    MMM-RAIN-MAP
    11 Posts 4 Posters 168 Views 4 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @karsten13
      @karsten13 Thanks for that feedback! I can’t reproduce the issue with low zoom levels - they’re working fine here with the latest version 🤔 I’m curious to hear your outcome tomorrow.
      • plainbrokeP Offline
        plainbroke @KristjanESPERANTO
        @KristjanESPERANTO
        Thank you for the update.
        Now MM boots up and fully loads.
        Before MM was hanging at load up of all the modules.
        Just have to do a little resizing so it fits the screen again…
        Thank you again…
        • plainbrokeP plainbroke has marked this topic as solved
        • E Offline
          eddiebrok
          MMM-RAIN-MAP itself is usually pretty light, but running around 48 modules under MMM-Pages can definitely cause freezes, especially after updates. Check the MagicMirror logs to see which module is throwing errors, and try disabling MMM-RAIN-MAP or a few other modules one by one to isolate it. It’s more likely a module conflict or resource issue than the Pi hardware.
          • karsten13K Offline
            karsten13 @karsten13
            said in MMM-RAIN-MAP:
            but since today, the two lowest of my four zoom levels seem to have stopped working
            they are definitely gone …
            I used for several years
                    mapPositions: [
                      { lat: ${LAT}, lng: ${LON}, zoom: 9, loops: 1 },
                      { lat: ${LAT}, lng: ${LON}, zoom: 8, loops: 1 },
                      { lat: ${LAT}, lng: ${LON}, zoom: 7, loops: 1 },
                      { lat: ${LAT}, lng: ${LON}, zoom: 6, loops: 1 },
            and now found in their docs Maximum zoom level is 7.
            Another restriction is that there is no forecast anymore (as already stated in the module readme).
            That’s a shame, it unfortunately devalues ​​the module.
            KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
              @karsten13 Thanks for investigating! It’s really a shame. I’ll update the docs.
              karsten13K 2 Replies Last reply Reply Quote 0
                karsten13 @KristjanESPERANTO
                @KristjanESPERANTO
                colorScheme seems to be useless too, the docs only mention 2 which is the default in the module, if I try other values there is no difference.
                  see https://github.com/rainviewer/rainviewer-api-example?tab=readme-ov-file#personal-use-api-limitations
                    @KristjanESPERANTO
                    I’m using https://globe.airplanes.live/ and they have a RainViewer Layer which still works when zooming in - maybe they use a license key …
                    Another approach I played with is using german dwd data (problem: germany only), tested this in my MMM-Flights module:
