    Bad question
    64 Posts 5 Posters 71.3k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Fonfon
      @Fonfon said in Bad question:
      how you manage your pie when it is in the mirror ??
      This is how I do/did it:
      Go to your Pi Application Menu, scroll down to Preferences, scroll down to Raspberry Pi Configuration. In the window that opens click the Interfaces button. Enable VNC. Click OK. Your done with the Pi.
      On the computer that you want to manage your Pi from, go to https://www.realvnc.com/download/viewer/windows/ (In this case it’s for Windows. Choose your platform). Download VNC Viewer. This will allow you to remotely administer your Pi, and your MM, without having to take your mirror down or bring a mouse and keyboard to your mirror. I was doing that for a while until I learned this.
      There might be other ways but this is the way I do it.
      Peace
      Reply Quote 2
      • F
        Fonfon
        Thanks very much Mykle1 for your answering.!!
        good way !
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @Fonfon - You’re welcome. Peace. :peace:
          • F
            Fonfon
            Ok work great !!
            Now new questions how it’s possible to traduce module in french for french mirror of course ?
            thanks
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Fonfon
              @Fonfon you can set your language in the config file, if the modules have french translations they will be displayed in french. If they don’t have translation you can either add them and create a pull request on github or send the author the translations, so he can add them.
              • F
                Fonfon
                ok ok i understand thanks strawberry-3-141
                • F
                  Fonfon
                  Help me please
                   ERR! Linux 4.4.34-v7+
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                  npm ERR! node v6.9.5
                  npm ERR! npm  v3.10.10
                  npm ERR! code ENOENT
                  npm ERR! errno -2
                  npm ERR! syscall open
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is most likely not a problem with npm itself
                  npm ERR! enoent and is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/npm-debug.log
                  • strawberry 3.141S
                    @Fonfon you are in the wrong directory cd ~/MagicMirror
                    • F
                      Fonfon
                      for sure i’m so confuse !
                      • F
                        Fonfon
                        Another one !! ;)
                        WARNING! Could not find config file. Please create one. Starting with default configuration.
                        why he say that ?
                        thanks
                        • Mykle1M
                          @Fonfon
                          Your config was working and now it’s not? If you just added something to a working config then that’s probably the culprit. Post your config here so we can have a look at it
                          • F
                            Fonfon
                            /* Magic Mirror Config Sample
                            • MIT Licensed.
                            var config = {
                            port: 8080,
                            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.1/24”],
                            language: 'fr',
                            timeFormat: 24,
                            units: 'metric',
                            		module: 'alert',
                            		module: "updatenotification",
                            		position: "top_bar"
                            		module: 'calendar',
                            		header: 'US Holidays',
                            		position: 'top_left',
                            					symbol: 'calendar-check-o ',
                            		module: 'compliments',
                            		position: 'lower_third'
                            		module: 'currentweather',
                            		position: 'top_right',
                            			locationID: '',  //ID from http://www.openweathermap.org
                            			appid: 'YOUR_OPENWEATHER_API_KEY'
                            		module: 'weatherforecast',
                            		header: 'Weather Forecast',
                            			locationID: '5128581',  //ID from http://www.openweathermap.org
                            		module: 'newsfeed',
                            		position: 'bottom_bar',
                            			feeds: [
                            					title: "New York Times",
                            			showSourceTitle: true,
                            			showPublishDate: true
                            if (typeof module !== ‘undefined’) {module.exports = config;}
                            Mykle1M 2 Replies Last reply
                            • Mykle1M
                              • Mykle1M
                                @Fonfon
                                the 2nd { in the calendar module should be deleted for starters
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @Mykle1
                                  Like this
                                  	module: 'calendar',
                                  • F
                                    Fonfon
                                    Can you give me a correct config file for starting or where i can find it ?
                                    F Mykle1M 2 Replies Last reply
                                    • F
                                      Fonfon @Fonfon
                                      @Fonfon and when i start npm , my config file name is config.js or config.js.sample ?
                                      • Mykle1M
                                        Well, that one should work if you make the correction I noted. Otherwise, in the config folder is a file called config.js.sample. Make a copy of it and rename it to config.js. Then you’ll have to add your other modules and API keys
                                        • Mykle1M
                                          config.js or it won’t work
                                          • F
                                            Fonfon
                                            ok i understand my another problem is with the whitelist but i try to solve 1 problem after 1 problem
                                            thank mykle1
                                            • 1 / 4
