[Remote-Control] Shutdown, Configure and Update your MagicMirror
@in_a_days thank you, I tried that module and I really liked it! But I’m not really a good programmer so it would be complicate for me to add new icons for every module.
Also, I don’t know why, with this module on, the Hide/show all module disappeared. How can I fix it? -
very nice module!
one day it might be remote configurator for a mirror.
You could do a querry for all installed modules and create a simple drag and drop interface for putting modules in their places of a screen and then regenerate mirror config file.I hope you will do it one day.
regards
Mike -
Hi @Jopyth
Awesome module!A couple of questions - how can I use it to enable-disable MMM-PIR-Sensor?
Is it possible to use it to disable/enable certain aspects of a module?
e.g.: for the newsfeed, i’d like to switch on/off certain feedsTIA
Hi!
Thank you for this great module!
I’m thinking it would be good to have menu entry for the “logs”.
Basically just “display” the logs (maybe last 100 lines) of the ~/.pm2/logs/mm* files.
What do you say? :)Best regards Snille
@Snille I like the idea, will probably add this to my “want to do” features.
Also, I decided to release all the stuff I have worked on as version 1.1.0, some of it is still experimental, but I put a (hopefully) clear warning before you can mess up your config.
[1.1.0] - 2017-01-26
Added
- First version of installer script
- Menu to send Alerts and/or Notifications to your mirror
- Menu to update your MagicMirror installation and your modules (through
git pull
) - Menu to change the
config.js
- Modules can be installed, added, removed, configured
- There will be backups of the five last versions of the
config.js
in theconfig
folder - Some of these parts are hidden behind an “exprimental” warning, do not ignore that warning
- NOTIFICATION action, see README.md for details
Changed
- Menu structure
- Old “Edit” and “Settings” are now under “Edit view”
- Smaller font sizes in lists
Fixed
- Issues coming from disabled modules since MM version 2.1.0
Well done for getting the update out!
Can’t wait to give it a try.
Loving the update so far. But I’m experiencing a couple small bugs. On re-boot I am losing my active/hidden module settings. I get the “Done” confirmation after Saving, but on reboot it’s showing all modules rather than just the ones I had active. I’m also getting “! Error!” when I attempt Power > Restart MagicMirror2.
Remote-Control is one of my favs. Happy to check some logs anything that may help isolate the problem.
Is it worth updating? I have been excited for this update, but I have waited to see if it would be better than the previous version. Since it appears that some people experience bugs, I might just stay with the version I have. Is this a smart choice?
@in_a_days Funny I also got that bug on the previous remote version, after updating to MM v2.1 . If I´m rebooting the MM or Power Off and starting it later, all changes of visible Modules are gone. So basically i tested some modules and later hide them cause i don´t want to delete them from the config, or just show them when i need some of them. It´s not a big deal, just saying.
