    Question about backup script
    30 Posts 3 Posters 7.0k Views 3 Watching
    • N Offline
      nowayto @sdetweil
      Perfect.
      Your right but since I’m not a programmer so sometimes I have some stupid doubts.
      I started with a simple idea and now in my mind I wanna make more than one MM, with differents setup but for now I need to learn the basics configuration, so I’m testing testing and testing more :)
      Reinstall from 0 and test again :)
      For example I hope it will be not to difficult to config css, I like the personalization it will offer but I’m scared about difficulties. But I’ll try for sure!
      Thank you again
      S 2 Replies Last reply Reply Quote 1
        sdetweil @nowayto
        @nowayto also see my MMM-Config, it provides module install and all config
        N 1 Reply Last reply Reply Quote 1
          sdetweil @nowayto
          @nowayto css, learn the developers window.
          see the second link in my signature below
            rkorell @sdetweil
            @sdetweil Dear Sam,
            seen backup/restore days ago and as the question arises here - I struggle with the commend line :-(
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -h
            works - I get some hints - same as on your github repo.
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p
            doesn’t work?
            "illegal option '- ’ " is the error message.
            Where can I place the -p option?
            (inside the brackets I get an errormessage from curl …)
            This is also true if I add repo- and username and the token.
            There is my second question: how to pass the parameters?
            I’ve tried
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p MagicMirror rkorell ghp_thisismyverylongandcryptictokenforgithub
            But with no luck.
            MagicMirror is a fresh created repo, rkorell is my username on GitHub - token is fresh created private token according your guidance in module description.
            Can you please help?
            Thanks a LOT -as always,
            Ralf
              rkorell @rkorell
              @sdetweil ,
              last trial (after digging in your script I understand that -p is not that correct…)
              So I’ve figured out that reponame and username have their own prefix.
              A prefix for the token is not present, so I assume user:token could be feasible.
              So I came to
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh) -p -r MagicMirror -u rkorell:ghpthisismyverylongandcryptictokenforgithub"
              But this doesn’t work either…
              So I’m desparately looking for the right place to put in the right parameters in the right manner.
              Sorry for being this dumb…
              Regards,
              Ralf
                sdetweil @rkorell
                @rkorell hm… I did
                and got
                -h takes optional parameters
                	 -s MagicMirror_dir
                		default /Users/sam/MagicMirror
                	 -b backup_dir
                		default /Users/sam/MM_backup
                	 -m backup message
                		 any message (in quotes) that you would like to attach to this change for later info
                		default none
                	 -p auto push to github (will need repo name, username,  user password or token
                		default false
                	 -r github repository name (reponame)
                		typically https://github.com/username/reponame.git
                		default output of git remote -v (if set)
                		 -r overrides the git remote setting
                	 -u github username
                		default none
                S R 3 Replies Last reply Reply Quote 0
                  @rkorell there was a typo in the help contents…
                  I NEVER ask for password/token… git will prompt if needed…
                  thus I cannot capture it in my script… a security confidence thing…
                    @rkorell -p by itself gives an error, will fix
                    in both scripts
                    -s is the MagicMirror folder
                    -b is the backup folder
                    -u is the github userid
                    -r is the repo name, short xxxx or long https:…/repo
                    if you use the long url, i will get the userid from there
                    in backup
                    -p is push if not specified script will NOT push to github
                    in restore
                    -f requests fetch the github repo. if not specified, the local -b folder will be used to restore from. if not found the script will abort
                    • N Offline
                      nowayto @sdetweil
                      @sdetweil said in Question about backup script:
                      I give it a try some days ago, after your suggestion but I wanna learn the configuration first, rather than easier ways
                      I’ll read your CSS guide for sure
                        sdetweil @nowayto
                        @nowayto yes, providing helpful tools hides the detail. a double edged sword
                        my objective is to help you get results.
