    MMM-RAIN-MAP
    18 Posts 7 Posters 3.9k Views 7 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer @karsten13
      @karsten13 Thanks for investigating! It’s really a shame. I’ll update the docs.
      karsten13K 2 Replies Last reply
      • karsten13K
        karsten13 @KristjanESPERANTO
        @KristjanESPERANTO
        colorScheme seems to be useless too, the docs only mention 2 which is the default in the module, if I try other values there is no difference.
        karsten13K KristjanESPERANTOK 2 Replies Last reply
        • karsten13K
          karsten13 @karsten13
          see https://github.com/rainviewer/rainviewer-api-example?tab=readme-ov-file#personal-use-api-limitations
          • karsten13K
            @KristjanESPERANTO
            I’m using https://globe.airplanes.live/ and they have a RainViewer Layer which still works when zooming in - maybe they use a license key …
            Another approach I played with is using german dwd data (problem: germany only), tested this in my MMM-Flights module:
              @karsten13 said in MMM-RAIN-MAP:
              Thanks for that too! I just updated the docs.
              I’ve thought about that too, but it would probably be more a matter for a new module.
                JeanMichelC
                Hi, I’m trying to set the market in the config file. I see 2 markers with different lat and long. What do they represent each? Same for the markers options.
                Are they defining the area?
                KristjanESPERANTOK 1 Reply Last reply
                  KristjanESPERANTO Module Developer @JeanMichelC
                  @JeanMichelC The markers are just visual pin icons on the map — they don’t define any area. A typical use case would be marking your home and workplace so you can easily spot them while watching the rain radar.
                  J 1 Reply Last reply
                    JeanMichelC @KristjanESPERANTO
                    @KristjanESPERANTO Thanks for your quick response. Yeah, I figured it out and it’s working beautifully, thanks. It looks great!!!
                    F 1 Reply Last reply
                    • F
                      fatespawn @JeanMichelC
                      @kristjanesperanto
                      Thanks for tending to the module. I noticed the zoom error on a couple of installations I had as well and saw your updated documentations. Bummer about both the zoom and forecast loops.
                      My module seems stuck looping between 4:20pm and 6:20pm now. I have restarted magicmirror but the module reverts to 4:20pm and the same radar loop associated with 4:20pm
                      • F
                        fatespawn @fatespawn
                        Disregard. It appears rainviewer.com was down for a while, but it’s back up now and updating correctly.
                        Reply Quote 2
                        • I
                          icemanmw
                          Just a question, maybe already answered, is there a way to pay for a better api access at rainviewer.com and implement into the rain-map module ?
