    Bad question
    64 Posts 5 Posters 70.2k Views 4 Watching
    • F Offline
      Fonfon
      Thanks very much Mykle1 for your answering.!!
      good way !
        Mykle1 Project Sponsor Module Developer @Fonfon
        @Fonfon - You’re welcome. Peace. :peace:
        • F Offline
          Fonfon
          Ok work great !!
          Now new questions how it’s possible to traduce module in french for french mirror of course ?
          thanks
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @Fonfon
            @Fonfon you can set your language in the config file, if the modules have french translations they will be displayed in french. If they don’t have translation you can either add them and create a pull request on github or send the author the translations, so he can add them.
            • F Offline
              Fonfon
              ok ok i understand thanks strawberry-3-141
              • F Offline
                Fonfon
                Help me please
                 ERR! Linux 4.4.34-v7+
                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                npm ERR! node v6.9.5
                npm ERR! npm  v3.10.10
                npm ERR! code ENOENT
                npm ERR! errno -2
                npm ERR! syscall open
                npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                npm ERR! enoent This is most likely not a problem with npm itself
                npm ERR! enoent and is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR!     /home/pi/npm-debug.log
                  @Fonfon you are in the wrong directory cd ~/MagicMirror
                  • F Offline
                    Fonfon
                    for sure i’m so confuse !
                    • F Offline
                      Fonfon
                      Another one !! ;)
                      WARNING! Could not find config file. Please create one. Starting with default configuration.
                      why he say that ?
                      thanks
                        @Fonfon
                        Your config was working and now it’s not? If you just added something to a working config then that’s probably the culprit. Post your config here so we can have a look at it
                        • F Offline
                          Fonfon
                          /* Magic Mirror Config Sample
                          • MIT Licensed.
                          var config = {
                          port: 8080,
                          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.1/24”],
                          language: 'fr',
                          timeFormat: 24,
                          units: 'metric',
                          		module: 'alert',
                          		module: "updatenotification",
                          		position: "top_bar"
                          		module: 'calendar',
                          		header: 'US Holidays',
                          		position: 'top_left',
                          					symbol: 'calendar-check-o ',
                          		module: 'compliments',
                          		position: 'lower_third'
                          		module: 'currentweather',
                          		position: 'top_right',
                          			locationID: '',  //ID from http://www.openweathermap.org
                          			appid: 'YOUR_OPENWEATHER_API_KEY'
                          		module: 'weatherforecast',
                          		header: 'Weather Forecast',
                          			locationID: '5128581',  //ID from http://www.openweathermap.org
                          		module: 'newsfeed',
                          		position: 'bottom_bar',
                          			feeds: [
                          					title: "New York Times",
                          			showSourceTitle: true,
                          			showPublishDate: true
                          if (typeof module !== ‘undefined’) {module.exports = config;}
                              @Fonfon
                              the 2nd { in the calendar module should be deleted for starters
                                Mykle1 Project Sponsor Module Developer @Mykle1
                                Like this
                                	module: 'calendar',
                                • F Offline
                                  Fonfon
                                  Can you give me a correct config file for starting or where i can find it ?
                                  F Mykle1M 2 Replies Last reply Reply Quote 0
                                  • F Offline
                                    Fonfon @Fonfon
                                    @Fonfon and when i start npm , my config file name is config.js or config.js.sample ?
                                      @Fonfon said in Bad question:
                                      Well, that one should work if you make the correction I noted. Otherwise, in the config folder is a file called config.js.sample. Make a copy of it and rename it to config.js. Then you’ll have to add your other modules and API keys
                                        config.js or it won’t work
                                        • F Offline
                                          Fonfon
                                          ok i understand my another problem is with the whitelist but i try to solve 1 problem after 1 problem
                                          thank mykle1
                                            @Fonfon yup, one thing at a time. Lets get your config.js working first
                                            • 1 / 4
