    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 423.9k Views 51 Watching
    • O
      ostfilinchen
      Make a git pull and it will work
      P cowboysdudeC 2 Replies Last reply Reply Quote 0
        PointPubMedia @ostfilinchen
        @ostfilinchen Already did my git pull this morning…
        • cowboysdudeC
          cowboysdude Module Developer @ostfilinchen
          @ostfilinchen All that will do is download the upper image files… not the icons.
          You have to add that your custom.css like in the example above.
          The icons are pretty standard and used in, I think, every weather module here… they are icons outside the module and are not included…so you have to colorize them yourself.
          • O
            ostfilinchen @cowboysdude
            @cowboysdude no. If you Set the Parameter coloricon to true, all weather Icons shown colored. I have nothing Set in my custom.css. all colorsets Come from weatherunderground.css
            • L
              lolobyte @PointPubMedia
              @PointPubMedia
              same issue.
              The Day forecast doesn’t show the cloud’s as picture.
                RedNax Module Developer
                Just pushed a new version which fixes all this. Give it a try!
                L 1 Reply Last reply Reply Quote 2
                • L
                  lolobyte @RedNax
                  @RedNax
                  All looks good. Thank you for your fast reaction.
                    c502
                    @RedNax Thanks for the awesome module. I do have one question however…
                    Is there a way to change the current Beaufort wind speed to mph?
                      RedNax Module Developer @c502
                      @c502
                      Hi!
                      Pull the new version and add
                      windunits: "mph",
                      to your config…
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @RedNax
                        @RedNax
                        This is a stunningly beautiful and informative module and the many config options must make it a favorite of anyone that uses it. I tip my hat to you.
                        With that, may I make a humble request regarding fctext? I love this option but it can change from 3 lines to as many as 7 lines. Would it be possible to limit, or set, the amount of lines displayed. Or, could the text decrease in size as more information needs to be displayed, taking up the same amount of space?
                          RedNax Module Developer @Mykle1
                          @Mykle1 Hi,
                          Thank you for your kind words. I’ve now pushed a version that will dynamically scale the fontsize/line length of the forecast text. Give it a go! :D
                          O Mykle1M 2 Replies Last reply Reply Quote 0
                          • O
                            ostfilinchen @RedNax
                            @RedNax now it don’t Looks good:
                            the FC-Text goes above the lines. Can u please check this?
                              Doesn’t seem to happen on my setup…
                              Is your issue that the % sign is on a seperate line?
                              0_1487331607607_upload-38ed4333-3e1c-4b88-ac81-22ecf1a8ca03
                              O 2 Replies Last reply Reply Quote 0
                              • O
                                @RedNax no. The lines under and above the forecasttest are not toll the right side of the text.
                                • Mykle1M
                                  @RedNax said in Weatherunderground - currently - hourly - daily - configurable:
                                  I have to run off to work right now but I will “give it a go” as soon as I get home. I’ll let you know. Thanks for this.:thumbsup:
                                  • O
                                    @RedNax i can’t say why but now after a while, it looks correct.
                                      RedNax Module Developer @ostfilinchen
                                      @ostfilinchen There’s a new version. I left my test in which just used metric. Imperial users wouldn’t be happy. I’ve also added trim to the wordwrap function so here aren’t any trailing spaces
                                        bminer1
                                        Im still only getting the Icons. How do i get those nicer pictures?
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @bminer1
                                          @bminer1 Did you try coloricon: true?
                                            bminer1 @strawberry 3.141
                                            @strawberry-3.141
                                            I swear you guys are way too talented! Fixed.
                                            • 10
                                            • 5 / 10
