    MMM-RAIN-MAP
    18 Posts 7 Posters 3.4k Views 7 Watching
    • karsten13K Offline
      karsten13 @KristjanESPERANTO
      @KristjanESPERANTO
      The module is working for me, but since today, the two lowest of my four zoom levels seem to have stopped working (no change after updating).
      I don’t see any 429 errors in the logs.
      But let’s just wait and see; it might work again tomorrow…
      KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 0
      • KristjanESPERANTOK Online
        KristjanESPERANTO Module Developer @karsten13
        @karsten13 Thanks for that feedback! I can’t reproduce the issue with low zoom levels - they’re working fine here with the latest version 🤔 I’m curious to hear your outcome tomorrow.
        • plainbrokeP Offline
          plainbroke @KristjanESPERANTO
          @KristjanESPERANTO
          Thank you for the update.
          Now MM boots up and fully loads.
          Before MM was hanging at load up of all the modules.
          Just have to do a little resizing so it fits the screen again…
          Thank you again…
          • plainbrokeP plainbroke has marked this topic as solved on
          • E Offline
            eddiebrok
            MMM-RAIN-MAP itself is usually pretty light, but running around 48 modules under MMM-Pages can definitely cause freezes, especially after updates. Check the MagicMirror logs to see which module is throwing errors, and try disabling MMM-RAIN-MAP or a few other modules one by one to isolate it. It’s more likely a module conflict or resource issue than the Pi hardware.
              karsten13 @karsten13
              said in MMM-RAIN-MAP:
              they are definitely gone …
              I used for several years
                      mapPositions: [
                        { lat: ${LAT}, lng: ${LON}, zoom: 9, loops: 1 },
                        { lat: ${LAT}, lng: ${LON}, zoom: 8, loops: 1 },
                        { lat: ${LAT}, lng: ${LON}, zoom: 7, loops: 1 },
                        { lat: ${LAT}, lng: ${LON}, zoom: 6, loops: 1 },
              and now found in their docs Maximum zoom level is 7.
              Another restriction is that there is no forecast anymore (as already stated in the module readme).
              That’s a shame, it unfortunately devalues ​​the module.
              KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                @karsten13 Thanks for investigating! It’s really a shame. I’ll update the docs.
                  @KristjanESPERANTO
                  colorScheme seems to be useless too, the docs only mention 2 which is the default in the module, if I try other values there is no difference.
                  karsten13K KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
                    see https://github.com/rainviewer/rainviewer-api-example?tab=readme-ov-file#personal-use-api-limitations
                      @KristjanESPERANTO
                      I’m using https://globe.airplanes.live/ and they have a RainViewer Layer which still works when zooming in - maybe they use a license key …
                      Another approach I played with is using german dwd data (problem: germany only), tested this in my MMM-Flights module:
                        @karsten13 said in MMM-RAIN-MAP:
                        Thanks for that too! I just updated the docs.
                        I’ve thought about that too, but it would probably be more a matter for a new module.
                          JeanMichelC
                          Hi, I’m trying to set the market in the config file. I see 2 markers with different lat and long. What do they represent each? Same for the markers options.
                          Are they defining the area?
                            KristjanESPERANTO Module Developer @JeanMichelC
                            @JeanMichelC The markers are just visual pin icons on the map — they don’t define any area. A typical use case would be marking your home and workplace so you can easily spot them while watching the rain radar.
                              JeanMichelC @KristjanESPERANTO
                              @KristjanESPERANTO Thanks for your quick response. Yeah, I figured it out and it’s working beautifully, thanks. It looks great!!!
                              F 1 Reply Last reply Reply Quote 1
                              • F Offline
                                fatespawn @JeanMichelC
                                @kristjanesperanto
                                Thanks for tending to the module. I noticed the zoom error on a couple of installations I had as well and saw your updated documentations. Bummer about both the zoom and forecast loops.
                                My module seems stuck looping between 4:20pm and 6:20pm now. I have restarted magicmirror but the module reverts to 4:20pm and the same radar loop associated with 4:20pm
                                • F Offline
                                  fatespawn @fatespawn
                                  Disregard. It appears rainviewer.com was down for a while, but it’s back up now and updating correctly.
                                  • I Offline
                                    icemanmw
                                    Just a question, maybe already answered, is there a way to pay for a better api access at rainviewer.com and implement into the rain-map module ?
