    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 423.9k Views 51 Watching
    • O
      ostfilinchen @RedNax
      @RedNax now it don’t Looks good:
      the FC-Text goes above the lines. Can u please check this?
        RedNax Module Developer
        Doesn’t seem to happen on my setup…
        Is your issue that the % sign is on a seperate line?
        0_1487331607607_upload-38ed4333-3e1c-4b88-ac81-22ecf1a8ca03
        O 2 Replies Last reply Reply Quote 0
        • O
          @RedNax no. The lines under and above the forecasttest are not toll the right side of the text.
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @RedNax
            @RedNax said in Weatherunderground - currently - hourly - daily - configurable:
            Thank you for your kind words. I’ve now pushed a version that will dynamically scale the fontsize/line length of the forecast text. Give it a go!
            I have to run off to work right now but I will “give it a go” as soon as I get home. I’ll let you know. Thanks for this.:thumbsup:
            • O
              @RedNax i can’t say why but now after a while, it looks correct.
                RedNax Module Developer @ostfilinchen
                @ostfilinchen There’s a new version. I left my test in which just used metric. Imperial users wouldn’t be happy. I’ve also added trim to the wordwrap function so here aren’t any trailing spaces
                  bminer1
                  Im still only getting the Icons. How do i get those nicer pictures?
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @bminer1
                    @bminer1 Did you try coloricon: true?
                      bminer1 @strawberry 3.141
                      @strawberry-3.141
                      I swear you guys are way too talented! Fixed.
                        @strawberry-3.141 Im sure you can help me out with something else. The wind direction in the forecast is pushing the module really far into the center of the screen. Is there a way i can change the forecast wind direction to shrink it up a bit? Everything at the top seems to be really far in space. I know i could always go back to the vertical but i like the horizontal too.
                        strawberry 3.141S R 2 Replies Last reply Reply Quote 0
                        • strawberry 3.141S
                          @bminer1 i think you have another issue, because the text wi-from-sw should actually be an icon
                            RedNax Module Developer @bminer1
                            @bminer1 Pull the new version ;)
                            B 1 Reply Last reply Reply Quote 3
                              bminer1 @RedNax
                              @RedNax much better! Thank you!
                              Just one thing, aesthetically, the little wind icons arent all uniform.0_1487352669390_Screen Shot 2017-02-17 at 12.29.56 PM.png
                                @bminer1 Made the fontsize smaller in css.Please try it.
                                You can try to tweak this is it still behaves oddly.
                                .MMM-WunderGround .smaller {
                                    font-size: 60%;
                                O K 2 Replies Last reply Reply Quote 0
                                • O
                                  @RedNax After the latest update, the Module wouldn’t start :-(
                                    @ostfilinchen Anything in the logs? Works fine here…
                                    IT could be your chosen weatherstation is feeding ‘estimated’ forecasts. The module skips those as they vary wildly (0 to 15 degrees C)… Should clear up on it’s own in that case.
                                    Update: There was no logging on skipping estimated forecasts. Added it just now.
                                    • O
                                      @RedNax in dev Mode it says: uncaught TypeError: cannot read property ‘cloudy’ of undefined. MMM-WunderGround.js Line 877
                                        @ostfilinchen Some obsolete coloricon code got in the way it seems. Are you not using the coloricons?
                                        • cowboysdudeC
                                          Thanks @RedNax I still remember the day I was trying to get this module to work [NOOOOOB LOL] and you helped me I appreciated that! Now the colors are just awesome!!!
                                          I’m finding that myself personally colors are making my mirror stand out and I like it… I’m sure many other users do as well!
                                          Thanks!
                                          • O
                                            @RedNax I Use the colored Icons. After the last update it works. But i’m Not sure if it goes wrong with an other weather like cloudy…
                                            • 10
                                            • 5 / 10
