    CSS modifications on a module which has no own css styles?
    30 Posts 2 Posters 6.3k Views 2 Watching
      sdetweil @rkorell
      @rkorell yes. as a replacement for module_name
      when you select the element in the dev window
      down at the bottom is the selector clause prototype
        rkorell @sdetweil
        @sdetweil unfortunately your suggestion doesn’t work…
        And I cannot see anything “at the button” ?
        Defnitely no “selector clause prototype”
          rkorell @rkorell
          This is complete view in Firefox Browser
          S R 2 Replies Last reply Reply Quote 0
            sdetweil @rkorell
            @rkorell there is an extra close div after the span
            where does it open
              rkorell @rkorell
              This same in Chrome
                rkorell @sdetweil
                @sdetweil said in CSS modifications on a module which has no own css styles?:
                where does it open
                <div module>
                <div class "module content">
                <div Style "margin-block-end">
                  <span class> font-awesome-picture
                " HERE THE TEXT"
                </div>
                </div>
                </div>
                The " <div class “module content”> " is identified by
                "#module_10_MMM-JsonValue > div:nth-child(2) " (for the first instance of module)
                second and following instances are counted up consecutively
                "#module_11_MMM-JsonValue > div:nth-child(2) "
                "#module_12_MMM-JsonValue > div:nth-child(2) "
                "#module_13_MMM-JsonValue > div:nth-child(2) "
                  rkorell @rkorell
                  #module_10_MMM-JsonValue > div:nth-child(2) {
                     color: "fuchsia";
                  Doesn’t work, either :-(
                    sdetweil @rkorell
                    @rkorell prototype
                    S R 2 Replies Last reply Reply Quote 1
                      @rkorell maybe that will work
                      if you change it in the input area, does change
                        @rkorell
                        .module-content div {
                        color:
