    Question about backup script
    30 Posts 3 Posters 10.1k Views 3 Watching
      rkorell Module Developer @rkorell
      @sdetweil ,
      last trial (after digging in your script I understand that -p is not that correct…)
      So I’ve figured out that reponame and username have their own prefix.
      A prefix for the token is not present, so I assume user:token could be feasible.
      So I came to
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh) -p -r MagicMirror -u rkorell:ghpthisismyverylongandcryptictokenforgithub"
      But this doesn’t work either…
      So I’m desparately looking for the right place to put in the right parameters in the right manner.
      Sorry for being this dumb…
      Regards,
      Ralf
        sdetweil @rkorell
        @rkorell hm… I did
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -h
        and got
        -h takes optional parameters
        	 -s MagicMirror_dir
        		default /Users/sam/MagicMirror
        	 -b backup_dir
        		default /Users/sam/MM_backup
        	 -m backup message
        		 any message (in quotes) that you would like to attach to this change for later info
        		default none
        	 -p auto push to github (will need repo name, username,  user password or token
        		default false
        	 -r github repository name (reponame)
        		typically https://github.com/username/reponame.git
        		default output of git remote -v (if set)
        		 -r overrides the git remote setting
        	 -u github username
        		default none
        S R 3 Replies Last reply Reply Quote 0
          @rkorell there was a typo in the help contents…
          I NEVER ask for password/token… git will prompt if needed…
          thus I cannot capture it in my script… a security confidence thing…
            @rkorell -p by itself gives an error, will fix
            in both scripts
            -s is the MagicMirror folder
            -b is the backup folder
            -u is the github userid
            -r is the repo name, short xxxx or long https:…/repo
            if you use the long url, i will get the userid from there
            in backup
            -p is push if not specified script will NOT push to github
            in restore
            -f requests fetch the github repo. if not specified, the local -b folder will be used to restore from. if not found the script will abort
            • N Offline
              nowayto @sdetweil
              @sdetweil said in Question about backup script:
              @nowayto also see my MMM-Config, it provides module install and all config
              I give it a try some days ago, after your suggestion but I wanna learn the configuration first, rather than easier ways
              I’ll read your CSS guide for sure
                sdetweil @nowayto
                @nowayto yes, providing helpful tools hides the detail. a double edged sword
                my objective is to help you get results.
                N 1 Reply Last reply Reply Quote 1
                • N Offline
                  nowayto @sdetweil
                  @sdetweil and I really thank you for that.
                  Thanks to you even more people will try MM and appreciate your work.
                  On my side I’m there to learn something new.
                  It’ more challenging but it’s also more interesting so I’d prefer manual ways.
                  Thanks a lot for your help, I’ll really appreciate that
                    hm… I did
                    Dear Sam (@sdetweil),
                    yes - this worked for me as well :-)
                    Now figured out how it works:
                    Have issued
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -r https://github.com/rkorell/MagicMirror -p
                    Then I was asked for username and password (twice) and git upload worked…
                    It seems git upload now contains a copy of local directory mm_backup.
                    If I check both, there are only a few directoris in Github as well as locally - much fewer than total number of installed modules…
                    What is the criterium for a module to “earn” a directory or not?
                    Thanks a lot!
                    Warmest regards,
                    Ralf
                      sdetweil @rkorell
                      @rkorell the backup copies the url of the module source
                      where you cloned from,
                      see git remote -v in any module folder
                      now some modules create files, token.json for example
                      if i find extra files i need a place to store them, so the module name for a folder is created
                      the module_list file contains the list of modules needed
                      and their urls. they are reinstalled
                      the readme says this
                      this is not a binary backup
                      you can use this to move to a new system or new sd card (changing processor architectures too, pc to pi, pi to pc… whatever)
                      yes the folder MM_backup by default is a git source repository
                      and git will track any changes (new backup differences)
                      each time you back up, i create a marker to label this event, in git called a tag
                      and you can restore any one of those and compare two tags to see the difference
                      the private repo is because the files are saved in source form, and contain apikeys and maybe other credentials
                      S R 2 Replies Last reply Reply Quote 1
                        @rkorell you got prompted twice for username because git needs to know who you are and how to reach you if there are concerns about your “commit” to the repo. you csn see this in git log
                        output in the backup folder
                        this is username and email address
                        then the push , github needs to know . this is the password prompt from git
                        you could use git config to save those, and avoid the prompts
                          Sounds cool.
                          How can I do this?
                          Thanks!
                          Ralf
                            sdetweil @rkorell
                            @rkorell google is your friend
                            how to use git config
                              Thanks for this explanation - this is what I had assumed.
                              Regards,
                              Ralf
                                OK, thanks.
                                I had understood that this is a config of your scripts, sorry.
                                  sdetweil @rkorell
                                  @rkorell no… you can store config settings for git (the source code repository tool MagicMirror uses and most modules use (…git clone))
                                  and the way to make the repository that the backup uses
                                    @sdetweil as far as google told me it seems, I need to install Git CLI - which is not easy available for Raspi.
                                    Any hint?
                                    Sorry!
                                    Ralf
                                    R S 2 Replies Last reply Reply Quote 0
                                      O.K,. Google is not my friend today…
                                      It seems that a “.gitconfig” file will do the trick …
                                      Will double check.
                                        Nope.
                                        Doesnt’t work.
                                        Have created a “.gitconfig” file with
                                        git config --global --edit
                                        Entered user, email and password - but your script asks again for “user” …
                                        Ralf
                                          sdetweil @rkorell
                                          @rkorell the SCRIPT does not prompt
                                          I use these git config parms
                                          if [ "$user_name." == "." ]; then
                                          	# prompt for users name
                                          	git config --local user.name $user_name
                                          else
                                          fi
                                          if [ "$email." == "." ]; then
                                          	# prompt for email address
                                          	git config --local user.email $email
                                          else
                                          fi
                                          git will prompt
                                            sdetweil @rkorell
                                            @rkorell you HAVE the git cli
                                            git --help
                                            (–local means in this folder only)
                                            git config --local user.name “your name”
                                            git config --local user.email “your email”
                                            see here
                                            https://stackoverflow.com/questions/35942754/how-can-i-save-username-and-password-in-git
                                            and username means github userid
