    I am sure nobody know it but...perhaps you know a fade in/out switch?
    13 Posts 4 Posters 10.5k Views 3 Watching
    • F
      fersev
      Looking for a fade in/out switch where can buy it? some idea!?
      morozgrafixM 1 Reply Last reply Reply Quote 0
      • morozgrafixM
        morozgrafix Moderator @fersev
        @fersev what is fade in/fade out switch?
        • cowboysdudeC
          cowboysdude Module Developer @morozgrafix
          @morozgrafix said in I am sure nobody know it but...perhaps you know a fade in/out switch?:
          I asked the same thing… then I suggested perhaps a dimmer switch…
          Not really sure what’s needed here.
          • F
            fersev
            sorry for delay…I mean a switch when I push the switch first time light will turn on bit by bit when push second light turn off bit by bit. Similar to light when you open or close door car.
            • morozgrafixM
              @fersev that’s called dimmer light switch. Plenty of them available on the market. Most designs are tailored for household use. Keep in mind that whatever you are going to use it with should be “dimmable” like an incandescent light bulb, some of the newer LED light bulbs are also dimmable.
              • cowboysdudeC
                @morozgrafix Yes that’s what I was telling him… a dimmer. I am a contractor so I knew what he was talking about but these are 110V…
                There may be a bluetooth connected one out there! :) That may work!
                • F
                  fersev
                  I know is a dimmer. But dimmer are like this:
                  alt text
                  But I do not need this, I refer a some like this:
                  https://www.youtube.com/watch?v=VMtyGhLqwuI
                  I think is called soft start :) maybe now you have more info! thanks!
                  • morozgrafixM
                    @fersev ummm, there is a buy link right in the description of the video that you’ve posted.
                    F 1 Reply Last reply Reply Quote 1
                    • cowboysdudeC
                      Now that could work, low voltage… on a momentary switch…
                      • F
                        fersev @morozgrafix
                        @morozgrafix I had see
                        But this is not good, I need more wattage about 12V and 6A… keep looking
                        thanks for all responses
                          broberg Project Sponsor @fersev
                          @fersev
                          http://www.ebay.com/itm/Manual-Dimmer-Switch-for-LED-Strip-Light-12V-8A-Mountable-with-Terminals-/231887888154
                          maybe?
                          • F
                            fersev
                            Hey guys! I finally I found it!!!
                            https://es.aliexpress.com/item/NEW-12V-Mini-3-Keys-Single-Color-LED-Controller-Brightness-Dimmer-for-led-3528-5050-strip/32706124669.html
                            https://es.aliexpress.com/item/12V-6A-3-Keys-Mini-Controller-Dimmer-for-5050-3528-RGB-LED-Strip-Light-19-Dynamic/32531126511.html
                            https://es.aliexpress.com/item/Music-IR-Controller-12V-6A-24-Keys-IR-Remote-Controller-for-3528-5050-RGB-LED-Strip/32324664581.html
                            • cowboysdudeC
                              cowboysdude Module Developer @fersev
                              @fersev said in I am sure nobody know it but...perhaps you know a fade in/out switch?:
                              See that… I just learned something new!! Thanks for sharing!!! :)
