    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 14.4k Views 5 Watching
    • evroomE Offline
      evroom @evroom
      To be honest, for me the MM does not display anything.
      Although it is dark, I still expected the graphic with 0 or so.
      Or I have to wait a bit longer.
      I used
      https://github.com/schris88/MMM-Hoymiles-Wifi/
      and all the above is correct and running.
      A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
      https://github.com/evroom/MMM-Hoymiles-Wifi/
      I will give this one a try when I have time.
      PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
      MagicMirror version: 2.36.0
        Jose1701 @evroom
        @evroom said in MMM-Hoymiles-Wifi:
        $ grep ‘dtu_ip_address’ HoymilesWifi.sh
        Until that line everything is ok. After that it says:
        grep: HoymilesWifi.sh: No such file or directory
          Jose1701 @evroom
          $ hoymiles-wifi --host 192.168.178.50 identify-inverters
          This works:
          Identify-inverters Response:
          {'1412a015f1e3': 'HMS-800W/1000W-2T'}
          After that: ./HoymilesWifi.sh
           * Serving Flask app 'hoymiles_data'
           * Debug mode: off
          Address already in use
          Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
            sdetweil @Jose1701
            @Jose1701 typo
             grep 'dtu_ip_address' Hoymiles-Wifi.sh
              Jose1701 @sdetweil
              Im getting this:
              python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
              S evroomE 2 Replies Last reply Reply Quote 0
                sdetweil @Jose1701
                @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                • evroomE Offline
                  evroom @Jose1701
                  @Jose1701
                  First of all, where I write
                  /home/admin/
                  please use
                  (tilde sign)
                  And can you please send me:
                  cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                  git branch
                  git remote -v
                  Every time you get that port in use error, run the long command to see what programs are using the port.
                  And of course do not use HoymilesWifi.sh when it is also active under pm2.
                  I am starting to wonder if the module works at all.
                  I finally got a picture, but it showed an error in it.
                  • evroomE Offline
                    evroom @Jose1701
                    @Jose1701
                    You also might try this module:
                    https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                    I may give it a try myself.
                      Jose1701 @evroom
                      @evroom
                      * master
                      origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
                      origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
                      I used the ~ symbol.
                        Jose1701 @evroom
                        @evroom
                        Well I tried that but I’m to silly to install it.
                        florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
                        error: externally-managed-environment
                        × This environment is externally managed
                        ╰─> To install Python packages system-wide, try apt install
                            python3-xyz, where xyz is the package you are trying to
                            install.
                            If you wish to install a non-Debian-packaged Python package,
                            create a virtual environment using python3 -m venv path/to/venv.
                            Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                            sure you have python3-full installed.
                            For more information visit http://rptl.io/venv
                        note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                        hint: See PEP 668 for the detailed specification.
                        florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
                        Error: Unable to locate package hoymiles-wifi
                        • evroomE Offline
                          evroom @Jose1701
                          @Jose1701
                          You installed that already, so no need to install it again.
                          Probably using:
                          python -m pip install -r requirements.txt --break-system-packages
                          The schris88 requirements.txt contains the hoymiles-wifi package.
                            Jose1701 @evroom
                            @evroom
                            By unsing this, I get the following error:
                            Defaulting to user installation because normal site-packages is not writeable
                            ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                            • evroomE Offline
                              evroom @Jose1701
                              @Jose1701
                              If you want to repeat it under the new module name, then you will need to copy the requirements.txt file from the previous module.
                              But again, since you already did this, no need to repeat.
                                Jose1701 @evroom
                                @evroom
                                Okay. But in the end I can’t get it to work. Don’t know whats wrong …
                                Does this has to do with that:
                                florian@raspberrypi:~ $ pm2 restart MagicMirror
                                [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                                [PM2] [MagicMirror](0) ✓
                                │ id │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                │ 1  │ HoymilesWifi    │ default     │ 2.33.0  │ fork    │ 3691100  │ 0      │ 367… │ stopped   │ 0%       │ 0b       │ florian  │ disabled │
                                │ 0  │ MagicMirror     │ default     │ 2.33.0  │ fork    │ 3691094  │ 0s     │ 3    │ online    │ 0%       │ 3.0mb    │ florian  │ enabled  │
                                • evroomE Offline
                                  evroom @Jose1701
                                  @Jose1701
                                  Yeah, stopped is not good.
                                  I will need to get it working myself before I can give more useful information on what to check.
                                  Will keep you posted.
                                  • evroomE Offline
                                    evroom @evroom
                                    @Jose1701
                                    Remove the old module from the config:
                                    $ vi ~/MagicMirror/config/config.js
                                    Remove the "MMM-Hoymiles-Wifi" config, or set:
                                        module: "MMM-Hoymiles-Wifi"
                                        disabled: true,
                                    Delete HoymilesWifi from pm2:
                                    $ pm2 stop HoymilesWifi
                                    $ pm2 delete HoymilesWifi
                                    $ pm2 save
                                    If desired, completely remove the old module:
                                    $ cd ~/MagicMirror/modules/
                                    $ rm -rf MMM-Hoymiles-Wifi
                                    Install MMM-HoymilesPVMonitor:
                                    $ git clone https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git
                                    $ cd MMM-HoymilesPVMonitor
                                    $ git branch
                                    * main
                                    $ git remote -v
                                    origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (fetch)
                                    origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (push)
                                    $ which hoymiles-wifi
                                    /home/admin/.local/bin/hoymiles-wifi
                                    $ echo $PATH
                                    /home/admin/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                        module: "MMM-HoymilesPVMonitor",
                                        disabled: false,
                                        header: "PV Monitor",
                                          dtuIp: "192.168.178.50",        // IP address of your Hoymiles DTU
                                          maxPower: 800,                  // Maximum system power in watts
                                          updateInterval: 5 * 60 * 1000   // Update interval in milliseconds (default: 5 minutes)
                                    $ grep 'dtuIp' ~/MagicMirror/config/config.js
                                    $ ls -als public/history_daily.json
                                    4 -rw-r--r-- 1 admin admin 115 Nov  6 08:47 public/history_daily.json
                                    $ cat public/history_daily.json
                                        "timestamp": "2025-11-06 08:47",
                                        "power": 40,
                                        "energy_daily": 0.03,
                                        "energy_total": 0.8
                                    $ pm2 flush
                                    $ pm2 status MagicMirror
                                    │ 0  │ MagicMirror    │ default     │ 2.33.0  │ fork    │ 26202    │ 4m     │ 3    │ online    │ 0%       │ 2.1mb    │ admin    │ enabled  │
                                    $ pm2 logs MagicMirror --lines 100
                                    0|MagicMir | [2025-11-06 08:47:43.474] [INFO]  [MMM-HoymilesPVMonitor.js:17:9] MMM-HoymilesPVMonitor started with DTU-IP: 192.168.178.50
                                    0|MagicMir | [2025-11-06 08:47:49.226] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                                    0|MagicMir | [2025-11-06 08:47:51.682] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [WARNING] Could not load history: Expecting value: line 2 column 1 (char 1)
                                    0|MagicMir | [2025-11-06 08:47] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:47', 'power': 40, 'energy_daily': 0.03, 'energy_total': 0.8}
                                    0|MagicMir | [2025-11-06 08:52:42.141] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                                    0|MagicMir | [2025-11-06 08:52:43.287] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [2025-11-06 08:52] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:52', 'power': 41, 'energy_daily': 0.03, 'energy_total': 0.8}
                                        "power": 40,
                                        "energy_total": 0.8
                                        "timestamp": "2025-11-06 08:52",
                                        "power": 41,
                                        "energy_total": 0.8
                                    Tested on:
                                    $ cat /proc/device-tree/model; echo
                                    Raspberry Pi 3 Model B Plus Rev 1.3
                                    $ vcgencmd get_config total_mem
                                    total_mem=1024
                                    $ grep version ~/MagicMirror/package.json
                                    	"version": "2.33.0",
                                      Jose1701 @evroom
                                      @evroom
                                      Great job! It could work for me. Unfortunately it’s dark outside but I can see the gauge on my mirror.
                                      I don’t even dare to ask, but do you have a hint how about resizing it? I tried it with width and height but it won’t work.
                                          disabled: false,
                                          width: "100px",
                                          height: "105px",
                                            dtuIp: "192.168.178.150",        // IP address of your Hoymiles DTU
                                      Many thanks and kind regards
                                      Florian
                                        sdetweil @Jose1701
                                        @Jose1701 said in MMM-Hoymiles-Wifi:
                                        width: "100px",
                                        height: "105px",
                                        those are outside the config:{} section, that means they are for the MM runtime…
                                        but we don’t process width/height
                                        if you want to do this you need to learn to use css(cascading style sheet) to customize the html presentation
                                        ALL updated css goes in css/custom.css
                                        a css entry in custom.css is
                                        selector_clause {
                                           styles to apply to elements selected by the selector clause
                                        we add the modulename as a class to the web content so that one can ‘select’ only for that module
                                        key selector clause elements
                                        starts with . means element has classname=xxx
                                        starts with # means element has id=xxxx
                                        does not start with either, means html element name, div, span, p, h1, img…
                                          Jose1701 @sdetweil
                                          Alright, I will try to get some info in the internet. Never done sth with css.
                                            sdetweil @Jose1701
                                            @Jose1701 I understand , the browser provides a developer environment with different capabilities
                                            logger
                                            code execution
                                            and elements viewer, css tester env
                                            see the second link in my signature below for a starter course on the elements tab.
                                            • 3 / 3
