    Building mirror without programing
    windows
    24 Posts 11 Posters 32.2k Views 11 Watching
      Mitchfarino Module Developer @yo-less
      @yo-less You’re a hero!
      I didn’t know this was possible either, but I’m gonna get it installed on my laptop.
      It’s annoying when I have a spare 30 minutes, but I have to get the pi/monitor out and set it all up before getting started!
      Now I can mess around and tinker on my laptop!
      Cheers
      • cowboysdudeC Offline
        This method is no longer working… it’s throwing errors like crazy. Latest version of nodejs and npm still throws errors and won’t install.
        • F Offline
          f0084r
          Just in case someone bumps into this like I did, I just followed the directions yo-less posted above and it worked fine for me on windows 10.
            schmo90
            Hy thanks this is working very fine.
            now i am trying to get it working with visual studio 2015.
            has anyone expirience with that IDE and node.js?
            i am able to load it, but i cannot start and debug the mm solution
              amanzimdwini
              Works like a charm! (except that folders constantly have the post-name _Master - which you need to remove: after installation, make sure everything “lives” in the folder C:\MagicMirror (or similar)
              Notes on how to install modules - here are MY 2 cents:
              Find the module you like; go to the GTT depository but select “Downloads as Zip”. Find the ZIP file and extract it into the MODULES subdirectory (in my example, C:\MagicMirror\modules). RENAME the folder you just created by removing the trailing _Master.
              Presto. Works great.
                cowboysdude Module Developer @amanzimdwini
                @amanzimdwini said in Building mirror without programing:
                Well that our just use -master in your config file ;) LOL
                A strawberry 3.141S 2 Replies Last reply Reply Quote 0
                  amanzimdwini @cowboysdude
                  @cowboysdude - DUH. Sorry - good point!
                    LOL Well I just rename them but I know how you feel. I believe they do it that way because that way the user knows it’s getting the correct branch :)
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                      @cowboysdude this will not work, because the js file cannot be found then
                      @amanzimdwini if yozu dont install the modules wuth git clone you have to redo the whole process for every update
                      cowboysdudeC A 2 Replies Last reply Reply Quote 2
                        cowboysdude Module Developer @strawberry 3.141
                        @strawberry-3.141 said in Building mirror without programing:
                        I am so glad we have you! :)
                          amanzimdwini @strawberry 3.141
                          @strawberry-3.141
                          Hmm - you SURE? I must have been lucky, since it worked for me just the way I described it (though I had to rename the extracted ZIPs by removing the -master extension: that’s why I published my results: so that others would also succeed). On my Win10, I successfully installed at least
                          Wunderground
                          MMM-forecast-io
                          Wunderlist
                          Valentine
                          (and probably a few others - would need to check).
                          Like I said, probably I was just lucky. But it worked for me.
                          [@cowboysdude said I should rename (have not tried it, though you stated that that would not work?)]
                          Thanks for reading/commenting.
                          cowboysdudeC Y strawberry 3.141S 3 Replies Last reply Reply Quote 0
                            @amanzimdwini That’s what I did too… just cut off the -master at the end when I downloaded them but now I just do:
                            ~MagicMirror/modules/
                            Then I do a 'git clone… ’
                            That’s the easiest way actually :)
                            • Y Offline
                              yawns Moderator @amanzimdwini
                              @amanzimdwini
                              If you download and unzip modules, you don’t have a folder called .git, and without this folder you cannot run git pull to update the specific module, when the developer releases a new version.
                              Everything else of course works fine.
                              A 1 Reply Last reply Reply Quote 3
                                strawberry 3.141 Project Sponsor Module Developer @amanzimdwini
                                @amanzimdwini it works, but I said putting -master in the config will not work, because then you have several problems
                                The only thing is without having the ability to use git you have to redo the whole process for every update, the correct installation steps are mostly in the readme of the module itself
                                  amanzimdwini @yawns
                                  @yawns
                                  Upvote.
                                  Sorry that I seem to have kicked a hornet’s nest – I was just reading that people had had problems, and found a way that worked for me. But yes, updating etc is not going to work. And yes, GIT pulls are best…
                                  BUT for real Noobs (been there, done that), GIT might be a bit “weird”, while ZIP is recognized.
                                  Bottom line:
                                  This all works - use @yo-less instructions, then either go the ZIP route (where you have to remove the -master) OR the GIT route (nice & easy).
                                  Thanks everyone for finding all the problems. Let’s leave this with the conclusion that THIS AWESOME MAGIC MIRROR works on Win-boxes too!
                                  Y cowboysdudeC 2 Replies Last reply Reply Quote 1
                                  • Y Offline
                                    @amanzimdwini
                                    You are right, git seems a bit irritating and uncomfortable at first and of course downloading and unzipping works at the moment. Neither strawberry nor I wanted to bash on you!
                                    We just wanted to point out the downside of the zip approach :)
                                      @amanzimdwini Nawwwwwwwwwww you’re okay not to worry…
                                      I’m a ‘windows’ guy and not a linux guy but once you do it a few times… it just becomes second nature… :) PLUS windows is a pretty mindless thing… it’s easy because they’ve done all the work for you… what fun is that? LOL
                                      • O Offline
                                        Omeliel
                                        HI. It doesnt work. I got nothiing but a black screen. Can you advice ? Thans
