will reinstall all the modules and copy any created files saved with them
      (What’s the point of having a restore tool if it doesn’t?)
      And restore will copy the GitHub repo down for you (part 1 of your option 2)
      now, on the github
      its the same as ‘copy the MM_backup folder someplace’
      backup also creates versions
      backup today and next week, and restore either one
      or one from last year
      github is free
      make a private repo
      N 1 Reply Last reply Reply Quote 2
      • N Offline
        nowayto @sdetweil
        Perfect.
        Your right but since I’m not a programmer so sometimes I have some stupid doubts.
        I started with a simple idea and now in my mind I wanna make more than one MM, with differents setup but for now I need to learn the basics configuration, so I’m testing testing and testing more :)
        Reinstall from 0 and test again :)
        For example I hope it will be not to difficult to config css, I like the personalization it will offer but I’m scared about difficulties. But I’ll try for sure!
        Thank you again
        S 2 Replies Last reply Reply Quote 1
          sdetweil @nowayto
          @nowayto also see my MMM-Config, it provides module install and all config
          N 1 Reply Last reply Reply Quote 1
            sdetweil @nowayto
            @nowayto css, learn the developers window.
            see the second link in my signature below
              @sdetweil Dear Sam,
              seen backup/restore days ago and as the question arises here - I struggle with the commend line :-(
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -h
              works - I get some hints - same as on your github repo.
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p
              doesn’t work?
              "illegal option '- ’ " is the error message.
              Where can I place the -p option?
              (inside the brackets I get an errormessage from curl …)
              This is also true if I add repo- and username and the token.
              There is my second question: how to pass the parameters?
              I’ve tried
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p MagicMirror rkorell ghp_thisismyverylongandcryptictokenforgithub
              But with no luck.
              MagicMirror is a fresh created repo, rkorell is my username on GitHub - token is fresh created private token according your guidance in module description.
              Can you please help?
              Thanks a LOT -as always,
              Ralf
                rkorell Module Developer @rkorell
                @sdetweil ,
                last trial (after digging in your script I understand that -p is not that correct…)
                So I’ve figured out that reponame and username have their own prefix.
                A prefix for the token is not present, so I assume user:token could be feasible.
                So I came to
                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh) -p -r MagicMirror -u rkorell:ghpthisismyverylongandcryptictokenforgithub"
                But this doesn’t work either…
                So I’m desparately looking for the right place to put in the right parameters in the right manner.
                Sorry for being this dumb…
                Regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell hm… I did
                  and got
                  -h takes optional parameters
                  	 -s MagicMirror_dir
                  		default /Users/sam/MagicMirror
                  	 -b backup_dir
                  		default /Users/sam/MM_backup
                  	 -m backup message
                  		 any message (in quotes) that you would like to attach to this change for later info
                  		default none
                  	 -p auto push to github (will need repo name, username,  user password or token
                  		default false
                  	 -r github repository name (reponame)
                  		typically https://github.com/username/reponame.git
                  		default output of git remote -v (if set)
                  		 -r overrides the git remote setting
                  	 -u github username
                  		default none
                  S R 3 Replies Last reply Reply Quote 0
                    @rkorell there was a typo in the help contents…
                    I NEVER ask for password/token… git will prompt if needed…
                    thus I cannot capture it in my script… a security confidence thing…
                      @rkorell -p by itself gives an error, will fix
                      in both scripts
                      -s is the MagicMirror folder
                      -b is the backup folder
                      -u is the github userid
                      -r is the repo name, short xxxx or long https:…/repo
                      if you use the long url, i will get the userid from there
                      in backup
                      -p is push if not specified script will NOT push to github
                      in restore
                      -f requests fetch the github repo. if not specified, the local -b folder will be used to restore from. if not found the script will abort
                      • N Offline
                        nowayto @sdetweil
                        @sdetweil said in Question about backup script:
                        I give it a try some days ago, after your suggestion but I wanna learn the configuration first, rather than easier ways
                        I’ll read your CSS guide for sure
                          sdetweil @nowayto
                          @nowayto yes, providing helpful tools hides the detail. a double edged sword
                          my objective is to help you get results.
                          • N Offline
                            nowayto @sdetweil
                            @sdetweil and I really thank you for that.
                            Thanks to you even more people will try MM and appreciate your work.
                            On my side I’m there to learn something new.
                            It’ more challenging but it’s also more interesting so I’d prefer manual ways.
                            Thanks a lot for your help, I’ll really appreciate that
                              hm… I did
                              Dear Sam (@sdetweil),
                              yes - this worked for me as well :-)
                              Now figured out how it works:
                              Have issued
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -r https://github.com/rkorell/MagicMirror -p
                              Then I was asked for username and password (twice) and git upload worked…
                              It seems git upload now contains a copy of local directory mm_backup.
                              If I check both, there are only a few directoris in Github as well as locally - much fewer than total number of installed modules…
                              What is the criterium for a module to “earn” a directory or not?
                              Thanks a lot!
                              Warmest regards,
                              Ralf
                                sdetweil @rkorell
                                @rkorell the backup copies the url of the module source
                                where you cloned from,
                                see git remote -v in any module folder
                                now some modules create files, token.json for example
                                if i find extra files i need a place to store them, so the module name for a folder is created
                                the module_list file contains the list of modules needed
                                and their urls. they are reinstalled
                                the readme says this
                                this is not a binary backup
                                you can use this to move to a new system or new sd card (changing processor architectures too, pc to pi, pi to pc… whatever)
                                yes the folder MM_backup by default is a git source repository
                                and git will track any changes (new backup differences)
                                each time you back up, i create a marker to label this event, in git called a tag
                                and you can restore any one of those and compare two tags to see the difference
                                the private repo is because the files are saved in source form, and contain apikeys and maybe other credentials
                                S R 2 Replies Last reply Reply Quote 1
                                  @rkorell you got prompted twice for username because git needs to know who you are and how to reach you if there are concerns about your “commit” to the repo. you csn see this in git log
                                  output in the backup folder
                                  this is username and email address
                                  then the push , github needs to know . this is the password prompt from git
                                  you could use git config to save those, and avoid the prompts
                                    Sounds cool.
                                    How can I do this?
                                    Thanks!
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell google is your friend
                                      how to use git config
                                        Thanks for this explanation - this is what I had assumed.
                                        Regards,
                                        Ralf
                                          OK, thanks.
                                          I had understood that this is a config of your scripts, sorry.
                                            sdetweil @rkorell
                                            @rkorell no… you can store config settings for git (the source code repository tool MagicMirror uses and most modules use (…git clone))
                                            and the way to make the repository that the backup uses
