    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 21.6k Views 5 Watching
      Jose1701 @evroom
      @evroom
      Thanks for the quick answer.
      I inserted the IP of the dtu.
      Portscan is:
      tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      64879/python
      tcp        0      0 127.0.0.1:33698         127.0.0.1:5000          TIME_WAIT   -
      tcp        0      0 127.0.0.1:5000          127.0.0.1:56374         TIME_WAIT   -
      tcp        0      0 127.0.0.1:60100         127.0.0.1:5000          ESTABLISHED 71440/exe
      tcp        0      0 127.0.0.1:5000          127.0.0.1:60100         ESTABLISHED 64879/python
      tcp        0      0 127.0.0.1:52508         127.0.0.1:5000          TIME_WAIT   -
      tcp        0      0 127.0.0.1:50296         127.0.0.1:5000          TIME_WAIT   -
      • evroomE Offline
        evroom @Jose1701
        @Jose1701
        This command should give more information on the PID found:
        ps -Flww -p
        E.g.
        ps -Flww -p 64879
        Perhaps there are easier ways, but this should do.
        MagicMirror version: 2.37.0
          Jose1701 @evroom
          @evroom
          Seems that this is hoymiles …?
          F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
          0 S florian    64879   64878  1  80   0 - 59630 do_sys 137520  1 16:11 ?        00:05:02 python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
          • evroomE Offline
            evroom @Jose1701
            @Jose1701
            Yes, so an instance is already running.
            You added it to pm2 too?
            pm2 status
            If yes, then you do not need to run it manually.
            If no, then kill the (p)pid.
            sudo kill -9 [ppid]
              Jose1701 @evroom
              @evroom
              Well, I’ve done that now. At the moment it is night so I can’t see any output.
              Will see if it works tomorrow …
              Thank you. I will post if it runs then.
              J evroomE 2 Replies Last reply Reply Quote 0
                Jose1701 @Jose1701
                Can’t get it to work.
                I don’t know what I’m doing wrong…
                Now, Portscan ist about that:
                tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
                tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
                tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
                tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
                • evroomE Offline
                  evroom @Jose1701
                  @Jose1701
                  First I would disable the module:
                  $ vi ~/MagicMirror/config/config.js
                      module: "MMM-Hoymiles-Wifi",
                      disabled: true,
                  $ pm2 restart MagicMirror
                  I build this command to try to get more info on port 5000:
                  $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
                  Hopefully the Forum tool does not change it.
                  Furthermore please verify and supply the following data:
                  $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
                  Check path:
                  $ which hoymiles-wifi
                  $ echo $PATH
                  Check if the path is in the PATH.
                  If not, do (using the path from ‘which’):
                  $ export PATH=$PATH:/home/admin/.local/bin
                  Check config.js:
                  $ grep ':5000' ~/MagicMirror/config/config.js
                  Expected is:
                  { src: 'http://127.0.0.1:5000' },
                  Check HoymilesWifi.sh:
                  $ grep 'dtu_ip_address' HoymilesWifi.sh
                  Expected is your DTU IP address, for example:
                  python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
                  Test run (hoymiles-wifi):
                  $ hoymiles-wifi --host 192.168.178.50  identify-inverters
                  Expected is a response.
                  Test run (HoymilesWifi.sh)
                  $ ./HoymilesWifi.sh
                  Expected is:
                  * Serving Flask app 'hoymiles_data'
                  * Debug mode: off
                  INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
                  * Running on http://127.0.0.1:5000
                  INFO:werkzeug:Press CTRL+C to quit
                  If you wait a bit some more output is shown.
                  If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
                  $ pm2 start HoymilesWifi.sh
                  $ pm2 save
                  $ pm2 status HoymilesWifi
                  $ pm2 logs HoymilesWifi --lines 10
                  If everything is okay, the enable the module again:
                      disabled: false,
                  evroomE J 3 Replies Last reply Reply Quote 0
                  • evroomE Offline
                    evroom @evroom
                    To be honest, for me the MM does not display anything.
                    Although it is dark, I still expected the graphic with 0 or so.
                    Or I have to wait a bit longer.
                    I used
                    https://github.com/schris88/MMM-Hoymiles-Wifi/
                    and all the above is correct and running.
                    A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
                    https://github.com/evroom/MMM-Hoymiles-Wifi/
                    I will give this one a try when I have time.
                    PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
                      Jose1701 @evroom
                      @evroom said in MMM-Hoymiles-Wifi:
                      $ grep ‘dtu_ip_address’ HoymilesWifi.sh
                      Until that line everything is ok. After that it says:
                      grep: HoymilesWifi.sh: No such file or directory
                        Jose1701 @evroom
                        This works:
                        Identify-inverters Response:
                        {'1412a015f1e3': 'HMS-800W/1000W-2T'}
                        After that: ./HoymilesWifi.sh
                         * Debug mode: off
                        Address already in use
                        Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
                          sdetweil @Jose1701
                          @Jose1701 typo
                           grep 'dtu_ip_address' Hoymiles-Wifi.sh
                            Jose1701 @sdetweil
                            Im getting this:
                            S evroomE 2 Replies Last reply Reply Quote 0
                              sdetweil @Jose1701
                              @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                              • evroomE Offline
                                evroom @Jose1701
                                @Jose1701
                                First of all, where I write
                                /home/admin/
                                please use
                                (tilde sign)
                                And can you please send me:
                                cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                                git branch
                                git remote -v
                                Every time you get that port in use error, run the long command to see what programs are using the port.
                                And of course do not use HoymilesWifi.sh when it is also active under pm2.
                                I am starting to wonder if the module works at all.
                                I finally got a picture, but it showed an error in it.
                                • evroomE Offline
                                  evroom @Jose1701
                                  @Jose1701
                                  You also might try this module:
                                  https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                                  I may give it a try myself.
                                    Jose1701 @evroom
                                    @evroom
                                    * master
                                    origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
                                    origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
                                    I used the ~ symbol.
                                      Jose1701 @evroom
                                      @evroom
                                      Well I tried that but I’m to silly to install it.
                                      florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
                                      error: externally-managed-environment
                                      × This environment is externally managed
                                      ╰─> To install Python packages system-wide, try apt install
                                          python3-xyz, where xyz is the package you are trying to
                                          install.
                                          If you wish to install a non-Debian-packaged Python package,
                                          create a virtual environment using python3 -m venv path/to/venv.
                                          Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                                          sure you have python3-full installed.
                                          For more information visit http://rptl.io/venv
                                      note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                                      hint: See PEP 668 for the detailed specification.
                                      florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
                                      Error: Unable to locate package hoymiles-wifi
                                      • evroomE Offline
                                        evroom @Jose1701
                                        @Jose1701
                                        You installed that already, so no need to install it again.
                                        Probably using:
                                        python -m pip install -r requirements.txt --break-system-packages
                                        The schris88 requirements.txt contains the hoymiles-wifi package.
                                          Jose1701 @evroom
                                          @evroom
                                          By unsing this, I get the following error:
                                          Defaulting to user installation because normal site-packages is not writeable
                                          ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                                          • evroomE Offline
                                            evroom @Jose1701
                                            @Jose1701
                                            If you want to repeat it under the new module name, then you will need to copy the requirements.txt file from the previous module.
                                            But again, since you already did this, no need to repeat.
                                            • 2 / 3
