    MMM-RAIN-MAP
    18 Posts 7 Posters 1.2k Views 7 Watching
    • plainbrokeP Offline
      plainbroke
      Anyone else have MMM-RAIN-MAP all the sudden stop working?
      It actually locked up my MM . OR do I have to many modules running under MMM-pages? Approximately 48.
      Rpi 4 8gb ram running water cooler and nvme-sata 128gb power supply is the pi5 version.
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @plainbroke
        Hi @plainbroke,
        yes, this is very likely API rate limiting (HTTP 429 errors) from RainViewer. The module was making too many requests with default settings.
        I recommend to update to the latest release v2.11.0 which includes:
        • Optimized defaults
        • Exponential backoff retry logic for 429 errors
        • Better error handling
        • karsten13K Offline
          karsten13 @KristjanESPERANTO
          @KristjanESPERANTO
          The module is working for me, but since today, the two lowest of my four zoom levels seem to have stopped working (no change after updating).
          I don’t see any 429 errors in the logs.
          But let’s just wait and see; it might work again tomorrow…
          KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 0
            KristjanESPERANTO Module Developer @karsten13
            @karsten13 Thanks for that feedback! I can’t reproduce the issue with low zoom levels - they’re working fine here with the latest version 🤔 I’m curious to hear your outcome tomorrow.
              plainbroke @KristjanESPERANTO
              @KristjanESPERANTO
              Thank you for the update.
              Now MM boots up and fully loads.
              Before MM was hanging at load up of all the modules.
              Just have to do a little resizing so it fits the screen again…
              Thank you again…
              • plainbrokeP plainbroke has marked this topic as solved on
              • E Offline
                eddiebrok
                MMM-RAIN-MAP itself is usually pretty light, but running around 48 modules under MMM-Pages can definitely cause freezes, especially after updates. Check the MagicMirror logs to see which module is throwing errors, and try disabling MMM-RAIN-MAP or a few other modules one by one to isolate it. It’s more likely a module conflict or resource issue than the Pi hardware.
                  karsten13 @karsten13
                  said in MMM-RAIN-MAP:
                  they are definitely gone …
                  I used for several years
                          mapPositions: [
                            { lat: ${LAT}, lng: ${LON}, zoom: 9, loops: 1 },
                            { lat: ${LAT}, lng: ${LON}, zoom: 8, loops: 1 },
                            { lat: ${LAT}, lng: ${LON}, zoom: 7, loops: 1 },
                            { lat: ${LAT}, lng: ${LON}, zoom: 6, loops: 1 },
                  and now found in their docs Maximum zoom level is 7.
                  Another restriction is that there is no forecast anymore (as already stated in the module readme).
                  That’s a shame, it unfortunately devalues ​​the module.
                  KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                    @karsten13 Thanks for investigating! It’s really a shame. I’ll update the docs.
                      @KristjanESPERANTO
                      colorScheme seems to be useless too, the docs only mention 2 which is the default in the module, if I try other values there is no difference.
                      karsten13K KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
                        see https://github.com/rainviewer/rainviewer-api-example?tab=readme-ov-file#personal-use-api-limitations
                          @KristjanESPERANTO
                          I’m using https://globe.airplanes.live/ and they have a RainViewer Layer which still works when zooming in - maybe they use a license key …
                          Another approach I played with is using german dwd data (problem: germany only), tested this in my MMM-Flights module:
                            @karsten13 said in MMM-RAIN-MAP:
                            Thanks for that too! I just updated the docs.
                            I’ve thought about that too, but it would probably be more a matter for a new module.
                              JeanMichelC
                              Hi, I’m trying to set the market in the config file. I see 2 markers with different lat and long. What do they represent each? Same for the markers options.
                              Are they defining the area?
                                KristjanESPERANTO Module Developer @JeanMichelC
                                @JeanMichelC The markers are just visual pin icons on the map — they don’t define any area. A typical use case would be marking your home and workplace so you can easily spot them while watching the rain radar.
                                  JeanMichelC @KristjanESPERANTO
                                  @KristjanESPERANTO Thanks for your quick response. Yeah, I figured it out and it’s working beautifully, thanks. It looks great!!!
                                  F 1 Reply Last reply Reply Quote 1
                                  • F Offline
                                    fatespawn @JeanMichelC
                                    @kristjanesperanto
                                    Thanks for tending to the module. I noticed the zoom error on a couple of installations I had as well and saw your updated documentations. Bummer about both the zoom and forecast loops.
                                    My module seems stuck looping between 4:20pm and 6:20pm now. I have restarted magicmirror but the module reverts to 4:20pm and the same radar loop associated with 4:20pm
                                    • F Offline
                                      fatespawn @fatespawn
                                      Disregard. It appears rainviewer.com was down for a while, but it’s back up now and updating correctly.
                                      • I Offline
                                        icemanmw
                                        Just a question, maybe already answered, is there a way to pay for a better api access at rainviewer.com and implement into the rain-map module ?
