    MMM-RAIN-MAP
    18 Posts 7 Posters 3.7k Views 7 Watching
    • E
      eddiebrok
      MMM-RAIN-MAP itself is usually pretty light, but running around 48 modules under MMM-Pages can definitely cause freezes, especially after updates. Check the MagicMirror logs to see which module is throwing errors, and try disabling MMM-RAIN-MAP or a few other modules one by one to isolate it. It’s more likely a module conflict or resource issue than the Pi hardware.
      • karsten13K
        karsten13 @karsten13
        said in MMM-RAIN-MAP:
        but since today, the two lowest of my four zoom levels seem to have stopped working
        they are definitely gone …
        I used for several years
                mapPositions: [
                  { lat: ${LAT}, lng: ${LON}, zoom: 9, loops: 1 },
                  { lat: ${LAT}, lng: ${LON}, zoom: 8, loops: 1 },
                  { lat: ${LAT}, lng: ${LON}, zoom: 7, loops: 1 },
                  { lat: ${LAT}, lng: ${LON}, zoom: 6, loops: 1 },
        and now found in their docs Maximum zoom level is 7.
        Another restriction is that there is no forecast anymore (as already stated in the module readme).
        That’s a shame, it unfortunately devalues ​​the module.
        KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
        • KristjanESPERANTOK
          KristjanESPERANTO Module Developer @karsten13
          @karsten13 Thanks for investigating! It’s really a shame. I’ll update the docs.
          karsten13K 2 Replies Last reply Reply Quote 0
          • karsten13K
            karsten13 @KristjanESPERANTO
            @KristjanESPERANTO
            colorScheme seems to be useless too, the docs only mention 2 which is the default in the module, if I try other values there is no difference.
            karsten13K KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
            • karsten13K
              see https://github.com/rainviewer/rainviewer-api-example?tab=readme-ov-file#personal-use-api-limitations
              • karsten13K
                @KristjanESPERANTO
                I’m using https://globe.airplanes.live/ and they have a RainViewer Layer which still works when zooming in - maybe they use a license key …
                Another approach I played with is using german dwd data (problem: germany only), tested this in my MMM-Flights module:
                  @karsten13 said in MMM-RAIN-MAP:
                  Thanks for that too! I just updated the docs.
                  I’ve thought about that too, but it would probably be more a matter for a new module.
                    JeanMichelC
                    Hi, I’m trying to set the market in the config file. I see 2 markers with different lat and long. What do they represent each? Same for the markers options.
                    Are they defining the area?
                      KristjanESPERANTO Module Developer @JeanMichelC
                      @JeanMichelC The markers are just visual pin icons on the map — they don’t define any area. A typical use case would be marking your home and workplace so you can easily spot them while watching the rain radar.
                        JeanMichelC @KristjanESPERANTO
                        @KristjanESPERANTO Thanks for your quick response. Yeah, I figured it out and it’s working beautifully, thanks. It looks great!!!
                        F 1 Reply Last reply Reply Quote 1
                        • F
                          fatespawn @JeanMichelC
                          @kristjanesperanto
                          Thanks for tending to the module. I noticed the zoom error on a couple of installations I had as well and saw your updated documentations. Bummer about both the zoom and forecast loops.
                          My module seems stuck looping between 4:20pm and 6:20pm now. I have restarted magicmirror but the module reverts to 4:20pm and the same radar loop associated with 4:20pm
                          • F
                            fatespawn @fatespawn
                            Disregard. It appears rainviewer.com was down for a while, but it’s back up now and updating correctly.
                            • I
                              icemanmw
                              Just a question, maybe already answered, is there a way to pay for a better api access at rainviewer.com and implement into the rain-map module ?
