    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 23.6k Views 5 Watching
      sdetweil @Jose1701
      @Jose1701 typo
       grep 'dtu_ip_address' Hoymiles-Wifi.sh
        Jose1701 @sdetweil
        Im getting this:
        python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
        S evroomE 2 Replies Last reply Reply Quote 0
          sdetweil @Jose1701
          @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
          • evroomE
            evroom @Jose1701
            @Jose1701
            First of all, where I write
            /home/admin/
            please use
            (tilde sign)
            And can you please send me:
            cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
            git branch
            git remote -v
            Every time you get that port in use error, run the long command to see what programs are using the port.
            And of course do not use HoymilesWifi.sh when it is also active under pm2.
            I am starting to wonder if the module works at all.
            I finally got a picture, but it showed an error in it.
            MagicMirror version: 2.37.0
            • evroomE
              evroom @Jose1701
              @Jose1701
              You also might try this module:
              https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
              I may give it a try myself.
                Jose1701 @evroom
                @evroom
                * master
                origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
                origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
                I used the ~ symbol.
                  Jose1701 @evroom
                  @evroom
                  Well I tried that but I’m to silly to install it.
                  florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
                  error: externally-managed-environment
                  × This environment is externally managed
                  ╰─> To install Python packages system-wide, try apt install
                      python3-xyz, where xyz is the package you are trying to
                      install.
                      If you wish to install a non-Debian-packaged Python package,
                      create a virtual environment using python3 -m venv path/to/venv.
                      Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                      sure you have python3-full installed.
                      For more information visit http://rptl.io/venv
                  note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                  hint: See PEP 668 for the detailed specification.
                  florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
                  Error: Unable to locate package hoymiles-wifi
                  • evroomE
                    evroom @Jose1701
                    @Jose1701
                    You installed that already, so no need to install it again.
                    Probably using:
                    python -m pip install -r requirements.txt --break-system-packages
                    The schris88 requirements.txt contains the hoymiles-wifi package.
                      Jose1701 @evroom
                      @evroom
                      By unsing this, I get the following error:
                      Defaulting to user installation because normal site-packages is not writeable
                      ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                      • evroomE
                        evroom @Jose1701
                        @Jose1701
                        If you want to repeat it under the new module name, then you will need to copy the requirements.txt file from the previous module.
                        But again, since you already did this, no need to repeat.
                          Jose1701 @evroom
                          @evroom
                          Okay. But in the end I can’t get it to work. Don’t know whats wrong …
                          Does this has to do with that:
                          florian@raspberrypi:~ $ pm2 restart MagicMirror
                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                          [PM2] [MagicMirror](0) ✓
                          │ id │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                          │ 1  │ HoymilesWifi    │ default     │ 2.33.0  │ fork    │ 3691100  │ 0      │ 367… │ stopped   │ 0%       │ 0b       │ florian  │ disabled │
                          │ 0  │ MagicMirror     │ default     │ 2.33.0  │ fork    │ 3691094  │ 0s     │ 3    │ online    │ 0%       │ 3.0mb    │ florian  │ enabled  │
                          • evroomE
                            evroom @Jose1701
                            @Jose1701
                            Yeah, stopped is not good.
                            I will need to get it working myself before I can give more useful information on what to check.
                            Will keep you posted.
                            • evroomE
                              evroom @evroom
                              @Jose1701
                              Remove the old module from the config:
                              $ vi ~/MagicMirror/config/config.js
                              Remove the "MMM-Hoymiles-Wifi" config, or set:
                                  module: "MMM-Hoymiles-Wifi"
                                  disabled: true,
                              Delete HoymilesWifi from pm2:
                              $ pm2 stop HoymilesWifi
                              $ pm2 delete HoymilesWifi
                              $ pm2 save
                              If desired, completely remove the old module:
                              $ cd ~/MagicMirror/modules/
                              $ rm -rf MMM-Hoymiles-Wifi
                              Install MMM-HoymilesPVMonitor:
                              $ git clone https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git
                              $ cd MMM-HoymilesPVMonitor
                              $ git branch
                              * main
                              $ git remote -v
                              origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (fetch)
                              origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (push)
                              $ which hoymiles-wifi
                              /home/admin/.local/bin/hoymiles-wifi
                              $ echo $PATH
                              /home/admin/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                  module: "MMM-HoymilesPVMonitor",
                                  disabled: false,
                                  header: "PV Monitor",
                                    dtuIp: "192.168.178.50",        // IP address of your Hoymiles DTU
                                    maxPower: 800,                  // Maximum system power in watts
                                    updateInterval: 5 * 60 * 1000   // Update interval in milliseconds (default: 5 minutes)
                              $ grep 'dtuIp' ~/MagicMirror/config/config.js
                              $ ls -als public/history_daily.json
                              4 -rw-r--r-- 1 admin admin 115 Nov  6 08:47 public/history_daily.json
                              $ cat public/history_daily.json
                                  "timestamp": "2025-11-06 08:47",
                                  "power": 40,
                                  "energy_daily": 0.03,
                                  "energy_total": 0.8
                              $ pm2 flush
                              $ pm2 status MagicMirror
                              │ 0  │ MagicMirror    │ default     │ 2.33.0  │ fork    │ 26202    │ 4m     │ 3    │ online    │ 0%       │ 2.1mb    │ admin    │ enabled  │
                              $ pm2 logs MagicMirror --lines 100
                              0|MagicMir | [2025-11-06 08:47:43.474] [INFO]  [MMM-HoymilesPVMonitor.js:17:9] MMM-HoymilesPVMonitor started with DTU-IP: 192.168.178.50
                              0|MagicMir | [2025-11-06 08:47:49.226] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                              0|MagicMir | [2025-11-06 08:47:51.682] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [WARNING] Could not load history: Expecting value: line 2 column 1 (char 1)
                              0|MagicMir | [2025-11-06 08:47] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:47', 'power': 40, 'energy_daily': 0.03, 'energy_total': 0.8}
                              0|MagicMir | [2025-11-06 08:52:42.141] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                              0|MagicMir | [2025-11-06 08:52:43.287] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [2025-11-06 08:52] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:52', 'power': 41, 'energy_daily': 0.03, 'energy_total': 0.8}
                                  "power": 40,
                                  "energy_total": 0.8
                                  "timestamp": "2025-11-06 08:52",
                                  "power": 41,
                                  "energy_total": 0.8
                              Tested on:
                              $ cat /proc/device-tree/model; echo
                              Raspberry Pi 3 Model B Plus Rev 1.3
                              $ vcgencmd get_config total_mem
                              total_mem=1024
                              $ grep version ~/MagicMirror/package.json
                              	"version": "2.33.0",
                                Jose1701 @evroom
                                @evroom
                                Great job! It could work for me. Unfortunately it’s dark outside but I can see the gauge on my mirror.
                                I don’t even dare to ask, but do you have a hint how about resizing it? I tried it with width and height but it won’t work.
                                    disabled: false,
                                    width: "100px",
                                    height: "105px",
                                      dtuIp: "192.168.178.150",        // IP address of your Hoymiles DTU
                                Many thanks and kind regards
                                Florian
                                  sdetweil @Jose1701
                                  @Jose1701 said in MMM-Hoymiles-Wifi:
                                  width: "100px",
                                  height: "105px",
                                  those are outside the config:{} section, that means they are for the MM runtime…
                                  but we don’t process width/height
                                  if you want to do this you need to learn to use css(cascading style sheet) to customize the html presentation
                                  ALL updated css goes in css/custom.css
                                  a css entry in custom.css is
                                  selector_clause {
                                     styles to apply to elements selected by the selector clause
                                  we add the modulename as a class to the web content so that one can ‘select’ only for that module
                                  key selector clause elements
                                  starts with . means element has classname=xxx
                                  starts with # means element has id=xxxx
                                  does not start with either, means html element name, div, span, p, h1, img…
                                    Jose1701 @sdetweil
                                    Alright, I will try to get some info in the internet. Never done sth with css.
                                      sdetweil @Jose1701
                                      @Jose1701 I understand , the browser provides a developer environment with different capabilities
                                      logger
                                      code execution
                                      and elements viewer, css tester env
                                      see the second link in my signature below for a starter course on the elements tab.
                                      • evroomE
                                        evroom @Jose1701
                                        @Jose1701
                                        No, sorry, no idea.
                                        What Sam says, but that needs knowledge.
                                        But I opened an issue/request, so let’s see if it will be granted:
                                        https://github.com/CuddlyCow/MMM-HoymilesPVMonitor/issues
                                          Jose1701 @evroom
                                          @evroom
                                          ok. Thank you for your patience and help.
                                            sdetweil @Jose1701
                                            @Jose1701 also. Sometimes the author documents it on the readme, sometimes the author provides their own css you can override w custom.css entries
                                            Sometimes it’s all grunt work….
                                            • 3 / 3
