    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 24.9k Views 5 Watching
    • evroomE
      evroom @schris88
      @schris88
      First of all, those are details I need to have a look at now that the basis is there.
      Perhaps there are other values and queries that make sense and that I can use. Like dtu_power and dtu_daily_energy.
      Also saving some data to not have counters showing 0 when the invertor is inactive needs to be implemented.
      During testing I found out that the pv_data for port 1 and 2 were different sometimes and that is why I needed to add those checks.
      And they can never hurt. Better to be safe than sorry.
      Furthermore, when you have only 1 panel connected, it is needed anyway.
      MagicMirror version: 2.37.0
      • evroomE
        evroom @schris88
        @schris88
        Just FYI, I declare(d) more parameters than really necessary and actually used, in order to allow for more counters to display.
        For example a gauge for each panel; more details on the energy production of each panel; etc.
        I will make a remark about this in the code.
          schris88 @evroom
          @evroom That sounds good, but we should loop through the pv_data objects and display each as a graph. In the end, there could be a config setting like detailed: true to activate the display of all pv_data objects as individual graphs. If set to false, we could display a single graph with the total power.
          There are Hoymiles inverters with 6 inputs, and adding 6 × 6 to 8 variables can quickly add up. This might not be an issue for us, but it’s worth considering if the module should be as generic as possible.
          Sorry I´m a IT-Consultant who, sometimes it breaks through :D
            schris88 @schris88
            @schris88 Recently worked on it a bit and added a second branch with local mongodb to save and display max power, Im planning to use the db entries to display a history chart
              Jose1701
              Hallo,
              ich bin reltiv neu hier und versuche gerade das modul zu installieren.
              Ich habe soweit alles nach Anleitung gemacht, aber wenn ich ./HoymilesWifi.sh starte kommt immer folgende Meldung:
               * Serving Flask app 'hoymiles_data'
               * Debug mode: off
              Address already in use
              Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
              Was mache ich falsch? Der port ist angeblich durch pthon belegt …
              Danke und Grüße
              Florian
              evroomE 1 Reply Last reply
              • evroomE
                evroom @Jose1701
                @Jose1701
                Try this to find out what is using port 5000:
                sudo netstat -apln | grep -w 5000
                And did you update the bash program?
                https://github.com/schris88/MMM-Hoymiles-Wifi?tab=readme-ov-file#enter-dtu-ip-address-of-dtu
                J 1 Reply Last reply
                  Jose1701 @evroom
                  @evroom
                  Thanks for the quick answer.
                  I inserted the IP of the dtu.
                  Portscan is:
                  tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      64879/python
                  tcp        0      0 127.0.0.1:33698         127.0.0.1:5000          TIME_WAIT   -
                  tcp        0      0 127.0.0.1:5000          127.0.0.1:56374         TIME_WAIT   -
                  tcp        0      0 127.0.0.1:60100         127.0.0.1:5000          ESTABLISHED 71440/exe
                  tcp        0      0 127.0.0.1:5000          127.0.0.1:60100         ESTABLISHED 64879/python
                  tcp        0      0 127.0.0.1:52508         127.0.0.1:5000          TIME_WAIT   -
                  tcp        0      0 127.0.0.1:50296         127.0.0.1:5000          TIME_WAIT   -
                  • evroomE
                    evroom @Jose1701
                    @Jose1701
                    This command should give more information on the PID found:
                    ps -Flww -p
                    E.g.
                    ps -Flww -p 64879
                    Perhaps there are easier ways, but this should do.
                      Jose1701 @evroom
                      @evroom
                      Seems that this is hoymiles …?
                      F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
                      0 S florian    64879   64878  1  80   0 - 59630 do_sys 137520  1 16:11 ?        00:05:02 python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
                      • evroomE
                        evroom @Jose1701
                        @Jose1701
                        Yes, so an instance is already running.
                        You added it to pm2 too?
                        pm2 status
                        If yes, then you do not need to run it manually.
                        If no, then kill the (p)pid.
                        sudo kill -9 [ppid]
                          Jose1701 @evroom
                          @evroom
                          Well, I’ve done that now. At the moment it is night so I can’t see any output.
                          Will see if it works tomorrow …
                          Thank you. I will post if it runs then.
                          J evroomE 2 Replies Last reply
                            Jose1701 @Jose1701
                            Can’t get it to work.
                            I don’t know what I’m doing wrong…
                            Now, Portscan ist about that:
                            tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
                            tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
                            tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
                            tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
                            • evroomE
                              evroom @Jose1701
                              @Jose1701
                              First I would disable the module:
                              $ vi ~/MagicMirror/config/config.js
                                  module: "MMM-Hoymiles-Wifi",
                                  disabled: true,
                              $ pm2 restart MagicMirror
                              I build this command to try to get more info on port 5000:
                              $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
                              Hopefully the Forum tool does not change it.
                              Furthermore please verify and supply the following data:
                              $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
                              Check path:
                              $ which hoymiles-wifi
                              $ echo $PATH
                              Check if the path is in the PATH.
                              If not, do (using the path from ‘which’):
                              $ export PATH=$PATH:/home/admin/.local/bin
                              Check config.js:
                              $ grep ':5000' ~/MagicMirror/config/config.js
                              Expected is:
                              { src: 'http://127.0.0.1:5000' },
                              Check HoymilesWifi.sh:
                              $ grep 'dtu_ip_address' HoymilesWifi.sh
                              Expected is your DTU IP address, for example:
                              python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
                              Test run (hoymiles-wifi):
                              $ hoymiles-wifi --host 192.168.178.50  identify-inverters
                              Expected is a response.
                              Test run (HoymilesWifi.sh)
                              $ ./HoymilesWifi.sh
                              Expected is:
                              * Debug mode: off
                              INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
                              * Running on http://127.0.0.1:5000
                              INFO:werkzeug:Press CTRL+C to quit
                              If you wait a bit some more output is shown.
                              If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
                              $ pm2 start HoymilesWifi.sh
                              $ pm2 save
                              $ pm2 status HoymilesWifi
                              $ pm2 logs HoymilesWifi --lines 10
                              If everything is okay, the enable the module again:
                                  disabled: false,
                              evroomE J 3 Replies Last reply
                              • evroomE
                                evroom @evroom
                                To be honest, for me the MM does not display anything.
                                Although it is dark, I still expected the graphic with 0 or so.
                                Or I have to wait a bit longer.
                                I used
                                https://github.com/schris88/MMM-Hoymiles-Wifi/
                                and all the above is correct and running.
                                A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
                                https://github.com/evroom/MMM-Hoymiles-Wifi/
                                I will give this one a try when I have time.
                                PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
                                  Jose1701 @evroom
                                  @evroom said in MMM-Hoymiles-Wifi:
                                  $ grep ‘dtu_ip_address’ HoymilesWifi.sh
                                  Until that line everything is ok. After that it says:
                                  grep: HoymilesWifi.sh: No such file or directory
                                    Jose1701 @evroom
                                    This works:
                                    Identify-inverters Response:
                                    {'1412a015f1e3': 'HMS-800W/1000W-2T'}
                                    After that: ./HoymilesWifi.sh
                                     * Debug mode: off
                                      sdetweil @Jose1701
                                      @Jose1701 typo
                                       grep 'dtu_ip_address' Hoymiles-Wifi.sh
                                        Jose1701 @sdetweil
                                        Im getting this:
                                        S evroomE 2 Replies Last reply
                                          sdetweil @Jose1701
                                          @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                                          • evroomE
                                            evroom @Jose1701
                                            @Jose1701
                                            First of all, where I write
                                            /home/admin/
                                            please use
                                            (tilde sign)
                                            And can you please send me:
                                            cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                                            git branch
                                            git remote -v
                                            Every time you get that port in use error, run the long command to see what programs are using the port.
                                            And of course do not use HoymilesWifi.sh when it is also active under pm2.
                                            I am starting to wonder if the module works at all.
                                            I finally got a picture, but it showed an error in it.
                                            • 2 / 3
