    I am sure nobody know it but...perhaps you know a fade in/out switch?
    13 Posts 4 Posters 9.6k Views 3 Watching
    • fersevF Offline
      fersev
      sorry for delay…I mean a switch when I push the switch first time light will turn on bit by bit when push second light turn off bit by bit. Similar to light when you open or close door car.
      morozgrafixM 1 Reply Last reply Reply Quote 0
      • morozgrafixM Offline
        morozgrafix Moderator @fersev
        @fersev that’s called dimmer light switch. Plenty of them available on the market. Most designs are tailored for household use. Keep in mind that whatever you are going to use it with should be “dimmable” like an incandescent light bulb, some of the newer LED light bulbs are also dimmable.
        • cowboysdudeC Offline
          cowboysdude Module Developer @morozgrafix
          @morozgrafix Yes that’s what I was telling him… a dimmer. I am a contractor so I knew what he was talking about but these are 110V…
          There may be a bluetooth connected one out there! :) That may work!
          • fersevF Offline
            fersev
            I know is a dimmer. But dimmer are like this:
            alt text
            But I do not need this, I refer a some like this:
            https://www.youtube.com/watch?v=VMtyGhLqwuI
            I think is called soft start :) maybe now you have more info! thanks!
              @fersev ummm, there is a buy link right in the description of the video that you’ve posted.
              fersevF 1 Reply Last reply Reply Quote 1
                Now that could work, low voltage… on a momentary switch…
                • fersevF Offline
                  fersev @morozgrafix
                  @morozgrafix I had see
                  But this is not good, I need more wattage about 12V and 6A… keep looking
                  thanks for all responses
                  • brobergB Offline
                    broberg Project Sponsor @fersev
                    @fersev
                    http://www.ebay.com/itm/Manual-Dimmer-Switch-for-LED-Strip-Light-12V-8A-Mountable-with-Terminals-/231887888154
                    maybe?
                    • fersevF Offline
                      fersev
                      Hey guys! I finally I found it!!!
                      https://es.aliexpress.com/item/NEW-12V-Mini-3-Keys-Single-Color-LED-Controller-Brightness-Dimmer-for-led-3528-5050-strip/32706124669.html
                      https://es.aliexpress.com/item/12V-6A-3-Keys-Mini-Controller-Dimmer-for-5050-3528-RGB-LED-Strip-Light-19-Dynamic/32531126511.html
                      https://es.aliexpress.com/item/Music-IR-Controller-12V-6A-24-Keys-IR-Remote-Controller-for-3528-5050-RGB-LED-Strip/32324664581.html
                        cowboysdude Module Developer @fersev
                        @fersev said in I am sure nobody know it but...perhaps you know a fade in/out switch?:
                        See that… I just learned something new!! Thanks for sharing!!! :)
