    MMM-RandomBackground, Background from local folder
    28 Posts 15 Posters 26.6k Views 18 Watching
      docmucki
      Hi, i have some warnings when I try to install this module. Can someone give me a hint what to do?
      thx,
      docmucki
      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Ultimatum22/MMM-RandomBackground.git
      Klone nach 'MMM-RandomBackground'...
      remote: Counting objects: 81, done.
      remote: Total 81 (delta 0), reused 0 (delta 0), pack-reused 81
      Entpacke Objekte: 100% (81/81), Fertig.
      Prüfe Konnektivität... Fertig.
      pi@raspberrypi:~/MagicMirror/modules $ npm install
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
      npm WARN modules No description
      npm WARN modules No repository field.
      npm WARN modules No README data
      npm WARN modules No license field.
      in_a_daysI 1 Reply Last reply Reply Quote 0
      • in_a_daysI Offline
        in_a_days @docmucki
        @docmucki
        I suspect you need to execute
        npm install
        From ~/MagicMirror/modules/MMM-RandomBackground rather than ~/MagicMirror/modules.
        Try:
        cd MMM-RandomBackground
        npm install
        D 1 Reply Last reply Reply Quote 2
          docmucki @in_a_days
          @in_a_days
          Thank you. That was the case.
            docmucki
            Changing the updateInterval seems to have no effect. Always feels like 3 seconds.
            U 1 Reply Last reply Reply Quote 0
              jfodor
              it uses milliseconds. mine is set at 900000 which is 15 minutes.
              • L Offline
                lignumaqua
                This works, but the background image is only in the top half of the screen (running portrait). Is there a way to make it fill the entire screen?
                • U Offline
                  Ultimatum22 Module Developer @docmucki
                  @docmucki What is the value you use, because it is indeed in miliseconds as jfodor said.
                  @lignumaqua Can you post your configuration for my module? It should work full screen if you look at the default ‘fullscreen_below’.
                  • L Offline
                    lignumaqua
                    • L Offline
                      lignumaqua
                      Oops! My apologies, I was getting this module confused with another. Mea culpa!
                      • foxF Offline
                        fox @Woody
                        @Woody said in Random background from local folder:
                        @Ultimatum22
                        No, not a USB storage. I mean a NAS, a cloud resourse, any SMB share.
                        Thank you for the module. Is it possible to make this working with a NAS ? And is it also possible e.g. on top_right instead of background?
                        Issues With MMM-WatchDog known?
                        https://forum.magicmirror.builders/post/29827
                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
