    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 44.6k Views 20 Watching
    • PierreGodeP
      PierreGode Module Developer @dmykins
      @dmykins
      Hi! I have made updates. Do a git pull in the folder and it should work fine.
      • PierreGodeP
        PierreGode Module Developer @smfd_guy
        @smfd_guy
        Hi I made a new update. ( git pull in the folder)
        If you leave dateFormatting With only ”” it will not show a date
        module: “MMM-Chores”,
        position: “bottom_right”,
        header: “Chores”,
        hideYear: true,
        updateInterval: 60 * 1000,
        adminPort: 5003,
        showDays: 1, // show tasks from today and th>
        showPast: true, // also show unfinished tasks f>
        dateFormatting: “” // example: month-day, can b>
        • PierreGodeP
          PierreGode Module Developer @redbeardedninja
          @redbeardedninja
          Has been a lot of updates last 2 days. Try to go to the folder and do a git pull and restart the mm
          /Pierre
            smfd_guy @PierreGode
            I just did a new pull and tried the “” to hide the dates. I rebooted but the dates are still showing up. Not sure what I’m doing wrong…
            position: “top_left”,
            header: “Chores”,
            adminPort: 5003,
            openaiApiKey: “your-openApi-key-here”,
            hideYear:true,
            showDays: 3, // show tasks from today and the next 2 days (total 3 days)
            showPast: true, // also show unfinished tasks from past days
            dateFormatting:“” // Date format pattern to display task dates,You can use tokens like ‘yyyy’ (year), ‘mm’ (month), ‘dd’ (day), or “mm-dd-yyyy” (US style)
              JohnGalt @smfd_guy
              @smfd_guy – Same here… New install but the dates display nevertheless.
              PierreGodeP 1 Reply Last reply Reply Quote 0
                redbeardedninja
                Thanks for all the updates. I’m still unable to click on the chores to mark them as completed. I’m assuming this is an issue on my end. Has anyone else been able to mark them at completed?
                  JohnGalt @redbeardedninja
                  @redbeardedninja – Are you trying to clear the item(s) on the display screen? I tried that too, but found it can only be marked done from the admin panel.
                  R PierreGodeP 2 Replies Last reply Reply Quote 0
                    redbeardedninja @JohnGalt
                    @JohnGalt
                    Yeah, exactly what I’m trying to do. Ideally, the kids or me or whoever would be able to check off their completed chores. When I go to click the box on the display screen, I see the hand/mouse cursor but it doesn’t interact. If I have to do it from the admin panel, it sort of defeats the purpose that I’m looking for. Open to ideas of how to make this work (not that I have the skill or knowledge to accomplish that…but still).
                    J PierreGodeP 3 Replies Last reply Reply Quote 0
                      @redbeardedninja – Agreed! If the developer can make it work as you described it will be much more useable. Probably more intuitive to use, too.
                        redbeardedninja
                        @PierreGode could you clarify how this module is meant to work? Should we be able to check off things on the magic mirror, or just on the admin panel?
                        • PierreGodeP
                          PierreGode Module Developer @JohnGalt
                          @JohnGalt
                          Hi! dateFormatting: “” is now working with todays patch.
                          • PierreGodeP
                            @redbeardedninja the plan is to do everything in the admin portal. the mirror is for you to have an overview of what is done and what is left to do.
                            • PierreGodeP
                              @JohnGalt
                              if you want to remove things from the mirror you can delete them after being marked as completed. ( everything is still stored in data.json file and AI can use that as information.
                              • PierreGodeP
                                @redbeardedninja Hi! good point! I am lookin at it and started a update for it to work.
                                  redbeardedninja @PierreGode
                                  @PierreGode awesome, thanks for letting us know and working on a new way to interact with your module
                                    JohnGalt @PierreGode
                                    @PierreGode – Great! I went in and did a ‘git pull’, and indeed that functionality now works.
                                      @PierreGode – Can you clarify your comment above comment above [quoted below]? If I read this correctly, the module is exposing the data it has to be scraped by AI engines.
                                      " … everything is still stored in data.json file and AI can use that as information "
                                      • PierreGodeP
                                        @JohnGalt
                                        All tasks and peope are stored in data.json even if you delete them (softdelete) . this is so both analytics page can view history and also so the AI generate can use your completed task as information. when you press AI generate it will read the data.json and look for all completed task deleted or not, and use that to create tasks for coming week.
                                        • PierreGodeP
                                          @redbeardedninja Hi this has now being added to latest update!
                                          you can now check the checkboxes directly on the mirror it self. (touch screen also works)
                                          ( the web admin portal will not update directly unless you refresh the page)
                                          What i found hard is that the mouse is invisible on magic mirror but if you manage to find the checkboxes they will be clickable. ( meaby a setting that can be tampered with)
                                          KristjanESPERANTOK S R 3 Replies Last reply Reply Quote 0
                                          • KristjanESPERANTOK
                                            KristjanESPERANTO Module Developer @PierreGode
                                            @PierreGode said in MMM-Chores - Manage and keep track of your household Chores:
                                            MMM-Cursor can solve that 🙂
                                            • 1 / 6
