    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 23.0k Views 5 Watching
      Jose1701 @evroom
      @evroom
      Well, I’ve done that now. At the moment it is night so I can’t see any output.
      Will see if it works tomorrow …
      Thank you. I will post if it runs then.
      J evroomE 2 Replies Last reply Reply Quote 0
        Jose1701 @Jose1701
        Can’t get it to work.
        I don’t know what I’m doing wrong…
        Now, Portscan ist about that:
        tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
        tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
        tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
        tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
        • evroomE Offline
          evroom @Jose1701
          @Jose1701
          First I would disable the module:
          $ vi ~/MagicMirror/config/config.js
              module: "MMM-Hoymiles-Wifi",
              disabled: true,
          $ pm2 restart MagicMirror
          I build this command to try to get more info on port 5000:
          $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
          Hopefully the Forum tool does not change it.
          Furthermore please verify and supply the following data:
          $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
          Check path:
          $ which hoymiles-wifi
          $ echo $PATH
          Check if the path is in the PATH.
          If not, do (using the path from ‘which’):
          $ export PATH=$PATH:/home/admin/.local/bin
          Check config.js:
          $ grep ':5000' ~/MagicMirror/config/config.js
          Expected is:
          { src: 'http://127.0.0.1:5000' },
          Check HoymilesWifi.sh:
          $ grep 'dtu_ip_address' HoymilesWifi.sh
          Expected is your DTU IP address, for example:
          python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
          Test run (hoymiles-wifi):
          $ hoymiles-wifi --host 192.168.178.50  identify-inverters
          Expected is a response.
          Test run (HoymilesWifi.sh)
          $ ./HoymilesWifi.sh
          Expected is:
          * Serving Flask app 'hoymiles_data'
          * Debug mode: off
          INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
          * Running on http://127.0.0.1:5000
          INFO:werkzeug:Press CTRL+C to quit
          If you wait a bit some more output is shown.
          If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
          $ pm2 start HoymilesWifi.sh
          $ pm2 save
          $ pm2 status HoymilesWifi
          $ pm2 logs HoymilesWifi --lines 10
          If everything is okay, the enable the module again:
              disabled: false,
          MagicMirror version: 2.37.0
          evroomE J 3 Replies Last reply Reply Quote 0
          • evroomE Offline
            evroom @evroom
            To be honest, for me the MM does not display anything.
            Although it is dark, I still expected the graphic with 0 or so.
            Or I have to wait a bit longer.
            I used
            https://github.com/schris88/MMM-Hoymiles-Wifi/
            and all the above is correct and running.
            A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
            https://github.com/evroom/MMM-Hoymiles-Wifi/
            I will give this one a try when I have time.
            PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
              Jose1701 @evroom
              @evroom said in MMM-Hoymiles-Wifi:
              $ grep ‘dtu_ip_address’ HoymilesWifi.sh
              Until that line everything is ok. After that it says:
              grep: HoymilesWifi.sh: No such file or directory
                Jose1701 @evroom
                This works:
                Identify-inverters Response:
                {'1412a015f1e3': 'HMS-800W/1000W-2T'}
                After that: ./HoymilesWifi.sh
                 * Debug mode: off
                Address already in use
                Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
                  sdetweil @Jose1701
                  @Jose1701 typo
                   grep 'dtu_ip_address' Hoymiles-Wifi.sh
                    Jose1701 @sdetweil
                    Im getting this:
                    python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
                    S evroomE 2 Replies Last reply Reply Quote 0
                      sdetweil @Jose1701
                      @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                      • evroomE Offline
                        evroom @Jose1701
                        @Jose1701
                        First of all, where I write
                        /home/admin/
                        please use
                        (tilde sign)
                        And can you please send me:
                        cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                        git branch
                        git remote -v
                        Every time you get that port in use error, run the long command to see what programs are using the port.
                        And of course do not use HoymilesWifi.sh when it is also active under pm2.
                        I am starting to wonder if the module works at all.
                        I finally got a picture, but it showed an error in it.
                        • evroomE Offline
                          evroom @Jose1701
                          @Jose1701
                          You also might try this module:
                          https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                          I may give it a try myself.
                            Jose1701 @evroom
                            @evroom
                            * master
                            origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
                            origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
                            I used the ~ symbol.
                              Jose1701 @evroom
                              @evroom
                              Well I tried that but I’m to silly to install it.
                              florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
                              error: externally-managed-environment
                              × This environment is externally managed
                              ╰─> To install Python packages system-wide, try apt install
                                  python3-xyz, where xyz is the package you are trying to
                                  install.
                                  If you wish to install a non-Debian-packaged Python package,
                                  create a virtual environment using python3 -m venv path/to/venv.
                                  Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                                  sure you have python3-full installed.
                                  For more information visit http://rptl.io/venv
                              note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                              hint: See PEP 668 for the detailed specification.
                              florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
                              Error: Unable to locate package hoymiles-wifi
                              • evroomE Offline
                                evroom @Jose1701
                                @Jose1701
                                You installed that already, so no need to install it again.
                                Probably using:
                                python -m pip install -r requirements.txt --break-system-packages
                                The schris88 requirements.txt contains the hoymiles-wifi package.
                                  Jose1701 @evroom
                                  @evroom
                                  By unsing this, I get the following error:
                                  Defaulting to user installation because normal site-packages is not writeable
                                  ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                                  • evroomE Offline
                                    evroom @Jose1701
                                    @Jose1701
                                    If you want to repeat it under the new module name, then you will need to copy the requirements.txt file from the previous module.
                                    But again, since you already did this, no need to repeat.
                                      Jose1701 @evroom
                                      @evroom
                                      Okay. But in the end I can’t get it to work. Don’t know whats wrong …
                                      Does this has to do with that:
                                      florian@raspberrypi:~ $ pm2 restart MagicMirror
                                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                                      [PM2] [MagicMirror](0) ✓
                                      │ id │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                      │ 1  │ HoymilesWifi    │ default     │ 2.33.0  │ fork    │ 3691100  │ 0      │ 367… │ stopped   │ 0%       │ 0b       │ florian  │ disabled │
                                      │ 0  │ MagicMirror     │ default     │ 2.33.0  │ fork    │ 3691094  │ 0s     │ 3    │ online    │ 0%       │ 3.0mb    │ florian  │ enabled  │
                                      • evroomE Offline
                                        evroom @Jose1701
                                        @Jose1701
                                        Yeah, stopped is not good.
                                        I will need to get it working myself before I can give more useful information on what to check.
                                        Will keep you posted.
                                        • evroomE Offline
                                          evroom @evroom
                                          @Jose1701
                                          Remove the old module from the config:
                                          Remove the "MMM-Hoymiles-Wifi" config, or set:
                                              disabled: true,
                                          Delete HoymilesWifi from pm2:
                                          $ pm2 stop HoymilesWifi
                                          $ pm2 delete HoymilesWifi
                                          $ pm2 save
                                          If desired, completely remove the old module:
                                          $ cd ~/MagicMirror/modules/
                                          $ rm -rf MMM-Hoymiles-Wifi
                                          Install MMM-HoymilesPVMonitor:
                                          $ git clone https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git
                                          $ cd MMM-HoymilesPVMonitor
                                          $ git branch
                                          * main
                                          $ git remote -v
                                          origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (fetch)
                                          origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (push)
                                          /home/admin/.local/bin/hoymiles-wifi
                                          $ echo $PATH
                                          /home/admin/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                              module: "MMM-HoymilesPVMonitor",
                                              disabled: false,
                                              header: "PV Monitor",
                                                dtuIp: "192.168.178.50",        // IP address of your Hoymiles DTU
                                                maxPower: 800,                  // Maximum system power in watts
                                                updateInterval: 5 * 60 * 1000   // Update interval in milliseconds (default: 5 minutes)
                                          $ grep 'dtuIp' ~/MagicMirror/config/config.js
                                          $ ls -als public/history_daily.json
                                          4 -rw-r--r-- 1 admin admin 115 Nov  6 08:47 public/history_daily.json
                                          $ cat public/history_daily.json
                                              "timestamp": "2025-11-06 08:47",
                                              "power": 40,
                                              "energy_daily": 0.03,
                                              "energy_total": 0.8
                                          $ pm2 flush
                                          $ pm2 status MagicMirror
                                          │ 0  │ MagicMirror    │ default     │ 2.33.0  │ fork    │ 26202    │ 4m     │ 3    │ online    │ 0%       │ 2.1mb    │ admin    │ enabled  │
                                          $ pm2 logs MagicMirror --lines 100
                                          0|MagicMir | [2025-11-06 08:47:43.474] [INFO]  [MMM-HoymilesPVMonitor.js:17:9] MMM-HoymilesPVMonitor started with DTU-IP: 192.168.178.50
                                          0|MagicMir | [2025-11-06 08:47:49.226] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                                          0|MagicMir | [2025-11-06 08:47:51.682] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [WARNING] Could not load history: Expecting value: line 2 column 1 (char 1)
                                          0|MagicMir | [2025-11-06 08:47] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:47', 'power': 40, 'energy_daily': 0.03, 'energy_total': 0.8}
                                          0|MagicMir | [2025-11-06 08:52:42.141] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                                          0|MagicMir | [2025-11-06 08:52:43.287] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [2025-11-06 08:52] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:52', 'power': 41, 'energy_daily': 0.03, 'energy_total': 0.8}
                                              "power": 40,
                                              "energy_total": 0.8
                                              "timestamp": "2025-11-06 08:52",
                                              "power": 41,
                                              "energy_total": 0.8
                                          Tested on:
                                          $ cat /proc/device-tree/model; echo
                                          Raspberry Pi 3 Model B Plus Rev 1.3
                                          $ vcgencmd get_config total_mem
                                          total_mem=1024
                                          $ grep version ~/MagicMirror/package.json
                                          	"version": "2.33.0",
                                            Jose1701 @evroom
                                            @evroom
                                            Great job! It could work for me. Unfortunately it’s dark outside but I can see the gauge on my mirror.
                                            I don’t even dare to ask, but do you have a hint how about resizing it? I tried it with width and height but it won’t work.
                                                disabled: false,
                                                width: "100px",
                                                height: "105px",
                                                  dtuIp: "192.168.178.150",        // IP address of your Hoymiles DTU
                                            Many thanks and kind regards
                                            Florian
                                            • 3 / 3
