    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.5k Views 77 Watching
    • A
      AAPS
      Is it worth updating? I have been excited for this update, but I have waited to see if it would be better than the previous version. Since it appears that some people experience bugs, I might just stay with the version I have. Is this a smart choice?
      J 1 Reply Last reply
      • schlachtkreuzer6S
        schlachtkreuzer6 @in_a_days
        @in_a_days Funny I also got that bug on the previous remote version, after updating to MM v2.1 . If I´m rebooting the MM or Power Off and starting it later, all changes of visible Modules are gone. So basically i tested some modules and later hide them cause i don´t want to delete them from the config, or just show them when i need some of them. It´s not a big deal, just saying.
          Jopyth Moderator @AAPS
          @AAPS (and everyone else): You can try the new version, but you can also go back to a previous version afterwards with the commands:
          cd MagicMirror/modules/MMM-Remote-Control # or wherever you installed the Mirror and the module
          git checkout v1.0.0 # or the version you want
          Currently, there is v1.0.0 (which is probably the one you are on) and v1.1.0 as older versions. To check out the most recent version use git checkout master again.
          foxF 1 Reply Last reply
          Reply Quote 2
            Brice
            I’m experiencing a white screen issue after updating MMM-Remote to the latest version. Anyone knows how to solve this ? I’ve disabled the module for now.
              Jopyth Moderator @Brice
              @Brice Check this thread.
                ChrisLaurie
                Notifications does not obey the length parameter. I have installed this module and it looks fantastic! I have tried both the alert and notification features. The alert works and only shows for the length of time specified, but a notification displays (at the top) for only about 3 to 4 seconds and then disappears, no matter what the seconds parameter is set to.
                  Jopyth Moderator @ChrisLaurie
                  @ChrisLaurie That is because a notification has a fixed length of time. There is no way to change the time of a notification to be displayed longer or shorter (see documentation). Maybe I should make this more clear, that the duration option only works for an alert?
                  C 1 Reply Last reply
                    Jopyth Moderator @in_a_days
                    @in_a_days Could you check if my changes on the develop branch solve the problem?
                    in_a_daysI 1 Reply Last reply
                    • elmatttE
                      elmattt
                      • in_a_daysI
                        in_a_days @Jopyth
                        @Jopyth
                        Yes, the Save feature is now working for me. Thank you very much! :)
                        I still get an error when I use Power > Restart MagicMirror
                        The software does restart correctly. Seems like a false error.
                          ChrisLaurie @Jopyth
                          @Jopyth So it is a core functionality. I’m not sure hat the value is of a fixed 4 second notification is.
                            @ChrisLaurie Correct. The value is 3500 ms by default (code). This can be changed in the config of the alert module.
                            @in_a_days Yes, that is a false error, I will probably implement it, so an error after trying to restart is just ignored.
                            • foxF
                              fox @Jopyth
                              @Jopyth said in [Remote-Control] Shutdown, Configure and Update your MagicMirror:
                              I want to update. But git checkout master does not work. There stands i shall use git pull but then there comes:
                              *Please, commit your changes or stash them before you can merge.
                              Aborting
                              Issues With MMM-WatchDog known?
                              https://forum.magicmirror.builders/post/29827
                              Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                Jopyth Moderator @fox
                                @fox Interesting. What changes did you make? I will try to give you a short git crash course for your case: You can get an overview via git status (should show changed files) and git diff (showing the changes themselves). If you do not care about these changes you should be able to use git reset --hard origin/master or if you do care about them use git stash, then do git pull, and then git stash pop to apply the changes again.
                                Reply Quote 2
                                • foxF
                                  fox @Jopyth
                                  Thank you!
                                  What for a fantastic update! I tested nearly every module and everythink worked fine.
                                  You refactored also the config file during saving. Awesome! Nice job.
                                  • PatexP
                                    Patex
                                    @Jopyth I forked your project and am looking into adding the functionality to toggle back and forth between different configurations with one click using the remote page (like having a set of different config files). Is this proposed change on your to do list as well?
                                    • A
                                      AAPS
                                      Is there anything I need to do to update instead of just putting “git pull” in ~/MagicMirror/modules/MMM-Remote-Control ?
                                        @AAPS The script does git pull and npm install (therefore you need to do the npm install, if you are updating from an old version). Also it offers to switch between the develop and the master version (source).
                                        A 1 Reply Last reply
                                          Jopyth Moderator @Patex
                                          @Patex Do you want to do this with the config.js or with the settings.json (visibility of modules and brightness)? I had this idea once for the settings of visible modules and brightness, but did not implement it. Basically what other modules do with profiles defined in the config. I am not sure how much sense it makes to have multiple config.js. One (large) config.js (which includes all configured modules) and multiple “profiles” which only show a selection of these might be the way to go?
                                          • A
                                            AAPS @Jopyth
                                            @Jopyth What is the difference between develop and master version? Also, I probably sound dumb, but how do I change my ipWhitelist? Currently I have “::ffff:192.168.1.1/24” added. Do I need anything else? ( I would rather be able to access the mirror from any device )
                                            • 13
                                            • 14
                                            • 7 / 14
