    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 417.4k Views 51 Watching
      Mykle1 Project Sponsor Module Developer @RedNax
      @RedNax
      This is a stunningly beautiful and informative module and the many config options must make it a favorite of anyone that uses it. I tip my hat to you.
      With that, may I make a humble request regarding fctext? I love this option but it can change from 3 lines to as many as 7 lines. Would it be possible to limit, or set, the amount of lines displayed. Or, could the text decrease in size as more information needs to be displayed, taking up the same amount of space?
        RedNax Module Developer @Mykle1
        @Mykle1 Hi,
        Thank you for your kind words. I’ve now pushed a version that will dynamically scale the fontsize/line length of the forecast text. Give it a go! :D
        O Mykle1M 2 Replies Last reply Reply Quote 0
        • O Offline
          ostfilinchen @RedNax
          @RedNax now it don’t Looks good:
          the FC-Text goes above the lines. Can u please check this?
            Doesn’t seem to happen on my setup…
            Is your issue that the % sign is on a seperate line?
            0_1487331607607_upload-38ed4333-3e1c-4b88-ac81-22ecf1a8ca03
            O 2 Replies Last reply Reply Quote 0
            • O Offline
              @RedNax no. The lines under and above the forecasttest are not toll the right side of the text.
                @RedNax said in Weatherunderground - currently - hourly - daily - configurable:
                I have to run off to work right now but I will “give it a go” as soon as I get home. I’ll let you know. Thanks for this.:thumbsup:
                • O Offline
                  @RedNax i can’t say why but now after a while, it looks correct.
                    RedNax Module Developer @ostfilinchen
                    @ostfilinchen There’s a new version. I left my test in which just used metric. Imperial users wouldn’t be happy. I’ve also added trim to the wordwrap function so here aren’t any trailing spaces
                      bminer1
                      Im still only getting the Icons. How do i get those nicer pictures?
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @bminer1
                        @bminer1 Did you try coloricon: true?
                          bminer1 @strawberry 3.141
                          @strawberry-3.141
                          I swear you guys are way too talented! Fixed.
                            @strawberry-3.141 Im sure you can help me out with something else. The wind direction in the forecast is pushing the module really far into the center of the screen. Is there a way i can change the forecast wind direction to shrink it up a bit? Everything at the top seems to be really far in space. I know i could always go back to the vertical but i like the horizontal too.
                            strawberry 3.141S R 2 Replies Last reply Reply Quote 0
                              @bminer1 i think you have another issue, because the text wi-from-sw should actually be an icon
                                RedNax Module Developer @bminer1
                                @bminer1 Pull the new version ;)
                                B 1 Reply Last reply Reply Quote 3
                                  bminer1 @RedNax
                                  @RedNax much better! Thank you!
                                  Just one thing, aesthetically, the little wind icons arent all uniform.0_1487352669390_Screen Shot 2017-02-17 at 12.29.56 PM.png
                                    @bminer1 Made the fontsize smaller in css.Please try it.
                                    You can try to tweak this is it still behaves oddly.
                                    .MMM-WunderGround .smaller {
                                        font-size: 60%;
                                    O K 2 Replies Last reply Reply Quote 0
                                    • O Offline
                                      @RedNax After the latest update, the Module wouldn’t start :-(
                                        @ostfilinchen Anything in the logs? Works fine here…
                                        IT could be your chosen weatherstation is feeding ‘estimated’ forecasts. The module skips those as they vary wildly (0 to 15 degrees C)… Should clear up on it’s own in that case.
                                        Update: There was no logging on skipping estimated forecasts. Added it just now.
                                        • O Offline
                                          @RedNax in dev Mode it says: uncaught TypeError: cannot read property ‘cloudy’ of undefined. MMM-WunderGround.js Line 877
                                            @ostfilinchen Some obsolete coloricon code got in the way it seems. Are you not using the coloricons?
                                            • 10
                                            • 5 / 10
