    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 23.6k Views 5 Watching
      Jose1701 @evroom
      @evroom
      Seems that this is hoymiles …?
      F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
      0 S florian    64879   64878  1  80   0 - 59630 do_sys 137520  1 16:11 ?        00:05:02 python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
      • evroomE
        evroom @Jose1701
        @Jose1701
        Yes, so an instance is already running.
        You added it to pm2 too?
        pm2 status
        If yes, then you do not need to run it manually.
        If no, then kill the (p)pid.
        sudo kill -9 [ppid]
        MagicMirror version: 2.37.0
          Jose1701 @evroom
          @evroom
          Well, I’ve done that now. At the moment it is night so I can’t see any output.
          Will see if it works tomorrow …
          Thank you. I will post if it runs then.
          J evroomE 2 Replies Last reply Reply Quote 0
            Jose1701 @Jose1701
            Can’t get it to work.
            I don’t know what I’m doing wrong…
            Now, Portscan ist about that:
            tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
            tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
            tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
            tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
            • evroomE
              evroom @Jose1701
              @Jose1701
              First I would disable the module:
              $ vi ~/MagicMirror/config/config.js
                  module: "MMM-Hoymiles-Wifi",
                  disabled: true,
              $ pm2 restart MagicMirror
              I build this command to try to get more info on port 5000:
              $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
              Hopefully the Forum tool does not change it.
              Furthermore please verify and supply the following data:
              $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
              Check path:
              $ which hoymiles-wifi
              $ echo $PATH
              Check if the path is in the PATH.
              If not, do (using the path from ‘which’):
              $ export PATH=$PATH:/home/admin/.local/bin
              Check config.js:
              $ grep ':5000' ~/MagicMirror/config/config.js
              Expected is:
              { src: 'http://127.0.0.1:5000' },
              Check HoymilesWifi.sh:
              $ grep 'dtu_ip_address' HoymilesWifi.sh
              Expected is your DTU IP address, for example:
              python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
              Test run (hoymiles-wifi):
              $ hoymiles-wifi --host 192.168.178.50  identify-inverters
              Expected is a response.
              Test run (HoymilesWifi.sh)
              $ ./HoymilesWifi.sh
              Expected is:
              * Serving Flask app 'hoymiles_data'
              * Debug mode: off
              INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
              * Running on http://127.0.0.1:5000
              INFO:werkzeug:Press CTRL+C to quit
              If you wait a bit some more output is shown.
              If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
              $ pm2 start HoymilesWifi.sh
              $ pm2 save
              $ pm2 status HoymilesWifi
              $ pm2 logs HoymilesWifi --lines 10
              If everything is okay, the enable the module again:
                  disabled: false,
              evroomE J 3 Replies Last reply Reply Quote 0
              • evroomE
                evroom @evroom
                To be honest, for me the MM does not display anything.
                Although it is dark, I still expected the graphic with 0 or so.
                Or I have to wait a bit longer.
                I used
                https://github.com/schris88/MMM-Hoymiles-Wifi/
                and all the above is correct and running.
                A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
                https://github.com/evroom/MMM-Hoymiles-Wifi/
                I will give this one a try when I have time.
                PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
                  Jose1701 @evroom
                  @evroom said in MMM-Hoymiles-Wifi:
                  $ grep ‘dtu_ip_address’ HoymilesWifi.sh
                  Until that line everything is ok. After that it says:
                  grep: HoymilesWifi.sh: No such file or directory
                    Jose1701 @evroom
                    This works:
                    Identify-inverters Response:
                    {'1412a015f1e3': 'HMS-800W/1000W-2T'}
                    After that: ./HoymilesWifi.sh
                     * Debug mode: off
                    Address already in use
                    Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
                      sdetweil @Jose1701
                      @Jose1701 typo
                       grep 'dtu_ip_address' Hoymiles-Wifi.sh
                        Jose1701 @sdetweil
                        Im getting this:
                        S evroomE 2 Replies Last reply Reply Quote 0
                          sdetweil @Jose1701
                          @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                          • evroomE
                            evroom @Jose1701
                            @Jose1701
                            First of all, where I write
                            /home/admin/
                            please use
                            (tilde sign)
                            And can you please send me:
                            cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                            git branch
                            git remote -v
                            Every time you get that port in use error, run the long command to see what programs are using the port.
                            And of course do not use HoymilesWifi.sh when it is also active under pm2.
                            I am starting to wonder if the module works at all.
                            I finally got a picture, but it showed an error in it.
                            • evroomE
                              evroom @Jose1701
                              @Jose1701
                              You also might try this module:
                              https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                              I may give it a try myself.
                                Jose1701 @evroom
                                @evroom
                                * master
                                origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
                                origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
                                I used the ~ symbol.
                                  Jose1701 @evroom
                                  @evroom
                                  Well I tried that but I’m to silly to install it.
                                  florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
                                  error: externally-managed-environment
                                  × This environment is externally managed
                                  ╰─> To install Python packages system-wide, try apt install
                                      python3-xyz, where xyz is the package you are trying to
                                      install.
                                      If you wish to install a non-Debian-packaged Python package,
                                      create a virtual environment using python3 -m venv path/to/venv.
                                      Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                                      sure you have python3-full installed.
                                      For more information visit http://rptl.io/venv
                                  note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                                  hint: See PEP 668 for the detailed specification.
                                  florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
                                  Error: Unable to locate package hoymiles-wifi
                                  • evroomE
                                    evroom @Jose1701
                                    @Jose1701
                                    You installed that already, so no need to install it again.
                                    Probably using:
                                    python -m pip install -r requirements.txt --break-system-packages
                                    The schris88 requirements.txt contains the hoymiles-wifi package.
                                      Jose1701 @evroom
                                      @evroom
                                      By unsing this, I get the following error:
                                      Defaulting to user installation because normal site-packages is not writeable
                                      ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                                      • evroomE
                                        evroom @Jose1701
                                        @Jose1701
                                        If you want to repeat it under the new module name, then you will need to copy the requirements.txt file from the previous module.
                                        But again, since you already did this, no need to repeat.
                                          Jose1701 @evroom
                                          @evroom
                                          Okay. But in the end I can’t get it to work. Don’t know whats wrong …
                                          Does this has to do with that:
                                          florian@raspberrypi:~ $ pm2 restart MagicMirror
                                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                                          [PM2] [MagicMirror](0) ✓
                                          │ id │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                          │ 1  │ HoymilesWifi    │ default     │ 2.33.0  │ fork    │ 3691100  │ 0      │ 367… │ stopped   │ 0%       │ 0b       │ florian  │ disabled │
                                          │ 0  │ MagicMirror     │ default     │ 2.33.0  │ fork    │ 3691094  │ 0s     │ 3    │ online    │ 0%       │ 3.0mb    │ florian  │ enabled  │
                                          • evroomE
                                            evroom @Jose1701
                                            @Jose1701
                                            Yeah, stopped is not good.
                                            I will need to get it working myself before I can give more useful information on what to check.
                                            Will keep you posted.
                                            • 2 / 3
