    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 24.9k Views 5 Watching
      Jose1701 @evroom
      @evroom said in MMM-Hoymiles-Wifi:
      $ grep ‘dtu_ip_address’ HoymilesWifi.sh
      Until that line everything is ok. After that it says:
      grep: HoymilesWifi.sh: No such file or directory
        Jose1701 @evroom
        $ hoymiles-wifi --host 192.168.178.50 identify-inverters
        This works:
        Identify-inverters Response:
        {'1412a015f1e3': 'HMS-800W/1000W-2T'}
        After that: ./HoymilesWifi.sh
         * Serving Flask app 'hoymiles_data'
         * Debug mode: off
        Address already in use
        Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
          sdetweil @Jose1701
          @Jose1701 typo
           grep 'dtu_ip_address' Hoymiles-Wifi.sh
          J 1 Reply Last reply
            Jose1701 @sdetweil
            Im getting this:
            python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
            S evroomE 2 Replies Last reply
              sdetweil @Jose1701
              @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
              • evroomE
                evroom @Jose1701
                @Jose1701
                First of all, where I write
                /home/admin/
                please use
                (tilde sign)
                And can you please send me:
                cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                git branch
                git remote -v
                Every time you get that port in use error, run the long command to see what programs are using the port.
                And of course do not use HoymilesWifi.sh when it is also active under pm2.
                I am starting to wonder if the module works at all.
                I finally got a picture, but it showed an error in it.
                MagicMirror version: 2.37.0
                • evroomE
                  evroom @Jose1701
                  @Jose1701
                  You also might try this module:
                  https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                  I may give it a try myself.
                    Jose1701 @evroom
                    @evroom
                    * master
                    origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
                    origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
                    I used the ~ symbol.
                      Jose1701 @evroom
                      @evroom
                      Well I tried that but I’m to silly to install it.
                      florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
                      error: externally-managed-environment
                      × This environment is externally managed
                      ╰─> To install Python packages system-wide, try apt install
                          python3-xyz, where xyz is the package you are trying to
                          install.
                          If you wish to install a non-Debian-packaged Python package,
                          create a virtual environment using python3 -m venv path/to/venv.
                          Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                          sure you have python3-full installed.
                          For more information visit http://rptl.io/venv
                      note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                      hint: See PEP 668 for the detailed specification.
                      florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
                      Error: Unable to locate package hoymiles-wifi
                      evroomE 1 Reply Last reply
                      • evroomE
                        evroom @Jose1701
                        @Jose1701
                        You installed that already, so no need to install it again.
                        Probably using:
                        python -m pip install -r requirements.txt --break-system-packages
                        The schris88 requirements.txt contains the hoymiles-wifi package.
                          Jose1701 @evroom
                          @evroom
                          By unsing this, I get the following error:
                          Defaulting to user installation because normal site-packages is not writeable
                          ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                          • evroomE
                            evroom @Jose1701
                            @Jose1701
                            If you want to repeat it under the new module name, then you will need to copy the requirements.txt file from the previous module.
                            But again, since you already did this, no need to repeat.
                              Jose1701 @evroom
                              @evroom
                              Okay. But in the end I can’t get it to work. Don’t know whats wrong …
                              Does this has to do with that:
                              florian@raspberrypi:~ $ pm2 restart MagicMirror
                              [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                              [PM2] [MagicMirror](0) ✓
                              │ id │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                              │ 1  │ HoymilesWifi    │ default     │ 2.33.0  │ fork    │ 3691100  │ 0      │ 367… │ stopped   │ 0%       │ 0b       │ florian  │ disabled │
                              │ 0  │ MagicMirror     │ default     │ 2.33.0  │ fork    │ 3691094  │ 0s     │ 3    │ online    │ 0%       │ 3.0mb    │ florian  │ enabled  │
                              • evroomE
                                evroom @Jose1701
                                @Jose1701
                                Yeah, stopped is not good.
                                I will need to get it working myself before I can give more useful information on what to check.
                                Will keep you posted.
                                • evroomE
                                  evroom @evroom
                                  @Jose1701
                                  Remove the old module from the config:
                                  $ vi ~/MagicMirror/config/config.js
                                  Remove the "MMM-Hoymiles-Wifi" config, or set:
                                      module: "MMM-Hoymiles-Wifi"
                                      disabled: true,
                                  Delete HoymilesWifi from pm2:
                                  $ pm2 stop HoymilesWifi
                                  $ pm2 delete HoymilesWifi
                                  $ pm2 save
                                  If desired, completely remove the old module:
                                  $ cd ~/MagicMirror/modules/
                                  $ rm -rf MMM-Hoymiles-Wifi
                                  Install MMM-HoymilesPVMonitor:
                                  $ git clone https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git
                                  $ cd MMM-HoymilesPVMonitor
                                  $ git branch
                                  * main
                                  $ git remote -v
                                  origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (fetch)
                                  origin	https://github.com/CuddlyCow/MMM-HoymilesPVMonitor.git (push)
                                  $ which hoymiles-wifi
                                  /home/admin/.local/bin/hoymiles-wifi
                                  $ echo $PATH
                                  /home/admin/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                      module: "MMM-HoymilesPVMonitor",
                                      disabled: false,
                                      header: "PV Monitor",
                                        dtuIp: "192.168.178.50",        // IP address of your Hoymiles DTU
                                        maxPower: 800,                  // Maximum system power in watts
                                        updateInterval: 5 * 60 * 1000   // Update interval in milliseconds (default: 5 minutes)
                                  $ grep 'dtuIp' ~/MagicMirror/config/config.js
                                  $ ls -als public/history_daily.json
                                  4 -rw-r--r-- 1 admin admin 115 Nov  6 08:47 public/history_daily.json
                                  $ cat public/history_daily.json
                                      "timestamp": "2025-11-06 08:47",
                                      "power": 40,
                                      "energy_daily": 0.03,
                                      "energy_total": 0.8
                                  $ pm2 flush
                                  $ pm2 status MagicMirror
                                  │ 0  │ MagicMirror    │ default     │ 2.33.0  │ fork    │ 26202    │ 4m     │ 3    │ online    │ 0%       │ 2.1mb    │ admin    │ enabled  │
                                  $ pm2 logs MagicMirror --lines 100
                                  0|MagicMir | [2025-11-06 08:47:43.474] [INFO]  [MMM-HoymilesPVMonitor.js:17:9] MMM-HoymilesPVMonitor started with DTU-IP: 192.168.178.50
                                  0|MagicMir | [2025-11-06 08:47:49.226] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                                  0|MagicMir | [2025-11-06 08:47:51.682] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [WARNING] Could not load history: Expecting value: line 2 column 1 (char 1)
                                  0|MagicMir | [2025-11-06 08:47] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:47', 'power': 40, 'energy_daily': 0.03, 'energy_total': 0.8}
                                  0|MagicMir | [2025-11-06 08:52:42.141] [LOG]   [MMM-HoymilesPVMonitor] Running Python script: python3 /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/dtu_data.py --ip 192.168.178.50 --max 800 --out /home/admin/MagicMirror/modules/MMM-HoymilesPVMonitor/public/history_daily.json
                                  0|MagicMir | [2025-11-06 08:52:43.287] [LOG]   [MMM-HoymilesPVMonitor] Python script output: [2025-11-06 08:52] [INFO] Live DTU data appended: {'timestamp': '2025-11-06 08:52', 'power': 41, 'energy_daily': 0.03, 'energy_total': 0.8}
                                      "power": 40,
                                      "energy_total": 0.8
                                      "timestamp": "2025-11-06 08:52",
                                      "power": 41,
                                      "energy_total": 0.8
                                  Tested on:
                                  $ cat /proc/device-tree/model; echo
                                  Raspberry Pi 3 Model B Plus Rev 1.3
                                  $ vcgencmd get_config total_mem
                                  total_mem=1024
                                  $ grep version ~/MagicMirror/package.json
                                  	"version": "2.33.0",
                                    Jose1701 @evroom
                                    @evroom
                                    Great job! It could work for me. Unfortunately it’s dark outside but I can see the gauge on my mirror.
                                    I don’t even dare to ask, but do you have a hint how about resizing it? I tried it with width and height but it won’t work.
                                        disabled: false,
                                        width: "100px",
                                        height: "105px",
                                          dtuIp: "192.168.178.150",        // IP address of your Hoymiles DTU
                                    Many thanks and kind regards
                                    Florian
                                      sdetweil @Jose1701
                                      @Jose1701 said in MMM-Hoymiles-Wifi:
                                      width: "100px",
                                      height: "105px",
                                      those are outside the config:{} section, that means they are for the MM runtime…
                                      but we don’t process width/height
                                      if you want to do this you need to learn to use css(cascading style sheet) to customize the html presentation
                                      ALL updated css goes in css/custom.css
                                      a css entry in custom.css is
                                      selector_clause {
                                         styles to apply to elements selected by the selector clause
                                      we add the modulename as a class to the web content so that one can ‘select’ only for that module
                                      key selector clause elements
                                      starts with . means element has classname=xxx
                                      starts with # means element has id=xxxx
                                      does not start with either, means html element name, div, span, p, h1, img…
                                        Jose1701 @sdetweil
                                        Alright, I will try to get some info in the internet. Never done sth with css.
                                        S 2 Replies Last reply
                                          sdetweil @Jose1701
                                          @Jose1701 I understand , the browser provides a developer environment with different capabilities
                                          logger
                                          code execution
                                          and elements viewer, css tester env
                                          see the second link in my signature below for a starter course on the elements tab.
                                          • evroomE
                                            evroom @Jose1701
                                            @Jose1701
                                            No, sorry, no idea.
                                            What Sam says, but that needs knowledge.
                                            But I opened an issue/request, so let’s see if it will be granted:
                                            https://github.com/CuddlyCow/MMM-HoymilesPVMonitor/issues
                                            • 3 / 3
