    I am sure nobody know it but...perhaps you know a fade in/out switch?
    13 Posts 4 Posters 9.6k Views 3 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @morozgrafix
      @morozgrafix said in I am sure nobody know it but...perhaps you know a fade in/out switch?:
      @fersev what is fade in/fade out switch?
      I asked the same thing… then I suggested perhaps a dimmer switch…
      Not really sure what’s needed here.
      • fersevF Offline
        fersev
        sorry for delay…I mean a switch when I push the switch first time light will turn on bit by bit when push second light turn off bit by bit. Similar to light when you open or close door car.
        morozgrafixM 1 Reply Last reply Reply Quote 0
        • morozgrafixM Offline
          morozgrafix Moderator @fersev
          @fersev that’s called dimmer light switch. Plenty of them available on the market. Most designs are tailored for household use. Keep in mind that whatever you are going to use it with should be “dimmable” like an incandescent light bulb, some of the newer LED light bulbs are also dimmable.
            @morozgrafix Yes that’s what I was telling him… a dimmer. I am a contractor so I knew what he was talking about but these are 110V…
            There may be a bluetooth connected one out there! :) That may work!
            • fersevF Offline
              fersev
              I know is a dimmer. But dimmer are like this:
              alt text
              But I do not need this, I refer a some like this:
              https://www.youtube.com/watch?v=VMtyGhLqwuI
              I think is called soft start :) maybe now you have more info! thanks!
                @fersev ummm, there is a buy link right in the description of the video that you’ve posted.
                fersevF 1 Reply Last reply Reply Quote 1
                  Now that could work, low voltage… on a momentary switch…
                  • fersevF Offline
                    fersev @morozgrafix
                    @morozgrafix I had see
                    But this is not good, I need more wattage about 12V and 6A… keep looking
                    thanks for all responses
                    • brobergB Offline
                      broberg Project Sponsor @fersev
                      @fersev
                      http://www.ebay.com/itm/Manual-Dimmer-Switch-for-LED-Strip-Light-12V-8A-Mountable-with-Terminals-/231887888154
                      maybe?
                      • fersevF Offline
                        fersev
                        Hey guys! I finally I found it!!!
                        https://es.aliexpress.com/item/NEW-12V-Mini-3-Keys-Single-Color-LED-Controller-Brightness-Dimmer-for-led-3528-5050-strip/32706124669.html
                        https://es.aliexpress.com/item/12V-6A-3-Keys-Mini-Controller-Dimmer-for-5050-3528-RGB-LED-Strip-Light-19-Dynamic/32531126511.html
                        https://es.aliexpress.com/item/Music-IR-Controller-12V-6A-24-Keys-IR-Remote-Controller-for-3528-5050-RGB-LED-Strip/32324664581.html
