    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 23.0k Views 5 Watching
    • evroomE Offline
      evroom @Jose1701
      @Jose1701
      Try this to find out what is using port 5000:
      sudo netstat -apln | grep -w 5000
      And did you update the bash program?
      https://github.com/schris88/MMM-Hoymiles-Wifi?tab=readme-ov-file#enter-dtu-ip-address-of-dtu
      MagicMirror version: 2.37.0
        Jose1701 @evroom
        @evroom
        Thanks for the quick answer.
        I inserted the IP of the dtu.
        Portscan is:
        tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      64879/python
        tcp        0      0 127.0.0.1:33698         127.0.0.1:5000          TIME_WAIT   -
        tcp        0      0 127.0.0.1:5000          127.0.0.1:56374         TIME_WAIT   -
        tcp        0      0 127.0.0.1:60100         127.0.0.1:5000          ESTABLISHED 71440/exe
        tcp        0      0 127.0.0.1:5000          127.0.0.1:60100         ESTABLISHED 64879/python
        tcp        0      0 127.0.0.1:52508         127.0.0.1:5000          TIME_WAIT   -
        tcp        0      0 127.0.0.1:50296         127.0.0.1:5000          TIME_WAIT   -
        • evroomE Offline
          evroom @Jose1701
          @Jose1701
          This command should give more information on the PID found:
          ps -Flww -p
          E.g.
          ps -Flww -p 64879
          Perhaps there are easier ways, but this should do.
            Jose1701 @evroom
            @evroom
            Seems that this is hoymiles …?
            F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
            0 S florian    64879   64878  1  80   0 - 59630 do_sys 137520  1 16:11 ?        00:05:02 python hoymiles_data.py --dtu_ip_address 192.168.178.150 --max 800
            • evroomE Offline
              evroom @Jose1701
              @Jose1701
              Yes, so an instance is already running.
              You added it to pm2 too?
              pm2 status
              If yes, then you do not need to run it manually.
              If no, then kill the (p)pid.
              sudo kill -9 [ppid]
                Jose1701 @evroom
                @evroom
                Well, I’ve done that now. At the moment it is night so I can’t see any output.
                Will see if it works tomorrow …
                Thank you. I will post if it runs then.
                J evroomE 2 Replies Last reply Reply Quote 0
                  Jose1701 @Jose1701
                  Can’t get it to work.
                  I don’t know what I’m doing wrong…
                  Now, Portscan ist about that:
                  tcp        0      0 127.0.0.1:5000          0.0.0.0:*               LISTEN      1139/python
                  tcp        0      0 127.0.0.1:5000          127.0.0.1:37002         ESTABLISHED 1139/python
                  tcp        0      0 127.0.0.1:57592         127.0.0.1:5000          TIME_WAIT   -
                  tcp        0      0 127.0.0.1:37002         127.0.0.1:5000          ESTABLISHED 6097/exe
                  • evroomE Offline
                    evroom @Jose1701
                    @Jose1701
                    First I would disable the module:
                    $ vi ~/MagicMirror/config/config.js
                        module: "MMM-Hoymiles-Wifi",
                        disabled: true,
                    $ pm2 restart MagicMirror
                    I build this command to try to get more info on port 5000:
                    $ for pid in `lsof -i :5000 | grep -v 'PID' | awk '{print $2}' | sort -u`; do echo $pid; ps -Flww -p  $pid; done
                    Hopefully the Forum tool does not change it.
                    Furthermore please verify and supply the following data:
                    $ cd /home/admin/MagicMirror/modules/MMM-Hoymiles-Wifi
                    Check path:
                    $ which hoymiles-wifi
                    $ echo $PATH
                    Check if the path is in the PATH.
                    If not, do (using the path from ‘which’):
                    $ export PATH=$PATH:/home/admin/.local/bin
                    Check config.js:
                    $ grep ':5000' ~/MagicMirror/config/config.js
                    Expected is:
                    { src: 'http://127.0.0.1:5000' },
                    Check HoymilesWifi.sh:
                    $ grep 'dtu_ip_address' HoymilesWifi.sh
                    Expected is your DTU IP address, for example:
                    python hoymiles_data.py --dtu_ip_address 192.168.178.50 --max 800
                    Test run (hoymiles-wifi):
                    $ hoymiles-wifi --host 192.168.178.50  identify-inverters
                    Expected is a response.
                    Test run (HoymilesWifi.sh)
                    $ ./HoymilesWifi.sh
                    Expected is:
                    * Serving Flask app 'hoymiles_data'
                    * Debug mode: off
                    INFO:werkzeug:WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
                    * Running on http://127.0.0.1:5000
                    INFO:werkzeug:Press CTRL+C to quit
                    If you wait a bit some more output is shown.
                    If it works, then I would suggest to stop the ./HoymilesWifi.sh command and do:
                    $ pm2 start HoymilesWifi.sh
                    $ pm2 save
                    $ pm2 status HoymilesWifi
                    $ pm2 logs HoymilesWifi --lines 10
                    If everything is okay, the enable the module again:
                        disabled: false,
                    evroomE J 3 Replies Last reply Reply Quote 0
                    • evroomE Offline
                      evroom @evroom
                      To be honest, for me the MM does not display anything.
                      Although it is dark, I still expected the graphic with 0 or so.
                      Or I have to wait a bit longer.
                      I used
                      https://github.com/schris88/MMM-Hoymiles-Wifi/
                      and all the above is correct and running.
                      A year ago I made a fork and made some changes, of which I think are present in the schris88 version as well.
                      https://github.com/evroom/MMM-Hoymiles-Wifi/
                      I will give this one a try when I have time.
                      PS: it seems that when the microinverter is off-line, you will not see anything. Need to wait for it to be active again.
                        Jose1701 @evroom
                        @evroom said in MMM-Hoymiles-Wifi:
                        $ grep ‘dtu_ip_address’ HoymilesWifi.sh
                        Until that line everything is ok. After that it says:
                        grep: HoymilesWifi.sh: No such file or directory
                          Jose1701 @evroom
                          This works:
                          Identify-inverters Response:
                          {'1412a015f1e3': 'HMS-800W/1000W-2T'}
                          After that: ./HoymilesWifi.sh
                           * Debug mode: off
                          Address already in use
                          Port 5000 is in use by another program. Either identify and stop that program, or start the server with a different port.
                            sdetweil @Jose1701
                            @Jose1701 typo
                             grep 'dtu_ip_address' Hoymiles-Wifi.sh
                              Jose1701 @sdetweil
                              Im getting this:
                              S evroomE 2 Replies Last reply Reply Quote 0
                                sdetweil @Jose1701
                                @Jose1701 he just wanted to see the IP address the module was connecting to , which is hard coded in that line
                                • evroomE Offline
                                  evroom @Jose1701
                                  @Jose1701
                                  First of all, where I write
                                  /home/admin/
                                  please use
                                  (tilde sign)
                                  And can you please send me:
                                  cd ~/MagicMirror/modules/MMM-Hoymiles-Wifi
                                  git branch
                                  git remote -v
                                  Every time you get that port in use error, run the long command to see what programs are using the port.
                                  And of course do not use HoymilesWifi.sh when it is also active under pm2.
                                  I am starting to wonder if the module works at all.
                                  I finally got a picture, but it showed an error in it.
                                  • evroomE Offline
                                    evroom @Jose1701
                                    @Jose1701
                                    You also might try this module:
                                    https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                                    I may give it a try myself.
                                      Jose1701 @evroom
                                      @evroom
                                      * master
                                      origin  https://github.com/schris88/MMM-Hoymiles-Wifi (fetch)
                                      origin  https://github.com/schris88/MMM-Hoymiles-Wifi (push)
                                      I used the ~ symbol.
                                        Jose1701 @evroom
                                        @evroom
                                        Well I tried that but I’m to silly to install it.
                                        florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ pip3 install hoymiles-wifi
                                        error: externally-managed-environment
                                        × This environment is externally managed
                                        ╰─> To install Python packages system-wide, try apt install
                                            python3-xyz, where xyz is the package you are trying to
                                            install.
                                            If you wish to install a non-Debian-packaged Python package,
                                            create a virtual environment using python3 -m venv path/to/venv.
                                            Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                                            sure you have python3-full installed.
                                            For more information visit http://rptl.io/venv
                                        note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                                        hint: See PEP 668 for the detailed specification.
                                        florian@raspberrypi:~/MagicMirror/modules/MMM-Hoymiles-Wifi $ sudo apt install python3 hoymiles-wifi
                                        Error: Unable to locate package hoymiles-wifi
                                        • evroomE Offline
                                          evroom @Jose1701
                                          @Jose1701
                                          You installed that already, so no need to install it again.
                                          Probably using:
                                          python -m pip install -r requirements.txt --break-system-packages
                                          The schris88 requirements.txt contains the hoymiles-wifi package.
                                            Jose1701 @evroom
                                            @evroom
                                            By unsing this, I get the following error:
                                            Defaulting to user installation because normal site-packages is not writeable
                                            ERROR: Could not open requirements file: [Errno 2] No such file or directory: 'requirements.txt'
                                            • 2 / 3
