    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 24.9k Views 5 Watching
      sdetweil @evroom
      @evroom
      you fork
      clone fork //git clone
      make new branch // git checkout -b nane
      make code changes
      // this part multiple times
      add to files to commit // git add filename
      git commit
      git push // to add to github fork
      on github go to original repo source
      create pull request // for origin to pull changes from your fork
      if subsequent push to same branch, PR will be updated automatically
      evroomE 1 Reply Last reply
      • evroomE
        evroom @sdetweil
        @sdetweil said in MMM-Hoymiles-Wifi:
        git commit
        I am stuck here.
        Will open a new topic for it …
        MagicMirror version: 2.37.0
        • evroomE
          evroom @evroom
          Hi there,
          I made some major changes to the code and hopefully did all the GitHub stuff correct in order to allow persons interested to give it a (new) try.
          https://github.com/schris88/MMM-Hoymiles-Wifi
          There is still a lot to do (see ‘TODO’ in the README file), but I think the basis provided by Christian (@schris88) has been strengthened.
          Best regards,
          E.J.
          • evroomE
            evroom @evroom
            @schris88
            Christian,
            This is on the TODO list:
            change pv_data to dtu date for combined output of inverter
            But I do not really understand what you mean by it.
            Do you mean combined output of 2 panels iso just 1 ?
            Please elaborate.
            E.J.
              schris88 @evroom
              @evroom Hi there, maybe you can confirm, if the inverter has multiple inputs there seems to be an array of pv_data objects in the json (as seen in the test.json you pushed)
              so the meter should combine all pv data power to have the total, right.
              But we dont need to do that by hand because the combined value should be in dtu_power already, you can get rid of all the try except.
              I just didnt change it in the beginning because for inverters with only one input it makes no difference because its pv_data power and dtu_power is always the same value.
              evroomE 2 Replies Last reply
              • evroomE
                evroom @schris88
                @schris88
                First of all, those are details I need to have a look at now that the basis is there.
                Perhaps there are other values and queries that make sense and that I can use. Like dtu_power and dtu_daily_energy.
                Also saving some data to not have counters showing 0 when the invertor is inactive needs to be implemented.
                During testing I found out that the pv_data for port 1 and 2 were different sometimes and that is why I needed to add those checks.
                And they can never hurt. Better to be safe than sorry.
                Furthermore, when you have only 1 panel connected, it is needed anyway.
                • evroomE
                  evroom @schris88
                  @schris88
                  Just FYI, I declare(d) more parameters than really necessary and actually used, in order to allow for more counters to display.
                  For example a gauge for each panel; more details on the energy production of each panel; etc.
                  I will make a remark about this in the code.
                    schris88 @evroom
                    @evroom That sounds good, but we should loop through the pv_data objects and display each as a graph. In the end, there could be a config setting like detailed: true to activate the display of all pv_data objects as individual graphs. If set to false, we could display a single graph with the total power.
                    There are Hoymiles inverters with 6 inputs, and adding 6 × 6 to 8 variables can quickly add up. This might not be an issue for us, but it’s worth considering if the module should be as generic as possible.
                    Sorry I´m a IT-Consultant who, sometimes it breaks through :D
                      schris88 @schris88
                      @schris88 Recently worked on it a bit and added a second branch with local mongodb to save and display max power, Im planning to use the db entries to display a history chart
                        Jose1701
                        Hallo,
                        ich bin reltiv neu hier und versuche gerade das modul zu installieren.
                        Ich habe soweit alles nach Anleitung gemacht, aber wenn ich ./HoymilesWifi.sh starte kommt immer folgende Meldung:
                         * Serving Flask app 'hoymiles_data'
                         * Debug mode: off
                        Address already in use
                        Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
                        Was mache ich falsch? Der port ist angeblich durch pthon belegt …
                        Danke und Grüße
                        Florian
                        • evroomE
                          evroom @Jose1701
                          @Jose1701
                          Try this to find out what is using port 5000:
                          sudo netstat -apln | grep -w 5000
                          And did you update the bash program?
                          https://github.com/schris88/MMM-Hoymiles-Wifi?tab=readme-ov-file#enter-dtu-ip-address-of-dtu
                          J 1 Reply Last reply
                            Jose1701 @evroom
                            @evroom
                            Thanks for the quick answer.
                            I inserted the IP of the dtu.
                            Portscan is:
                            tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      64879/python
                            tcp        0      0 127.0.0.1:33698         127.0.0.1:5000          TIME_WAIT   -
                            tcp        0      0 127.0.0.1:5000          127.0.0.1:56374         TIME_WAIT   -
                            tcp        0      0 127.0.0.1:60100         127.0.0.1:5000          ESTABLISHED 71440/exe
                            tcp        0      0 127.0.0.1:5000          127.0.0.1:60100         ESTABLISHED 64879/python
                            tcp        0      0 127.0.0.1:52508         127.0.0.1:5000          TIME_WAIT   -
                            tcp        0      0 127.0.0.1:50296         127.0.0.1:5000          TIME_WAIT   -
                            • evroomE
                              evroom @Jose1701
                              @Jose1701
                              This command should give more information on the PID found:
                              ps -Flww -p
                              E.g.
                              ps -Flww -p 64879
                              Perhaps there are easier ways, but this should do.
                                Jose1701 @evroom
                                @evroom
                                Seems that this is hoymiles …?
                                F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
                                0 S florian    64879   64878  1  80   0 - 59630 do_sys 137520  1 16:11 ?        00:05:02 python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
                                • evroomE
                                  evroom @Jose1701
                                  @Jose1701
                                  Yes, so an instance is already running.
                                  You added it to pm2 too?
                                  pm2 status
                                  If yes, then you do not need to run it manually.
                                  If no, then kill the (p)pid.
                                  sudo kill -9 [ppid]
                                    Jose1701 @evroom
                                    @evroom
                                    Well, I’ve done that now. At the moment it is night so I can’t see any output.
                                    Will see if it works tomorrow …
                                    Thank you. I will post if it runs then.
                                    J evroomE 2 Replies Last reply
                                      Jose1701 @Jose1701
                                      Can’t get it to work.
                                      I don’t know what I’m doing wrong…
                                      Now, Portscan ist about that:
                                      tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
                                      tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
                                      tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
                                      tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
                                      • evroomE
                                        evroom @Jose1701
                                        @Jose1701
                                        First I would disable the module:
                                        $ vi ~/MagicMirror/config/config.js
                                            module: "MMM-Hoymiles-Wifi",
                                            disabled: true,
                                        $ pm2 restart MagicMirror
                                        I build this command to try to get more info on port 5000:
                                        $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
                                        Hopefully the Forum tool does not change it.
                                        Furthermore please verify and supply the following data:
                                        $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
                                        Check path:
                                        $ which hoymiles-wifi
                                        $ echo $PATH
                                        Check if the path is in the PATH.
                                        If not, do (using the path from ‘which’):
                                        $ export PATH=$PATH:/home/admin/.local/bin
                                        Check config.js:
                                        $ grep ':5000' ~/MagicMirror/config/config.js
                                        Expected is:
                                        { src: 'http://127.0.0.1:5000' },
                                        Check HoymilesWifi.sh:
                                        $ grep 'dtu_ip_address' HoymilesWifi.sh
                                        Expected is your DTU IP address, for example:
                                        python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
                                        Test run (hoymiles-wifi):
                                        $ hoymiles-wifi --host 192.168.178.50  identify-inverters
                                        Expected is a response.
                                        Test run (HoymilesWifi.sh)
                                        $ ./HoymilesWifi.sh
                                        Expected is:
                                        * Debug mode: off
                                        INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
                                        * Running on http://127.0.0.1:5000
                                        INFO:werkzeug:Press CTRL+C to quit
                                        If you wait a bit some more output is shown.
                                        If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
                                        $ pm2 start HoymilesWifi.sh
                                        $ pm2 save
                                        $ pm2 status HoymilesWifi
                                        $ pm2 logs HoymilesWifi --lines 10
                                        If everything is okay, the enable the module again:
                                            disabled: false,
                                        evroomE J 3 Replies Last reply
                                        • evroomE
                                          evroom @evroom
                                          To be honest, for me the MM does not display anything.
                                          Although it is dark, I still expected the graphic with 0 or so.
                                          Or I have to wait a bit longer.
                                          I used
                                          https://github.com/schris88/MMM-Hoymiles-Wifi/
                                          and all the above is correct and running.
                                          A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
                                          https://github.com/evroom/MMM-Hoymiles-Wifi/
                                          I will give this one a try when I have time.
                                          PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
                                            Jose1701 @evroom
                                            @evroom said in MMM-Hoymiles-Wifi:
                                            $ grep ‘dtu_ip_address’ HoymilesWifi.sh
                                            Until that line everything is ok. After that it says:
                                            grep: HoymilesWifi.sh: No such file or directory
                                            • 2 / 3
