    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 249.5k Views 13 Watching
      djsunrise19
      Any ideas?
        djsunrise19
        I cloned your repo to MMM-WunderGround and edited the module name also. Now it works. You should change your Readme.
        Thanks for the cool module ;).
        R 1 Reply Last reply
        Reply Quote 2
          RedNax Module Developer @djsunrise19
          @djsunrise19 Thanks for spotting my mistake :D I’ve modified the readme accordingly. Enjoy!
            MagicCrumps1
            it’s taking me forever but How do i change pws: ‘locid:’ for san francisco? I cant find the location ID for my city using google
            • strawberry 3.141S
              Can be any WU api location info.
              US Example: NY/New_York
              Example: locid:NLXX8014;loctype:1
              so just change it to CA/San_Francisco
                MagicCrumps1
                I’m getting a blank screen. Any idea why?
                		module: 'MMM-WunderGround',
                		position: 'top_right',
                		header: 'Weather Forecast',
                		    apikey: 'a1fa37eaff91b5450c',
                		    pws: 'CA/San_Francisco',
                		    fctext: '1',
                			  fcdaycount: '5',
                			  fcdaystart: '0',
                			  hourly: '1',
                			  hourlyinterval: '3',
                				hourlycount: '2',
                				alerttime: 1000,
                				alerttruncatestring: 'english:'
                  Config looks good, could you have a look at your logs?
                  See here for some troubleshootign info: https://forum.magicmirror.builders/topic/86/how-to-troubleshoot
                    RedNax Module Developer @MagicCrumps1
                    @MagicCrumps1 On the other hand, you api key seems to be invalid. (if the key in your post is indeed your key):
                      "response": {
                      "version":"0.1",
                      "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
                      "features": {
                    	"error": {
                    		"type": "keynotfound"
                    		,"description": "this key does not exist"
                    M 2 Replies Last reply
                      MagicCrumps1 @RedNax
                        @RedNax Still not working. Sorry, I should have included that I added a few extra keys to my personal api key thus making them invalid.
                        Loading config …
                        Loading module helpers …
                        No helper found for module: MMM-WunderGround.
                        All module helpers loaded.
                        Starting server op port 8080 …
                        Server started …
                        Starting module: newsfeed
                        Sockets connected & modules started …
                        Launching application.
                        • K
                          KirAsh4 Moderator
                          That looks like everything did load up properly there. There’s a way to look at electron’s console logs but I don’t know what the keystroke is (maybe CTRL-W?). But, at times like this, I find it’s easier/faster for me to debug by using a different machine with Chrome/Firefox and load up the mirror that way by going to the rpi’s IP and port: http://10.0.0.1:8080 (assuming your rpi’s IP is 10.0.0.1, change it to match yours.) Black screen or not, you can always hit F12 on a windows browser and pull up the console log. Look for Javascript errors.
                            MagicCrumps1
                            Thanks KirAsh4 and RedNax! I resolved it. What happened was that I entered
                            locationid: ‘5391959’
                            on the currentweather module.
                            I decided to delete the locationid key and left it blank and voila! It works now! You guys rock!
                              MagicCrumps1
                              @RedNax do you happen to know why my MMM-WunderGround module is not showing the forecast?
                              0_1465449394807_upload-42252077-f895-4414-a919-4178207675af
                                Any errors in the console or the web inspector?
                                  Shockwave
                                  This module is fantastic, thank you. I was wondering about getting weather for multiple areas. Is there a way to do that within the program or would I need to copy the directory to say, MMM-WunderGround2?
                                    RedNax Module Developer @Shockwave
                                    @Shockwave Thanks :) To use the module twice you can just enter multiple wunderground config sections in your config.js. It will then display both. There is no need to install the actual module twice.
                                      Shockwave @RedNax
                                      @RedNax Hey thanks for the quick response! I have 2 locations up and running and great. Unfortunately I now have another question. :smile: There is a special weather statement for one of my 2 locations, and it popped up an alert which is really cool. However, the popup alert just said, Special Statement, which is just the subject text, for lack of a better description. Is that the expected behavior?
                                      Special Statement
                                      Issued: 1:49 PM EDT Jun. 27, 2016 – National Weather Service
                                      … A strong thunderstorm with intense lightning will impact central
                                      Oconee County until 230 PM EDT…
                                      At 148 PM EDT… Doppler radar was tracking a strong thunderstorm
                                      with intense lightning 5 miles northwest of Walhalla… or near
                                      Oconee State Park… moving southeast at 25 mph.
                                      Locations to be impacted include…
                                      Walhalla… Westminster… Oconee State Park… Lake Keowee and Mountain
                                      Rest.
                                      In addition to intense lightning… pea size hail and wind gusts up to
                                      40 mph will be possible in these areas.
                                        pugsly
                                        Quick question about this module and some of the icon classes. I found which ones I need to change for the high and low temperature in the custom.css file, which works great. What I can’t figure out is how come I can’t get sunset to change to orange, and sunrise to yellow. I am pretty sure its the right icon.
                                        .wi.wi-thermometer {
                                          color: #ff0000; /* Red */
                                        .wi.wi-thermometer-exterior {
                                          color: #0000ff; /* Blue */
                                        .wi.wi-umbrella {
                                          color: white;
                                        wi.wi.sunset {
                                          color: orange;
                                        wi.wi.sunrise {
                                          color: yellow;
                                          pugsly
                                          Nevermind, I found it.
                                          .wi.dimmed.wi-sunset
                                          and
                                          .wi.dimmed.wi-sunrise
                                            @Shockwave Sorry for the late reply… missed your post here…
                                            It’s not expected behaviour. The entire message should be displayed in the popup. It may have something to do with the
                                            				alerttruncatestring : "english:"
                                            property…
                                            Try changing t to an empty string.
                                            Also, could you post the entire result of your api call?
                                            http://api.wunderground.com/api/<apikey>/conditions/forecast10day/astronomy/alerts/lang:EN/q/<value of your pws property>.json
                                            • 3 / 7
