    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 941.1k Views 77 Watching
    • A
      AlessandroRa
      It works, and it’s awesome!!
      Now, time for a stupid question: since I’m building a touch screen smart mirror, can I run the remote menu on an iFrame? I want to be able to manage the modules and shut down the mirror when I’m not using it
      • A
        AlessandroRa
        I just tried to use the “Hello World” module, but that’s what I’ve got 0_1483883271656_2017-01-08-144602_1920x1080_scrot.png
        • I
          in_a_days @AlessandroRa
          @AlessandroRa said in MMM-Remote-Control:
          You might find this module more useful for your particular build. I don’t think it features power and restart buttons yet, but that will be a pretty simple addition.
          https://github.com/chr1syy/MM-navbar
          https://forum.magicmirror.builders/topic/1128/mm-navbar-navigation-bar-for-touchscreens-to-hide-show-modules
          • A
            AlessandroRa @in_a_days
            @in_a_days thank you, I tried that module and I really liked it! But I’m not really a good programmer so it would be complicate for me to add new icons for every module.
            Also, I don’t know why, with this module on, the Hide/show all module disappeared. How can I fix it?
            • G
              Gooral
              very nice module!
              one day it might be remote configurator for a mirror.
              You could do a querry for all installed modules and create a simple drag and drop interface for putting modules in their places of a screen and then regenerate mirror config file.
              I hope you will do it one day.
              regards
              Mike
              • E
                ejmina
                Hi @Jopyth
                Awesome module!
                A couple of questions - how can I use it to enable-disable MMM-PIR-Sensor?
                Is it possible to use it to disable/enable certain aspects of a module?
                e.g.: for the newsfeed, i’d like to switch on/off certain feeds
                TIA
                • SnilleS
                  Snille Module Developer
                  Hi!
                  Thank you for this great module!
                  I’m thinking it would be good to have menu entry for the “logs”.
                  Basically just “display” the logs (maybe last 100 lines) of the ~/.pm2/logs/mm* files.
                  What do you say? :)
                  Best regards Snille
                    Jopyth Moderator @Snille
                    @Snille I like the idea, will probably add this to my “want to do” features.
                      Jopyth Moderator
                      Also, I decided to release all the stuff I have worked on as version 1.1.0, some of it is still experimental, but I put a (hopefully) clear warning before you can mess up your config.
                      [1.1.0] - 2017-01-26
                      Added
                      • First version of installer script
                      • Menu to send Alerts and/or Notifications to your mirror
                      • Menu to update your MagicMirror installation and your modules (through git pull)
                      • Menu to change the config.js
                        • Modules can be installed, added, removed, configured
                        • There will be backups of the five last versions of the config.js in the config folder
                        • Some of these parts are hidden behind an “exprimental” warning, do not ignore that warning
                      • NOTIFICATION action, see README.md for details
                      Changed
                      • Menu structure
                        • Old “Edit” and “Settings” are now under “Edit view”
                      • Smaller font sizes in lists
                      Fixed
                      • Issues coming from disabled modules since MM version 2.1.0
                      • O
                        open_book
                        Well done for getting the update out!
                        Can’t wait to give it a try.
                        sudo insert motivational.quote
                        • I
                          in_a_days
                          Loving the update so far. But I’m experiencing a couple small bugs. On re-boot I am losing my active/hidden module settings. I get the “Done” confirmation after Saving, but on reboot it’s showing all modules rather than just the ones I had active. I’m also getting “! Error!” when I attempt Power > Restart MagicMirror2.
                          Remote-Control is one of my favs. Happy to check some logs anything that may help isolate the problem.
                          S J 2 Replies Last reply Reply Quote 1
                          • A
                            AAPS
                            Is it worth updating? I have been excited for this update, but I have waited to see if it would be better than the previous version. Since it appears that some people experience bugs, I might just stay with the version I have. Is this a smart choice?
                              schlachtkreuzer6 @in_a_days
                              @in_a_days Funny I also got that bug on the previous remote version, after updating to MM v2.1 . If I´m rebooting the MM or Power Off and starting it later, all changes of visible Modules are gone. So basically i tested some modules and later hide them cause i don´t want to delete them from the config, or just show them when i need some of them. It´s not a big deal, just saying.
                                Jopyth Moderator @AAPS
                                @AAPS (and everyone else): You can try the new version, but you can also go back to a previous version afterwards with the commands:
                                cd MagicMirror/modules/MMM-Remote-Control # or wherever you installed the Mirror and the module
                                git checkout v1.0.0 # or the version you want
                                Currently, there is v1.0.0 (which is probably the one you are on) and v1.1.0 as older versions. To check out the most recent version use git checkout master again.
                                F 1 Reply Last reply Reply Quote 2
                                  Brice
                                  I’m experiencing a white screen issue after updating MMM-Remote to the latest version. Anyone knows how to solve this ? I’ve disabled the module for now.
                                    Jopyth Moderator @Brice
                                    @Brice Check this thread.
                                      ChrisLaurie
                                      Notifications does not obey the length parameter. I have installed this module and it looks fantastic! I have tried both the alert and notification features. The alert works and only shows for the length of time specified, but a notification displays (at the top) for only about 3 to 4 seconds and then disappears, no matter what the seconds parameter is set to.
                                        Jopyth Moderator @ChrisLaurie
                                        @ChrisLaurie That is because a notification has a fixed length of time. There is no way to change the time of a notification to be displayed longer or shorter (see documentation). Maybe I should make this more clear, that the duration option only works for an alert?
                                          Jopyth Moderator @in_a_days
                                          @in_a_days Could you check if my changes on the develop branch solve the problem?
                                          I 1 Reply Last reply Reply Quote 1
                                          • elmatttE
                                            elmattt
                                            • 13
                                            • 14
                                            • 7 / 14
