    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 23.6k Views 5 Watching
    • evroomE
      evroom @schris88
      @schris88
      Just FYI, I declare(d) more parameters than really necessary and actually used, in order to allow for more counters to display.
      For example a gauge for each panel; more details on the energy production of each panel; etc.
      I will make a remark about this in the code.
      MagicMirror version: 2.37.0
        schris88 @evroom
        @evroom That sounds good, but we should loop through the pv_data objects and display each as a graph. In the end, there could be a config setting like detailed: true to activate the display of all pv_data objects as individual graphs. If set to false, we could display a single graph with the total power.
        There are Hoymiles inverters with 6 inputs, and adding 6 × 6 to 8 variables can quickly add up. This might not be an issue for us, but it’s worth considering if the module should be as generic as possible.
        Sorry I´m a IT-Consultant who, sometimes it breaks through :D
          schris88 @schris88
          @schris88 Recently worked on it a bit and added a second branch with local mongodb to save and display max power, Im planning to use the db entries to display a history chart
            Jose1701
            Hallo,
            ich bin reltiv neu hier und versuche gerade das modul zu installieren.
            Ich habe soweit alles nach Anleitung gemacht, aber wenn ich ./HoymilesWifi.sh starte kommt immer folgende Meldung:
             * Serving Flask app 'hoymiles_data'
             * Debug mode: off
            Address already in use
            Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
            Was mache ich falsch? Der port ist angeblich durch pthon belegt …
            Danke und Grüße
            Florian
            • evroomE
              evroom @Jose1701
              @Jose1701
              Try this to find out what is using port 5000:
              sudo netstat -apln | grep -w 5000
              And did you update the bash program?
              https://github.com/schris88/MMM-Hoymiles-Wifi?tab=readme-ov-file#enter-dtu-ip-address-of-dtu
                Jose1701 @evroom
                @evroom
                Thanks for the quick answer.
                I inserted the IP of the dtu.
                Portscan is:
                tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      64879/python
                tcp        0      0 127.0.0.1:33698         127.0.0.1:5000          TIME_WAIT   -
                tcp        0      0 127.0.0.1:5000          127.0.0.1:56374         TIME_WAIT   -
                tcp        0      0 127.0.0.1:60100         127.0.0.1:5000          ESTABLISHED 71440/exe
                tcp        0      0 127.0.0.1:5000          127.0.0.1:60100         ESTABLISHED 64879/python
                tcp        0      0 127.0.0.1:52508         127.0.0.1:5000          TIME_WAIT   -
                tcp        0      0 127.0.0.1:50296         127.0.0.1:5000          TIME_WAIT   -
                • evroomE
                  evroom @Jose1701
                  @Jose1701
                  This command should give more information on the PID found:
                  ps -Flww -p
                  E.g.
                  ps -Flww -p 64879
                  Perhaps there are easier ways, but this should do.
                    Jose1701 @evroom
                    @evroom
                    Seems that this is hoymiles …?
                    F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
                    0 S florian    64879   64878  1  80   0 - 59630 do_sys 137520  1 16:11 ?        00:05:02 python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
                    • evroomE
                      evroom @Jose1701
                      @Jose1701
                      Yes, so an instance is already running.
                      You added it to pm2 too?
                      pm2 status
                      If yes, then you do not need to run it manually.
                      If no, then kill the (p)pid.
                      sudo kill -9 [ppid]
                        Jose1701 @evroom
                        @evroom
                        Well, I’ve done that now. At the moment it is night so I can’t see any output.
                        Will see if it works tomorrow …
                        Thank you. I will post if it runs then.
                        J evroomE 2 Replies Last reply Reply Quote 0
                          Jose1701 @Jose1701
                          Can’t get it to work.
                          I don’t know what I’m doing wrong…
                          Now, Portscan ist about that:
                          tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
                          tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
                          tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
                          tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
                          • evroomE
                            evroom @Jose1701
                            @Jose1701
                            First I would disable the module:
                            $ vi ~/MagicMirror/config/config.js
                                module: "MMM-Hoymiles-Wifi",
                                disabled: true,
                            $ pm2 restart MagicMirror
                            I build this command to try to get more info on port 5000:
                            $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
                            Hopefully the Forum tool does not change it.
                            Furthermore please verify and supply the following data:
                            $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
                            Check path:
                            $ which hoymiles-wifi
                            $ echo $PATH
                            Check if the path is in the PATH.
                            If not, do (using the path from ‘which’):
                            $ export PATH=$PATH:/home/admin/.local/bin
                            Check config.js:
                            $ grep ':5000' ~/MagicMirror/config/config.js
                            Expected is:
                            { src: 'http://127.0.0.1:5000' },
                            Check HoymilesWifi.sh:
                            $ grep 'dtu_ip_address' HoymilesWifi.sh
                            Expected is your DTU IP address, for example:
                            python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
                            Test run (hoymiles-wifi):
                            $ hoymiles-wifi --host 192.168.178.50  identify-inverters
                            Expected is a response.
                            Test run (HoymilesWifi.sh)
                            $ ./HoymilesWifi.sh
                            Expected is:
                            * Debug mode: off
                            INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
                            * Running on http://127.0.0.1:5000
                            INFO:werkzeug:Press CTRL+C to quit
                            If you wait a bit some more output is shown.
                            If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
                            $ pm2 start HoymilesWifi.sh
                            $ pm2 save
                            $ pm2 status HoymilesWifi
                            $ pm2 logs HoymilesWifi --lines 10
                            If everything is okay, the enable the module again:
                                disabled: false,
                            evroomE J 3 Replies Last reply Reply Quote 0
                            • evroomE
                              evroom @evroom
                              To be honest, for me the MM does not display anything.
                              Although it is dark, I still expected the graphic with 0 or so.
                              Or I have to wait a bit longer.
                              I used
                              https://github.com/schris88/MMM-Hoymiles-Wifi/
                              and all the above is correct and running.
                              A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
                              https://github.com/evroom/MMM-Hoymiles-Wifi/
                              I will give this one a try when I have time.
                              PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
                                Jose1701 @evroom
                                @evroom said in MMM-Hoymiles-Wifi:
                                $ grep ‘dtu_ip_address’ HoymilesWifi.sh
                                Until that line everything is ok. After that it says:
                                grep: HoymilesWifi.sh: No such file or directory
                                  Jose1701 @evroom
                                  This works:
                                  Identify-inverters Response:
                                  {'1412a015f1e3': 'HMS-800W/1000W-2T'}
                                  After that: ./HoymilesWifi.sh
                                   * Debug mode: off
                                    sdetweil @Jose1701
                                    @Jose1701 typo
                                     grep 'dtu_ip_address' Hoymiles-Wifi.sh
                                      Jose1701 @sdetweil
                                      Im getting this:
                                      S evroomE 2 Replies Last reply Reply Quote 0
                                        sdetweil @Jose1701
                                        @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                                        • evroomE
                                          evroom @Jose1701
                                          @Jose1701
                                          First of all, where I write
                                          /home/admin/
                                          please use
                                          (tilde sign)
                                          And can you please send me:
                                          cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                                          git branch
                                          git remote -v
                                          Every time you get that port in use error, run the long command to see what programs are using the port.
                                          And of course do not use HoymilesWifi.sh when it is also active under pm2.
                                          I am starting to wonder if the module works at all.
                                          I finally got a picture, but it showed an error in it.
                                          • evroomE
                                            evroom @Jose1701
                                            @Jose1701
                                            You also might try this module:
                                            https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                                            I may give it a try myself.
                                            • 2 / 3
